root/radiance/ray/src/common/rtprocess.h
Revision: 3.7
Committed: Mon Nov 10 16:41:52 2003 UTC (21 years, 6 months ago) by greg
Changes since 3.6: +5 -1 lines
1 /* RCSid $Id: rtprocess.h,v 3.6 2003/10/27 10:19:31 schorsch Exp $ */
2 /*
3 * rtprocess.h
4 * Routines to communicate with separate process via dual pipes
5 *
6 * WARNING: On Windows, there's a system header named <process.h>.
7 */
8 #ifndef _RAD_PROCESS_H_
9 #define _RAD_PROCESS_H_
10
11 #include <errno.h>
12 #ifdef _WIN32
13 #include <windows.h> /* DWORD etc. */
14 #include <stdio.h>
15 typedef DWORD pid_t;
16 #include <process.h> /* getpid() and others */
17 #define nice(inc) win_nice(inc)
18
19 #ifdef __cplusplus
20 extern "C" {
21 #endif
22 extern FILE *win_popen(char *command, char *type);
23 extern int win_pclose(FILE *p);
24 #ifdef __cplusplus
25 }
26 #endif
27
28 #define popen(cmd,mode) win_popen(cmd,mode)
29 #define pclose(p) win_pclose(p)
30 #else
31 #include <sys/param.h>
32 #endif
33
34 #include "paths.h"
35
36 #if !defined(BSD) || defined(sparc)
37 #define vfork fork
38 #endif
39
40 #ifdef __cplusplus
41 extern "C" {
42 #endif
43
44 /* On Windows, a process ID is a DWORD. That might actually be the
45 same thing as an int, but it's better not to assume anything.
46
47 This means that we shouldn't rely on PIDs and file descriptors
48 being the same type, so we have to describe processes with a struct,
49 instead of the original int[3]. To keep things simple, we typedef
50 the posix pid_t on those systems that don't have it already.
51 */
52
53
54 #ifndef PIPE_BUF
55 #ifdef PIPSIZ
56 #define PIPE_BUF PIPSIZ
57 #else
58 #ifdef PIPE_MAX
59 #define PIPE_BUF PIPE_MAX
60 #else
61 #define PIPE_BUF 512 /* hyperconservative */
62 #endif
63 #endif
64 #endif
65
66 typedef struct {
67 int r; /* read handle */
68 int w; /* write handle */
69 int running; /* doing something */
70 pid_t pid; /* process ID */
71 } SUBPROC;
72
73 #define SP_INACTIVE {-1,-1,0,0} /* for static initializations */
74
75 extern int open_process(SUBPROC *pd, char *av[]);
76 extern int close_process(SUBPROC *pd);
77 extern int process(SUBPROC *pd, char *recvbuf, char *sendbuf, int nbr, int nbs);
78 extern int readbuf(int fd, char *bpos, int siz);
79 extern int writebuf(int fd, char *bpos, int siz);
80
81 #ifdef _WIN32
82 /* any non-negative increment will send the process to IDLE_PRIORITY_CLASS. */
83 extern int win_nice(int inc);
84 #endif
85
86
87 #ifdef __cplusplus
88 }
89 #endif
90 #endif /* _RAD_PROCESS_H_ */
91
