root/radiance/ray/src/common/rtio.h
Revision: 3.6
Committed: Fri Nov 14 17:22:06 2003 UTC (21 years, 8 months ago) by schorsch
Changes since 3.5: +3 -11 lines
1 /* RCSid $Id: rtio.h,v 3.5 2003/10/27 10:19:31 schorsch Exp $ */
2 /*
3 * Radiance i/o and string routines
4 */
5
6 #ifndef _RAD_RTIO_H_
7 #define _RAD_RTIO_H_
8
9 #include <stdio.h>
10 #include <sys/types.h>
11 #include <fcntl.h>
12 #include <string.h>
13
14 #include "paths.h"
15
16 #ifdef __cplusplus
17 extern "C" {
18 #endif
19
20 /* defined in badarg.c */
21 extern int badarg(int ac, char **av, char *fl);
22 /* defined in expandarg.c */
23 extern int expandarg(int *acp, char ***avp, int n);
24 /* defined in fdate.c */
25 extern time_t fdate(char *fname);
26 extern int setfdate(char *fname, long ftim);
27 /* defined in fgetline.c */
28 extern char *fgetline(char *s, int n, FILE *fp);
29 /* defined in fgetval.c */
30 extern int fgetval(FILE *fp, int ty, char *vp);
31 /* defined in fgetword.c */
32 extern char *fgetword(char *s, int n, FILE *fp);
33 /* defined in fputword.c */
34 extern void fputword(char *s, FILE *fp);
35 /* defined in fropen.c */
36 extern FILE *frlibopen(char *fname);
37 /* defined in getlibpath.c */
38 extern char *getrlibpath(void);
39 /* defined in gethomedir.c */
40 extern char *gethomedir(char *uname, char *path, int plen);
41 /* defined in getpath.c */
42 extern char *getpath(char *fname, char *searchpath, int mode);
43 /* defined in portio.c */
44 extern void putstr(char *s, FILE *fp);
45 extern void putint(long i, int siz, FILE *fp);
46 extern void putflt(double f, FILE *fp);
47 extern char *getstr(char *s, FILE *fp);
48 extern long getint(int siz, FILE *fp);
49 extern double getflt(FILE *fp);
50 /* defined in rexpr.c */
51 extern int ecompile(char *sp, int iflg, int wflag);
52 extern char *expsave(void);
53 extern void expset(char *ep);
54 extern char *eindex(char *sp);
55 /* defined in savestr.c */
56 extern char *savestr(char *str);
57 extern void freestr(char *s);
58 extern int shash(char *s);
59 /* defined in savqstr.c */
60 extern char *savqstr(char *s);
61 extern void freeqstr(char *s);
62 /* defined in wordfile.c */
63 extern int wordfile(char **words, char *fname);
64 extern int wordstring(char **avl, char *str);
65 /* defined in words.c */
66 extern char *atos(char *rs, int nb, char *s);
67 extern char *nextword(char *cp, int nb, char *s);
68 extern char *sskip(char *s);
69 extern char *sskip2(char *s, int n);
70 extern char *iskip(char *s);
71 extern char *fskip(char *s);
72 extern int isint(char *s);
73 extern int isintd(char *s, char *ds);
74 extern int isflt(char *s);
75 extern int isfltd(char *s, char *ds);
76 /* defined in lamp.c */
77 extern float * matchlamp(char *s);
78 extern int loadlamps(char *file);
79 extern void freelamps(void);
80
81 #ifdef __cplusplus
82 }
83 #endif
84 #endif /* _RAD_RTIO_H_ */
85
