root/Development/ray/src/common/rtio.h
Sat Jun 7 05:09:45 2025 UTC (6 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 3.33: +1 -10 lines
Diff to previous 3.33 , to selected 3.21
Sat Mar 1 00:51:26 2025 UTC (10 months ago) by greg
Changes since 3.32: +4 -1 lines
Diff to previous 3.32 , to selected 3.21
chore: Added missing strncasecmp() library call for Windows
Tue Dec 3 01:11:43 2024 UTC (12 months, 4 weeks ago) by greg
Changes since 3.31: +5 -1 lines
Diff to previous 3.31 , to selected 3.21
Tue Oct 29 00:35:06 2024 UTC (14 months ago) by greg
Changes since 3.30: +2 -2 lines
Diff to previous 3.30 , to selected 3.21
refactor: Changed some calls to use const type for better C++ callability
Fri Dec 15 03:42:31 2023 UTC (2 years ago) by greg
Changes since 3.29: +4 -4 lines
Diff to previous 3.29 , to selected 3.21
refactor: Removed unnecessary parens
Thu Jun 8 17:48:01 2023 UTC (2 years, 6 months ago) by greg
Changes since 3.28: +3 -3 lines
Diff to previous 3.28 , to selected 3.21
fix: passing const char * to savestr() and shash()
Fri Feb 10 18:29:46 2023 UTC (2 years, 10 months ago) by greg
Changes since 3.27: +4 -3 lines
Diff to previous 3.27 , to selected 3.21
feat: Added fddate() call to get modification time from open file
Mon Feb 6 22:40:21 2023 UTC (2 years, 10 months ago) by greg
Changes since 3.26: +2 -2 lines
Diff to previous 3.26 , to selected 3.21
Sat Feb 4 17:24:30 2023 UTC (2 years, 10 months ago) by greg
Changes since 3.25: +3 -3 lines
Diff to previous 3.25 , to selected 3.21
fix: moved #undef's to where they belonged
Fri Feb 19 16:15:23 2021 UTC (4 years, 10 months ago) by greg
Changes since 3.24: +4 -4 lines
Diff to previous 3.24 , to selected 3.21
feat: added output stream error-checking to putstr(), putint(), and putflt()
Fri Jan 15 18:31:38 2021 UTC (4 years, 11 months ago) by greg
Changes since 3.23: +6 -6 lines
Diff to previous 3.23 , to selected 3.21
More 64-bit addressing fixes
Thu Nov 7 23:20:28 2019 UTC (6 years, 1 month ago) by greg
Changes since 3.22: +3 -1 lines
Diff to previous 3.22 , to selected 3.21
Wed Aug 14 18:20:02 2019 UTC (6 years, 4 months ago) by greg
Changes since 3.21: +4 -1 lines
Diff to previous 3.21
Revision 3.21 - (view) (download) (annotate) - [selected]
Fri Aug 9 23:34:39 2019 UTC (6 years, 4 months ago) by greg
Changes since 3.20: +3 -1 lines
Diff to previous 3.20
Added retrofit for macOS Sierra+
Fri Jul 19 17:37:56 2019 UTC (6 years, 5 months ago) by greg
Changes since 3.19: +29 -1 lines
Diff to previous 3.19 , to selected 3.21
Fri Jun 1 16:38:37 2018 UTC (7 years, 7 months ago) by greg
Changes since 3.18: +2 -2 lines
Diff to previous 3.18 , to selected 3.21
Fixed compiling under Darwin (OS X)
Wed May 30 14:14:56 2018 UTC (7 years, 7 months ago) by greg
Changes since 3.17: +4 -2 lines
Diff to previous 3.17 , to selected 3.21
Avoid declaration complaints in OS X
Fri May 4 21:22:44 2018 UTC (7 years, 8 months ago) by greg
Changes since 3.16: +4 -1 lines
Diff to previous 3.16 , to selected 3.21
Added compatible declarations for strlcpy() and strlcat()
Tue Apr 10 23:38:40 2018 UTC (7 years, 8 months ago) by greg
Changes since 3.15: +5 -1 lines
Diff to previous 3.15 , to selected 3.21
Made reading uncompressed scanlines a bit faster
Tue Mar 20 18:45:04 2018 UTC (7 years, 9 months ago) by greg
Changes since 3.14: +5 -1 lines
Diff to previous 3.14 , to selected 3.21
Added missing rtio.h include to redefine getc, putc, etc.
Tue Dec 13 18:38:35 2016 UTC (9 years ago) by greg
Changes since 3.13: +2 -1 lines
Diff to previous 3.13 , to selected 3.21
Added missing extern variable declarations
Thu Aug 18 00:52:48 2016 UTC (9 years, 4 months ago) by greg
Changes since 3.12: +3 -3 lines
Diff to previous 3.12 , to selected 3.21
Mon Mar 21 19:06:08 2016 UTC (9 years, 9 months ago) by greg
Changes since 3.11: +3 -3 lines
Diff to previous 3.11 , to selected 3.21
Thu Mar 3 22:09:59 2016 UTC (9 years, 10 months ago) by greg
Changes since 3.10: +8 -1 lines
Diff to previous 3.10 , to selected 3.21
Moved putc and getc overrides to rtio.h
Thu Mar 3 22:06:18 2016 UTC (9 years, 10 months ago) by greg
Changes since 3.9: +4 -2 lines
Diff to previous 3.9 , to selected 3.21
Added fread() and fwrite() replacements
Sat Dec 23 17:27:45 2006 UTC (19 years ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Changes since 3.8: +5 -1 lines
Diff to previous 3.8 , to selected 3.21
Sun Mar 28 20:33:12 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 3.7: +2 -2 lines
Diff to previous 3.7 , to selected 3.21
Thu Feb 12 18:55:50 2004 UTC (21 years, 10 months ago) by greg
Diff to previous 3.6 , to selected 3.21
Fri Nov 14 17:22:06 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 3.5: +3 -11 lines
Diff to previous 3.5 , to selected 3.21
Mon Oct 27 10:19:31 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 3.4: +3 -1 lines
Diff to previous 3.4 , to selected 3.21
Mon Oct 20 16:01:55 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.3: +1 -4 lines
Diff to previous 3.3 , to selected 3.21
Mon Jul 14 22:23:59 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 3.2: +5 -4 lines
Diff to previous 3.2 , to selected 3.21
Mon Jun 30 14:59:11 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 3.1: +2 -6 lines
Diff to previous 3.1 , to selected 3.21
Fri Jun 27 06:53:21 2003 UTC (22 years, 6 months ago) by greg
Diff to selected 3.21
