root/Development/ray/src/common/rtio.h
Revision: 3.19
Committed: Fri Jun 1 16:38:37 2018 UTC (7 years, 7 months ago) by greg
Changes since 3.18: +2 -2 lines
Fixed compiling under Darwin (OS X)
1 /* RCSid $Id: rtio.h,v 3.18 2018/05/30 14:14:56 greg Exp $ */
2 /*
3 * Radiance i/o and string routines
4 */
5
6 #ifndef _RAD_RTIO_H_
7 #define _RAD_RTIO_H_
8
9 #include <stdio.h>
10 #include <sys/types.h>
11 #include <fcntl.h>
12 #include <string.h>
13
14 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
15 #undef getc
16 #undef getchar
17 #undef putc
18 #undef putchar
19 #undef feof
20 #undef ferror
21 #define getc getc_unlocked
22 #define getchar getchar_unlocked
23 #define putc putc_unlocked
24 #define putchar putchar_unlocked
25 #define feof feof_unlocked
26 #define ferror ferror_unlocked
27 #endif
28
29 #ifdef __cplusplus
30 extern "C" {
31 #endif
32 /* defined in badarg.c */
33 extern int badarg(int ac, char **av, char *fl);
34 /* defined in expandarg.c */
35 extern int envexpchr, filexpchr;
36 extern int expandarg(int *acp, char ***avp, int n);
37 /* defined in fdate.c */
38 extern time_t fdate(char *fname);
39 extern int setfdate(char *fname, long ftim);
40 /* defined in fgetline.c */
41 extern char *fgetline(char *s, int n, FILE *fp);
42 /* defined in fgetval.c */
43 extern int fgetval(FILE *fp, int ty, void *vp);
44 /* defined in fgetword.c */
45 extern char *fgetword(char *s, int n, FILE *fp);
46 /* defined in fputword.c */
47 extern void fputword(char *s, FILE *fp);
48 /* defined in fropen.c */
49 extern FILE *frlibopen(char *fname);
50 /* defined in getlibpath.c */
51 extern char *getrlibpath(void);
52 /* defined in gethomedir.c */
53 extern char *gethomedir(char *uname, char *path, int plen);
54 /* defined in getpath.c */
55 extern char *getpath(char *fname, char *searchpath, int mode);
56 /* defined in byteswap.c */
57 extern void swap16(char *wp, int n);
58 extern void swap32(char *wp, int n);
59 extern void swap64(char *wp, int n);
60 /* defined in portio.c */
61 extern void putstr(char *s, FILE *fp);
62 extern void putint(long i, int siz, FILE *fp);
63 extern void putflt(double f, FILE *fp);
64 extern int putbinary(const void *s, int elsiz, int nel, FILE *fp);
65 extern char *getstr(char *s, FILE *fp);
66 extern long getint(int siz, FILE *fp);
67 extern double getflt(FILE *fp);
68 extern int getbinary(void *s, int elsiz, int nel, FILE *fp);
69 /* defined in rexpr.c */
70 extern int ecompile(char *sp, int iflg, int wflag);
71 extern char *expsave(void);
72 extern void expset(char *ep);
73 extern char *eindex(char *sp);
74 /* defined in savestr.c */
75 extern char *savestr(char *str);
76 extern void freestr(char *s);
77 extern int shash(char *s);
78 /* defined in savqstr.c */
79 extern char *savqstr(char *s);
80 extern void freeqstr(char *s);
81 /* defined in wordfile.c */
82 extern int wordfile(char **words, int nargs, char *fname);
83 extern int wordstring(char **avl, int nargs, char *str);
84 /* defined in words.c */
85 extern char *atos(char *rs, int nb, char *s);
86 extern char *nextword(char *cp, int nb, char *s);
87 extern char *sskip(char *s);
88 extern char *sskip2(char *s, int n);
89 extern char *iskip(char *s);
90 extern char *fskip(char *s);
91 extern int isint(char *s);
92 extern int isintd(char *s, char *ds);
93 extern int isflt(char *s);
94 extern int isfltd(char *s, char *ds);
95 /* defined in lamp.c */
96 extern float * matchlamp(char *s);
97 extern int loadlamps(char *file);
98 extern void freelamps(void);
99
100 #ifndef strlcpy /* defined in option strlcpy.c */
101 extern size_t strlcpy(char *dst, const char *src, size_t siz);
102 extern size_t strlcat(char *dst, const char *src, size_t siz);
103 #endif
104
105 #ifdef __cplusplus
106 }
107 #endif
108 #endif /* _RAD_RTIO_H_ */
109
