root/radiance/ray/src/common/rtio.h
Fri Jun 1 16:38:37 2018 UTC (6 years ago) by greg
Changes since 3.18: +2 -2 lines
Diff to previous 3.18 , to selected 3.7
Fixed compiling under Darwin (OS X)
Wed May 30 14:14:56 2018 UTC (6 years ago) by greg
Changes since 3.17: +4 -2 lines
Diff to previous 3.17 , to selected 3.7
Avoid declaration complaints in OS X
Fri May 4 21:22:44 2018 UTC (6 years ago) by greg
Changes since 3.16: +4 -1 lines
Diff to previous 3.16 , to selected 3.7
Added compatible declarations for strlcpy() and strlcat()
Tue Apr 10 23:38:40 2018 UTC (6 years, 1 month ago) by greg
Changes since 3.15: +5 -1 lines
Diff to previous 3.15 , to selected 3.7
Made reading uncompressed scanlines a bit faster
Tue Mar 20 18:45:04 2018 UTC (6 years, 2 months ago) by greg
Changes since 3.14: +5 -1 lines
Diff to previous 3.14 , to selected 3.7
Added missing rtio.h include to redefine getc, putc, etc.
Tue Dec 13 18:38:35 2016 UTC (7 years, 5 months ago) by greg
Changes since 3.13: +2 -1 lines
Diff to previous 3.13 , to selected 3.7
Added missing extern variable declarations
Thu Aug 18 00:52:48 2016 UTC (7 years, 9 months ago) by greg
Changes since 3.12: +3 -3 lines
Diff to previous 3.12 , to selected 3.7
Mon Mar 21 19:06:08 2016 UTC (8 years, 2 months ago) by greg
Changes since 3.11: +3 -3 lines
Diff to previous 3.11 , to selected 3.7
Thu Mar 3 22:09:59 2016 UTC (8 years, 2 months ago) by greg
Changes since 3.10: +8 -1 lines
Diff to previous 3.10 , to selected 3.7
Moved putc and getc overrides to rtio.h
Thu Mar 3 22:06:18 2016 UTC (8 years, 2 months ago) by greg
Changes since 3.9: +4 -2 lines
Diff to previous 3.9 , to selected 3.7
Added fread() and fwrite() replacements
Sat Dec 23 17:27:45 2006 UTC (17 years, 5 months ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Changes since 3.8: +5 -1 lines
Diff to previous 3.8 , to selected 3.7
Changes since 3.7: +2 -2 lines
Diff to previous 3.7
Revision 3.7 - (view) (download) (annotate) - [selected]
Thu Feb 12 18:55:50 2004 UTC (20 years, 3 months ago) by greg
Diff to previous 3.6
Changes since 3.5: +3 -11 lines
Diff to previous 3.5 , to selected 3.7
Mon Oct 27 10:19:31 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 3.4: +3 -1 lines
Diff to previous 3.4 , to selected 3.7
Changes since 3.3: +1 -4 lines
Diff to previous 3.3 , to selected 3.7
Mon Jul 14 22:23:59 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 3.2: +5 -4 lines
Diff to previous 3.2 , to selected 3.7
Changes since 3.1: +2 -6 lines
Diff to previous 3.1 , to selected 3.7
Diff to selected 3.7
