root/radiance/ray/src/common/rtio.h
Revision: 3.9
Committed: Sat Dec 23 17:27:45 2006 UTC (17 years, 4 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad4R2, rad4R1, rad4R0, rad3R9, rad4R2P1
Changes since 3.8: +5 -1 lines
1 /* RCSid $Id: rtio.h,v 3.8 2004/03/28 20:33:12 schorsch Exp $ */
2 /*
3 * Radiance i/o and string routines
4 */
5
6 #ifndef _RAD_RTIO_H_
7 #define _RAD_RTIO_H_
8
9 #include <stdio.h>
10 #include <sys/types.h>
11 #include <fcntl.h>
12 #include <string.h>
13
14 #ifdef __cplusplus
15 extern "C" {
16 #endif
17 /* defined in badarg.c */
18 extern int badarg(int ac, char **av, char *fl);
19 /* defined in expandarg.c */
20 extern int expandarg(int *acp, char ***avp, int n);
21 /* defined in fdate.c */
22 extern time_t fdate(char *fname);
23 extern int setfdate(char *fname, long ftim);
24 /* defined in fgetline.c */
25 extern char *fgetline(char *s, int n, FILE *fp);
26 /* defined in fgetval.c */
27 extern int fgetval(FILE *fp, int ty, void *vp);
28 /* defined in fgetword.c */
29 extern char *fgetword(char *s, int n, FILE *fp);
30 /* defined in fputword.c */
31 extern void fputword(char *s, FILE *fp);
32 /* defined in fropen.c */
33 extern FILE *frlibopen(char *fname);
34 /* defined in getlibpath.c */
35 extern char *getrlibpath(void);
36 /* defined in gethomedir.c */
37 extern char *gethomedir(char *uname, char *path, int plen);
38 /* defined in getpath.c */
39 extern char *getpath(char *fname, char *searchpath, int mode);
40 /* defined in byteswap.c */
41 extern void swap16(char *wp, int n);
42 extern void swap32(char *wp, int n);
43 extern void swap64(char *wp, int n);
44 /* defined in portio.c */
45 extern void putstr(char *s, FILE *fp);
46 extern void putint(long i, int siz, FILE *fp);
47 extern void putflt(double f, FILE *fp);
48 extern char *getstr(char *s, FILE *fp);
49 extern long getint(int siz, FILE *fp);
50 extern double getflt(FILE *fp);
51 /* defined in rexpr.c */
52 extern int ecompile(char *sp, int iflg, int wflag);
53 extern char *expsave(void);
54 extern void expset(char *ep);
55 extern char *eindex(char *sp);
56 /* defined in savestr.c */
57 extern char *savestr(char *str);
58 extern void freestr(char *s);
59 extern int shash(char *s);
60 /* defined in savqstr.c */
61 extern char *savqstr(char *s);
62 extern void freeqstr(char *s);
63 /* defined in wordfile.c */
64 extern int wordfile(char **words, char *fname);
65 extern int wordstring(char **avl, char *str);
66 /* defined in words.c */
67 extern char *atos(char *rs, int nb, char *s);
68 extern char *nextword(char *cp, int nb, char *s);
69 extern char *sskip(char *s);
70 extern char *sskip2(char *s, int n);
71 extern char *iskip(char *s);
72 extern char *fskip(char *s);
73 extern int isint(char *s);
74 extern int isintd(char *s, char *ds);
75 extern int isflt(char *s);
76 extern int isfltd(char *s, char *ds);
77 /* defined in lamp.c */
78 extern float * matchlamp(char *s);
79 extern int loadlamps(char *file);
80 extern void freelamps(void);
81
82 #ifdef __cplusplus
83 }
84 #endif
85 #endif /* _RAD_RTIO_H_ */
86
