--- ray/src/common/rtprocess.h 2004/01/28 12:42:22 3.10 +++ ray/src/common/rtprocess.h 2020/02/28 05:18:49 3.18 @@ -1,4 +1,4 @@ -/* RCSid $Id: rtprocess.h,v 3.10 2004/01/28 12:42:22 schorsch Exp $ */ +/* RCSid $Id: rtprocess.h,v 3.18 2020/02/28 05:18:49 greg Exp $ */ /* * rtprocess.h * Routines to communicate with separate process via dual pipes @@ -9,26 +9,15 @@ #define _RAD_PROCESS_H_ #include -#ifdef _WIN32 +#include +#if defined(_WIN32) || defined(_WIN64) #include /* DWORD etc. */ - #include typedef DWORD RT_PID; #include /* getpid() and others */ - #define nice(inc) win_nice(inc) - - #ifdef __cplusplus - extern "C" { - #endif - extern FILE *win_popen(char *command, char *type); - extern int win_pclose(FILE *p); - #ifdef __cplusplus - } - #endif - - #define popen(cmd,mode) win_popen(cmd,mode) - #define pclose(p) win_pclose(p) + #define getpid _getpid + #define execv _execv + #define execvp _execvp #else - #include #include #include typedef pid_t RT_PID; @@ -49,7 +38,29 @@ extern "C" { platform independent RT_PID. */ +/* On Unix, we can set flags and assign descriptors before opening a + process, coupling an existing input or output to the new process rather + than opening both pipes. If PF_FILT_INP is passed in the flags member of + SUBPROC, then the given r stream will be attached to the standard input + of the child process, and subsequent reads from that descriptor in the + parent get data from the standard output of the child, instead. The + returned w descriptor is set to -1, since there is no longer any way + to write to the input of the child. The default r descriptor of 0 will + compel the child to act as a filter on the standard input of the parent. + Whatever r handle you specify, the child will filter its read operations. + Note that this should be called before anything has been buffered using r. + If PF_FILT_OUT is set in flags, then the given w stream will be + attached to the standard output of the child, and subsequent writes + to that descriptor in the parent send data to the standard input + of the child. The returned r descriptor is set to -1, since + there is no output to read from any longer in the child. The + default w descriptor of 1 will cause the child to act as a filter + on the output of the parent. Make sure to call fflush(stdout) first + if any data was buffered. It is illegal to set both PF_FILT_INP and + PF_FILT_OUT, as a circular process is guaranteed to hang. +*/ + #ifndef PIPE_BUF #ifdef PIPSIZ #define PIPE_BUF PIPSIZ @@ -61,27 +72,35 @@ extern "C" { #endif #endif #endif + /* process flags */ +#define PF_RUNNING 1 /* process is running */ +#define PF_FILT_INP 2 /* use assigned read descriptor */ +#define PF_FILT_OUT 4 /* use assigned write descriptor */ typedef struct { - int r; /* read handle */ - int w; /* write handle */ - int running; /* doing something */ - RT_PID pid; /* process ID */ + int flags; /* what is being done */ + int r; /* read handle */ + int w; /* write handle */ + RT_PID pid; /* process ID */ } SUBPROC; -#define SP_INACTIVE {-1,-1,0,0} /* for static initializations */ +#define SP_INACTIVE {0,0,1,-1} /* for static initializations */ +#define close_process(pd) close_processes(pd,1) + extern int open_process(SUBPROC *pd, char *av[]); -extern int close_process(SUBPROC *pd); +extern int close_processes(SUBPROC pd[], int nproc); extern int process(SUBPROC *pd, char *recvbuf, char *sendbuf, int nbr, int nbs); extern int readbuf(int fd, char *bpos, int siz); extern int writebuf(int fd, char *bpos, int siz); -#ifdef _WIN32 +#if defined(_WIN32) || defined(_WIN64) /* any non-negative increment will send the process to IDLE_PRIORITY_CLASS. */ +extern int win_kill(RT_PID pid, int sig /* ignored */); extern int win_nice(int inc); #endif +extern SUBPROC sp_inactive; #ifdef __cplusplus }
