root/radiance/ray/src/common/rtprocess.h
Revision: 3.18
Committed: Fri Feb 28 05:18:49 2020 UTC (5 years, 4 months ago) by greg
Changes since 3.17: +33 -6 lines
1 /* RCSid $Id: rtprocess.h,v 3.17 2018/03/20 17:45:07 greg Exp $ */
2 /*
3 * rtprocess.h
4 * Routines to communicate with separate process via dual pipes
5 *
6 * WARNING: On Windows, there's a system header named <process.h>.
7 */
8 #ifndef _RAD_PROCESS_H_
9 #define _RAD_PROCESS_H_
10
11 #include <errno.h>
12 #include <stdio.h>
13 #if defined(_WIN32) || defined(_WIN64)
14 #include <windows.h> /* DWORD etc. */
15 typedef DWORD RT_PID;
16 #include <process.h> /* getpid() and others */
17 #define getpid _getpid
18 #define execv _execv
19 #define execvp _execvp
20 #else
21 #include <sys/param.h>
22 #include <sys/types.h>
23 typedef pid_t RT_PID;
24 #endif
25
26 #include "paths.h"
27
28 #ifdef __cplusplus
29 extern "C" {
30 #endif
31
32 /* On Windows, a process ID is a DWORD. That might actually be the
33 same thing as an int, but it's better not to assume anything.
34
35 This means that we shouldn't rely on PIDs and file descriptors
36 being the same type, so we have to describe processes with a struct,
37 instead of the original int[3]. For that purpose, we typedef a
38 platform independent RT_PID.
39 */
40
41 /* On Unix, we can set flags and assign descriptors before opening a
42 process, coupling an existing input or output to the new process rather
43 than opening both pipes. If PF_FILT_INP is passed in the flags member of
44 SUBPROC, then the given r stream will be attached to the standard input
45 of the child process, and subsequent reads from that descriptor in the
46 parent get data from the standard output of the child, instead. The
47 returned w descriptor is set to -1, since there is no longer any way
48 to write to the input of the child. The default r descriptor of 0 will
49 compel the child to act as a filter on the standard input of the parent.
50 Whatever r handle you specify, the child will filter its read operations.
51 Note that this should be called before anything has been buffered using r.
52 If PF_FILT_OUT is set in flags, then the given w stream will be
53 attached to the standard output of the child, and subsequent writes
54 to that descriptor in the parent send data to the standard input
55 of the child. The returned r descriptor is set to -1, since
56 there is no output to read from any longer in the child. The
57 default w descriptor of 1 will cause the child to act as a filter
58 on the output of the parent. Make sure to call fflush(stdout) first
59 if any data was buffered. It is illegal to set both PF_FILT_INP and
60 PF_FILT_OUT, as a circular process is guaranteed to hang.
61 */
62
63
64 #ifndef PIPE_BUF
65 #ifdef PIPSIZ
66 #define PIPE_BUF PIPSIZ
67 #else
68 #ifdef PIPE_MAX
69 #define PIPE_BUF PIPE_MAX
70 #else
71 #define PIPE_BUF 512 /* hyperconservative */
72 #endif
73 #endif
74 #endif
75 /* process flags */
76 #define PF_RUNNING 1 /* process is running */
77 #define PF_FILT_INP 2 /* use assigned read descriptor */
78 #define PF_FILT_OUT 4 /* use assigned write descriptor */
79
80 typedef struct {
81 int flags; /* what is being done */
82 int r; /* read handle */
83 int w; /* write handle */
84 RT_PID pid; /* process ID */
85 } SUBPROC;
86
87 #define SP_INACTIVE {0,0,1,-1} /* for static initializations */
88
89 #define close_process(pd) close_processes(pd,1)
90
91 extern int open_process(SUBPROC *pd, char *av[]);
92 extern int close_processes(SUBPROC pd[], int nproc);
93 extern int process(SUBPROC *pd, char *recvbuf, char *sendbuf, int nbr, int nbs);
94 extern int readbuf(int fd, char *bpos, int siz);
95 extern int writebuf(int fd, char *bpos, int siz);
96
97 #if defined(_WIN32) || defined(_WIN64)
98 /* any non-negative increment will send the process to IDLE_PRIORITY_CLASS. */
99 extern int win_kill(RT_PID pid, int sig /* ignored */);
100 extern int win_nice(int inc);
101 #endif
102
103 extern SUBPROC sp_inactive;
104
105 #ifdef __cplusplus
106 }
107 #endif
108 #endif /* _RAD_PROCESS_H_ */
109
