root/radiance/ray/src/common/rtio.h
Revision: 3.4
Committed: Mon Oct 20 16:01:55 2003 UTC (20 years, 8 months ago) by greg
Changes since 3.3: +1 -4 lines
1 /* RCSid $Id: rtio.h,v 3.3 2003/07/14 22:23:59 schorsch Exp $ */
2 /*
3 * Radiance i/o and string routines
4 */
5
6 #ifndef _RAD_RTIO_H_
7 #define _RAD_RTIO_H_
8
9 #include <stdio.h>
10 #include <sys/types.h>
11 #include <fcntl.h>
12 #include <string.h>
13
14 #ifdef __cplusplus
15 extern "C" {
16 #endif
17
18 /* XXX include paths.h instead */
19 #ifndef F_OK /* mode bits for access(2) call */
20 #define R_OK 4 /* readable */
21 #define W_OK 2 /* writable */
22 #define X_OK 1 /* executable */
23 #define F_OK 0 /* exists */
24 #endif
25
26 /* defined in badarg.c */
27 extern int badarg(int ac, char **av, char *fl);
28 /* defined in expandarg.c */
29 extern int expandarg(int *acp, char ***avp, int n);
30 /* defined in fdate.c */
31 extern time_t fdate(char *fname);
32 extern int setfdate(char *fname, long ftim);
33 /* defined in fgetline.c */
34 extern char *fgetline(char *s, int n, FILE *fp);
35 /* defined in fgetval.c */
36 extern int fgetval(FILE *fp, int ty, char *vp);
37 /* defined in fgetword.c */
38 extern char *fgetword(char *s, int n, FILE *fp);
39 /* defined in fputword.c */
40 extern void fputword(char *s, FILE *fp);
41 /* defined in fixargv0.c */
42 /*extern char *fixargv0(char *av0);*/ /* XXX include paths.h instead */
43 /* defined in fropen.c */
44 extern FILE *frlibopen(char *fname);
45 /* defined in getlibpath.c */
46 extern char *getrlibpath(void);
47 /* defined in getpath.c */
48 extern char *getpath(char *fname, char *searchpath, int mode);
49 /* defined in portio.c */
50 extern void putstr(char *s, FILE *fp);
51 extern void putint(long i, int siz, FILE *fp);
52 extern void putflt(double f, FILE *fp);
53 extern char *getstr(char *s, FILE *fp);
54 extern long getint(int siz, FILE *fp);
55 extern double getflt(FILE *fp);
56 /* defined in rexpr.c */
57 extern int ecompile(char *sp, int iflg, int wflag);
58 extern char *expsave(void);
59 extern void expset(char *ep);
60 extern char *eindex(char *sp);
61 /* defined in savestr.c */
62 extern char *savestr(char *str);
63 extern void freestr(char *s);
64 extern int shash(char *s);
65 /* defined in savqstr.c */
66 extern char *savqstr(char *s);
67 extern void freeqstr(char *s);
68 /* defined in wordfile.c */
69 extern int wordfile(char **words, char *fname);
70 extern int wordstring(char **avl, char *str);
71 /* defined in words.c */
72 extern char *atos(char *rs, int nb, char *s);
73 extern char *nextword(char *cp, int nb, char *s);
74 extern char *sskip(char *s);
75 extern char *sskip2(char *s, int n);
76 extern char *iskip(char *s);
77 extern char *fskip(char *s);
78 extern int isint(char *s);
79 extern int isintd(char *s, char *ds);
80 extern int isflt(char *s);
81 extern int isfltd(char *s, char *ds);
82 /* defined in lamp.c */
83 extern float * matchlamp(char *s);
84 extern int loadlamps(char *file);
85 extern void freelamps(void);
86
87 #ifdef __cplusplus
88 }
89 #endif
90 #endif /* _RAD_RTIO_H_ */
91
