root/radiance/ray/src/common/rtio.h
Revision: 3.22
Committed: Wed Aug 14 18:20:02 2019 UTC (5 years, 9 months ago) by greg
Changes since 3.21: +4 -1 lines
1 /* RCSid $Id: rtio.h,v 3.21 2019/08/09 23:34:39 greg Exp $ */
2 /*
3 * Radiance i/o and string routines
4 */
5
6 #ifndef _RAD_RTIO_H_
7 #define _RAD_RTIO_H_
8
9 #include <stdio.h>
10 #include <sys/types.h>
11 #include <fcntl.h>
12 #include <string.h>
13 #include <time.h>
14
15 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
16 #undef getc
17 #undef getchar
18 #undef putc
19 #undef putchar
20 #undef feof
21 #undef ferror
22 #define getc getc_unlocked
23 #define getchar getchar_unlocked
24 #define putc putc_unlocked
25 #define putchar putchar_unlocked
26 #ifndef __cplusplus
27 #define feof feof_unlocked
28 #define ferror ferror_unlocked
29 #endif
30 #endif
31
32 #ifdef __cplusplus
33 extern "C" {
34 #endif
35 /* identify header lines */
36 #define MAXFMTLEN 64
37 #define isheadid(s) headidval(NULL,s)
38 #define isformat(s) formatval(NULL,s)
39 #define isdate(s) dateval(NULL,s)
40 #define isgmt(s) gmtval(NULL,s)
41
42 #define LATLONSTR "LATLONG="
43 #define LLATLONSTR 8
44 #define islatlon(hl) (!strncmp(hl,LATLONSTR,LLATLONSTR))
45 #define latlonval(ll,hl) sscanf((hl)+LLATLONSTR, "%f %f", \
46 &(ll)[0],&(ll)[1])
47 #define fputlatlon(lat,lon,fp) fprintf(fp,"%s %.6f %.6f\n",LATLONSTR,lat,lon)
48 /* defined in header.c */
49 extern void newheader(const char *t, FILE *fp);
50 extern int headidval(char *r, const char *s);
51 extern int dateval(time_t *t, const char *s);
52 extern int gmtval(time_t *t, const char *s);
53 extern void fputdate(time_t t, FILE *fp);
54 extern void fputnow(FILE *fp);
55 extern void printargs(int ac, char **av, FILE *fp);
56 extern int formatval(char fmt[MAXFMTLEN], const char *s);
57 extern void fputformat(const char *s, FILE *fp);
58 extern int nativebigendian(void);
59 extern int isbigendian(const char *s);
60 extern void fputendian(FILE *fp);
61 typedef int gethfunc(char *s, void *p); /* callback to process header lines */
62 extern int getheader(FILE *fp, gethfunc *f, void *p);
63 extern int globmatch(const char *pat, const char *str);
64 extern int checkheader(FILE *fin, char fmt[MAXFMTLEN], FILE *fout);
65 /* defined in badarg.c */
66 extern int badarg(int ac, char **av, char *fl);
67 /* defined in expandarg.c */
68 extern int envexpchr, filexpchr;
69 extern int expandarg(int *acp, char ***avp, int n);
70 /* defined in fdate.c */
71 extern time_t fdate(char *fname);
72 extern int setfdate(char *fname, long ftim);
73 /* defined in fgetline.c */
74 extern char *fgetline(char *s, int n, FILE *fp);
75 /* defined in fgetval.c */
76 extern int fgetval(FILE *fp, int ty, void *vp);
77 /* defined in fgetword.c */
78 extern char *fgetword(char *s, int n, FILE *fp);
79 /* defined in fputword.c */
80 extern void fputword(char *s, FILE *fp);
81 /* defined in fropen.c */
82 extern FILE *frlibopen(char *fname);
83 /* defined in getlibpath.c */
84 extern char *getrlibpath(void);
85 /* defined in gethomedir.c */
86 extern char *gethomedir(char *uname, char *path, int plen);
87 /* defined in getpath.c */
88 extern char *getpath(char *fname, char *searchpath, int mode);
89 /* defined in byteswap.c */
90 extern void swap16(char *wp, int n);
91 extern void swap32(char *wp, int n);
92 extern void swap64(char *wp, int n);
93 /* defined in portio.c */
94 extern void putstr(char *s, FILE *fp);
95 extern void putint(long i, int siz, FILE *fp);
96 extern void putflt(double f, FILE *fp);
97 extern int putbinary(const void *s, int elsiz, int nel, FILE *fp);
98 extern char *getstr(char *s, FILE *fp);
99 extern long getint(int siz, FILE *fp);
100 extern double getflt(FILE *fp);
101 extern int getbinary(void *s, int elsiz, int nel, FILE *fp);
102 /* defined in rexpr.c */
103 extern int ecompile(char *sp, int iflg, int wflag);
104 extern char *expsave(void);
105 extern void expset(char *ep);
106 extern char *eindex(char *sp);
107 /* defined in savestr.c */
108 extern char *savestr(char *str);
109 extern void freestr(char *s);
110 extern int shash(char *s);
111 /* defined in savqstr.c */
112 extern char *savqstr(char *s);
113 extern void freeqstr(char *s);
114 /* defined in wordfile.c */
115 extern int wordfile(char **words, int nargs, char *fname);
116 extern int wordstring(char **avl, int nargs, char *str);
117 /* defined in words.c */
118 extern char *atos(char *rs, int nb, char *s);
119 extern char *nextword(char *cp, int nb, char *s);
120 extern char *sskip(char *s);
121 extern char *sskip2(char *s, int n);
122 extern char *iskip(char *s);
123 extern char *fskip(char *s);
124 extern int isint(char *s);
125 extern int isintd(char *s, char *ds);
126 extern int isflt(char *s);
127 extern int isfltd(char *s, char *ds);
128 /* defined in lamp.c */
129 extern float * matchlamp(char *s);
130 extern int loadlamps(char *file);
131 extern void freelamps(void);
132
133 #ifndef strlcpy /* defined in option strlcpy.c */
134 extern size_t strlcpy(char *dst, const char *src, size_t siz);
135 extern size_t strlcat(char *dst, const char *src, size_t siz);
136 #endif
137
138 #ifdef __cplusplus
139 }
140 #endif
141 #endif /* _RAD_RTIO_H_ */
142
