refactor: Removed unnecessary parens
fix: passing const char * to savestr() and shash()
feat: Added fddate() call to get modification time from open file
fix: moved #undef's to where they belonged
feat: added output stream error-checking to putstr(), putint(), and putflt()
More 64-bit addressing fixes
Added retrofit for macOS Sierra+
Fixed compiling under Darwin (OS X)
Avoid declaration complaints in OS X
Added compatible declarations for strlcpy() and strlcat()
Made reading uncompressed scanlines a bit faster
Added missing rtio.h include to redefine getc, putc, etc.
Added missing extern variable declarations
Moved putc and getc overrides to rtio.h
Added fread() and fwrite() replacements
Instrumented headers against multiple inclusion and for use from C++. Moved includes in headers out of "C" scope.
