--- ray/src/common/rtprocess.h 2020/02/28 05:18:49 3.18 +++ ray/src/common/rtprocess.h 2021/01/15 19:01:53 3.20 @@ -1,4 +1,4 @@ -/* RCSid $Id: rtprocess.h,v 3.18 2020/02/28 05:18:49 greg Exp $ */ +/* RCSid $Id: rtprocess.h,v 3.20 2021/01/15 19:01:53 greg Exp $ */ /* * rtprocess.h * Routines to communicate with separate process via dual pipes @@ -58,6 +58,49 @@ extern "C" { on the output of the parent. Make sure to call fflush(stdout) first if any data was buffered. It is illegal to set both PF_FILT_INP and PF_FILT_OUT, as a circular process is guaranteed to hang. + + If you want behavior similar to popen(cmd, "w") (again Unix-only), + keeping stdout open in parent, use a duplicate descriptor like so: + { + SUBPROC rtp = sp_inactive; + FILE *fout; + fflush(stdout); + rtp.w = dup(fileno(stdout)); + rtp.flags |= PF_FILT_OUT; + if (open_process(&rtp, cmd_argv) <= 0) { + perror(cmd_argv[0]); exit(1); + } + fout = fdopen(rtp.w, "w"); + ...write data to filter using fout until finished... + fclose(fout); + if (close_process(&rtp)) { + perror(cmd_argv[0]); exit(1); + } + ...can continue sending data directly to stdout... + } + We could also have called open_process() after fdopen() above, or after + using fopen() on a file if we wanted to insert our filter before it. + A similar sequence may be used to filter from stdin without closing + it, though process termination becomes more difficult with two readers. + Filtering input from a file works better, since the file is then read by + the child only, as in: + { + SUBPROC rtp = sp_inactive; + FILE *fin = fopen(fname, "r"); + if (fin == NULL) { + open_error(fname); exit(1); + } + rtp.r = fileno(fin); + rtp.flags |= PF_FILT_INP; + if (open_process(&rtp, cmd_argv) <= 0) { + perror(cmd_argv[0]); fclose(fin); exit(1); + } + ...read filtered file data from fin until EOF... + fclose(fin); + if (close_process(&rtp)) { + perror(cmd_argv[0]); exit(1); + } + } */ @@ -91,8 +134,8 @@ typedef struct { extern int open_process(SUBPROC *pd, char *av[]); extern int close_processes(SUBPROC pd[], int nproc); extern int process(SUBPROC *pd, char *recvbuf, char *sendbuf, int nbr, int nbs); -extern int readbuf(int fd, char *bpos, int siz); -extern int writebuf(int fd, char *bpos, int siz); +extern ssize_t readbuf(int fd, char *bpos, ssize_t siz); +extern ssize_t writebuf(int fd, char *bpos, ssize_t siz); #if defined(_WIN32) || defined(_WIN64) /* any non-negative increment will send the process to IDLE_PRIORITY_CLASS. */
