root/radiance/ray/src/common/rtio.h
Thu Nov 7 23:20:28 2019 UTC (5 years, 6 months ago) by greg
Changes since 3.22: +3 -1 lines
Diff to previous 3.22
Wed Aug 14 18:20:02 2019 UTC (5 years, 9 months ago) by greg
Changes since 3.21: +4 -1 lines
Diff to previous 3.21
Fri Aug 9 23:34:39 2019 UTC (5 years, 9 months ago) by greg
Changes since 3.20: +3 -1 lines
Diff to previous 3.20
Added retrofit for macOS Sierra+
Fri Jul 19 17:37:56 2019 UTC (5 years, 10 months ago) by greg
Changes since 3.19: +29 -1 lines
Diff to previous 3.19
Fri Jun 1 16:38:37 2018 UTC (7 years ago) by greg
Changes since 3.18: +2 -2 lines
Diff to previous 3.18
Fixed compiling under Darwin (OS X)
Wed May 30 14:14:56 2018 UTC (7 years ago) by greg
Changes since 3.17: +4 -2 lines
Diff to previous 3.17
Avoid declaration complaints in OS X
Fri May 4 21:22:44 2018 UTC (7 years ago) by greg
Changes since 3.16: +4 -1 lines
Diff to previous 3.16
Added compatible declarations for strlcpy() and strlcat()
Tue Apr 10 23:38:40 2018 UTC (7 years, 1 month ago) by greg
Changes since 3.15: +5 -1 lines
Diff to previous 3.15
Made reading uncompressed scanlines a bit faster
Tue Mar 20 18:45:04 2018 UTC (7 years, 2 months ago) by greg
Changes since 3.14: +5 -1 lines
Diff to previous 3.14
Added missing rtio.h include to redefine getc, putc, etc.
Tue Dec 13 18:38:35 2016 UTC (8 years, 5 months ago) by greg
Changes since 3.13: +2 -1 lines
Diff to previous 3.13
Added missing extern variable declarations
Thu Aug 18 00:52:48 2016 UTC (8 years, 9 months ago) by greg
Changes since 3.12: +3 -3 lines
Diff to previous 3.12
Mon Mar 21 19:06:08 2016 UTC (9 years, 2 months ago) by greg
Changes since 3.11: +3 -3 lines
Diff to previous 3.11
Thu Mar 3 22:09:59 2016 UTC (9 years, 2 months ago) by greg
Changes since 3.10: +8 -1 lines
Diff to previous 3.10
Moved putc and getc overrides to rtio.h
Thu Mar 3 22:06:18 2016 UTC (9 years, 2 months ago) by greg
Changes since 3.9: +4 -2 lines
Diff to previous 3.9
Added fread() and fwrite() replacements
Sat Dec 23 17:27:45 2006 UTC (18 years, 5 months ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Changes since 3.8: +5 -1 lines
Diff to previous 3.8
Sun Mar 28 20:33:12 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 3.7: +2 -2 lines
Diff to previous 3.7
Thu Feb 12 18:55:50 2004 UTC (21 years, 3 months ago) by greg
Diff to previous 3.6
Fri Nov 14 17:22:06 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 3.5: +3 -11 lines
Diff to previous 3.5
Mon Oct 27 10:19:31 2003 UTC (21 years, 7 months ago) by schorsch
Changes since 3.4: +3 -1 lines
Diff to previous 3.4
Mon Oct 20 16:01:55 2003 UTC (21 years, 7 months ago) by greg
Changes since 3.3: +1 -4 lines
Diff to previous 3.3
Mon Jul 14 22:23:59 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 3.2: +5 -4 lines
Mon Jun 30 14:59:11 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 3.1: +2 -6 lines
Fri Jun 27 06:53:21 2003 UTC (21 years, 11 months ago) by greg
