root/Development/ray/src/common/rtprocess.h
Revision: 3.13
Committed: Tue Feb 2 18:02:32 2016 UTC (9 years, 11 months ago) by greg
Changes since 3.12: +2 -22 lines
1 /* RCSid $Id: rtprocess.h,v 3.12 2014/03/04 17:06:13 greg Exp $ */
2 /*
3 * rtprocess.h
4 * Routines to communicate with separate process via dual pipes
5 *
6 * WARNING: On Windows, there's a system header named <process.h>.
7 */
8 #ifndef _RAD_PROCESS_H_
9 #define _RAD_PROCESS_H_
10
11 #include <errno.h>
12 #include <stdio.h>
13 #ifdef _WIN32
14 #include <windows.h> /* DWORD etc. */
15 typedef DWORD RT_PID;
16 #include <process.h> /* getpid() and others */
17 #else
18 #include <sys/param.h>
19 #include <sys/types.h>
20 typedef pid_t RT_PID;
21 #endif
22
23 #include "paths.h"
24
25 #ifdef __cplusplus
26 extern "C" {
27 #endif
28
29 /* On Windows, a process ID is a DWORD. That might actually be the
30 same thing as an int, but it's better not to assume anything.
31
32 This means that we shouldn't rely on PIDs and file descriptors
33 being the same type, so we have to describe processes with a struct,
34 instead of the original int[3]. For that purpose, we typedef a
35 platform independent RT_PID.
36 */
37
38
39 #ifndef PIPE_BUF
40 #ifdef PIPSIZ
41 #define PIPE_BUF PIPSIZ
42 #else
43 #ifdef PIPE_MAX
44 #define PIPE_BUF PIPE_MAX
45 #else
46 #define PIPE_BUF 512 /* hyperconservative */
47 #endif
48 #endif
49 #endif
50
51 typedef struct {
52 int r; /* read handle */
53 int w; /* write handle */
54 int running; /* doing something */
55 RT_PID pid; /* process ID */
56 } SUBPROC;
57
58 #define SP_INACTIVE {-1,-1,0,0} /* for static initializations */
59
60 extern int open_process(SUBPROC *pd, char *av[]);
61 extern int close_process(SUBPROC *pd);
62 extern int process(SUBPROC *pd, char *recvbuf, char *sendbuf, int nbr, int nbs);
63 extern int readbuf(int fd, char *bpos, int siz);
64 extern int writebuf(int fd, char *bpos, int siz);
65
66 #ifdef _WIN32
67 /* any non-negative increment will send the process to IDLE_PRIORITY_CLASS. */
68 extern int win_nice(int inc);
69 #endif
70
71
72 #ifdef __cplusplus
73 }
74 #endif
75 #endif /* _RAD_PROCESS_H_ */
76
