--- ray/src/common/rtio.h 2003/10/20 16:01:55 3.4 +++ ray/src/common/rtio.h 2004/02/12 18:55:50 3.7 @@ -1,4 +1,4 @@ -/* RCSid $Id: rtio.h,v 3.4 2003/10/20 16:01:55 greg Exp $ */ +/* RCSid $Id: rtio.h,v 3.7 2004/02/12 18:55:50 greg Exp $ */ /* * Radiance i/o and string routines */ @@ -14,15 +14,6 @@ #ifdef __cplusplus extern "C" { #endif - -/* XXX include paths.h instead */ -#ifndef F_OK /* mode bits for access(2) call */ -#define R_OK 4 /* readable */ -#define W_OK 2 /* writable */ -#define X_OK 1 /* executable */ -#define F_OK 0 /* exists */ -#endif - /* defined in badarg.c */ extern int badarg(int ac, char **av, char *fl); /* defined in expandarg.c */ @@ -38,12 +29,12 @@ extern int fgetval(FILE *fp, int ty, char *vp); extern char *fgetword(char *s, int n, FILE *fp); /* defined in fputword.c */ extern void fputword(char *s, FILE *fp); - /* defined in fixargv0.c */ -/*extern char *fixargv0(char *av0);*/ /* XXX include paths.h instead */ /* defined in fropen.c */ extern FILE *frlibopen(char *fname); /* defined in getlibpath.c */ extern char *getrlibpath(void); + /* defined in gethomedir.c */ +extern char *gethomedir(char *uname, char *path, int plen); /* defined in getpath.c */ extern char *getpath(char *fname, char *searchpath, int mode); /* defined in portio.c */
