1 |
/* RCSid $Id: rtprocess.h,v 3.3 2003/07/14 20:02:29 schorsch Exp $ */ |
2 |
3 |
* rtprocess.h |
4 |
* Routines to communicate with separate process via dual pipes |
5 |
6 |
* WARNING: On Windows, there's a system header named <process.h>. |
7 |
8 |
#ifndef _RAD_PROCESS_H_ |
9 |
#define _RAD_PROCESS_H_ |
10 |
11 |
#include <errno.h> |
12 |
#ifdef _WIN32 |
13 |
#include <windows.h> /* DWORD etc. */ |
14 |
typedef DWORD pid_t; |
15 |
#include <process.h> /* getpid() and others */ |
16 |
#else |
17 |
#include <sys/param.h> |
18 |
#endif |
19 |
20 |
#include "paths.h" |
21 |
22 |
#ifdef __cplusplus |
23 |
extern "C" { |
24 |
#endif |
25 |
26 |
/* On Windows, a process ID is a DWORD. That might actually be the |
27 |
same thing as an int, but it's better not to assume anything. |
28 |
29 |
This means that we shouldn't rely on PIDs and file descriptors |
30 |
being the same type, so we have to describe processes with a struct, |
31 |
instead of the original int[3]. To keep things simple, we typedef |
32 |
the posix pid_t on those systems that don't have it already. |
33 |
34 |
Some older Windows systems use negative PIDs. Open_process() and |
35 |
close_process() will convert those to positive values during |
36 |
runtime, so that client modules can still use -1 as invalid PID. |
37 |
38 |
39 |
40 |
#ifndef PIPE_BUF |
41 |
#ifdef PIPSIZ |
42 |
#define PIPE_BUF PIPSIZ |
43 |
#else |
44 |
#ifdef PIPE_MAX |
45 |
#define PIPE_BUF PIPE_MAX |
46 |
#else |
47 |
#define PIPE_BUF 512 /* hyperconservative */ |
48 |
#endif |
49 |
#endif |
50 |
#endif |
51 |
52 |
typedef struct { |
53 |
int r; /* read handle */ |
54 |
int w; /* write handle */ |
55 |
int running; /* doing something */ |
56 |
pid_t pid; /* process ID */ |
57 |
} SUBPROC; |
58 |
59 |
#define SP_INACTIVE {-1,-1,0,0} /* for static initializations */ |
60 |
61 |
extern int open_process(SUBPROC *pd, char *av[]); |
62 |
extern int close_process(SUBPROC *pd); |
63 |
extern int process(SUBPROC *pd, char *recvbuf, char *sendbuf, int nbr, int nbs); |
64 |
extern int readbuf(int fd, char *bpos, int siz); |
65 |
extern int writebuf(int fd, char *bpos, int siz); |
66 |
67 |
68 |
69 |
70 |
#endif |
71 |
#endif /* _RAD_PROCESS_H_ */ |
72 |
