root/radiance/ray/src/common/rtio.h
Fri Dec 15 03:42:31 2023 UTC (5 months, 2 weeks ago) by greg
Changes since 3.29: +4 -4 lines
Diff to previous 3.29
refactor: Removed unnecessary parens
Thu Jun 8 17:48:01 2023 UTC (11 months, 3 weeks ago) by greg
Changes since 3.28: +3 -3 lines
Diff to previous 3.28
fix: passing const char * to savestr() and shash()
Fri Feb 10 18:29:46 2023 UTC (15 months, 3 weeks ago) by greg
Changes since 3.27: +4 -3 lines
Diff to previous 3.27
feat: Added fddate() call to get modification time from open file
Mon Feb 6 22:40:21 2023 UTC (15 months, 3 weeks ago) by greg
Changes since 3.26: +2 -2 lines
Diff to previous 3.26
Sat Feb 4 17:24:30 2023 UTC (15 months, 4 weeks ago) by greg
Changes since 3.25: +3 -3 lines
Diff to previous 3.25
fix: moved #undef's to where they belonged
Fri Feb 19 16:15:23 2021 UTC (3 years, 3 months ago) by greg
Changes since 3.24: +4 -4 lines
Diff to previous 3.24
feat: added output stream error-checking to putstr(), putint(), and putflt()
Fri Jan 15 18:31:38 2021 UTC (3 years, 4 months ago) by greg
Changes since 3.23: +6 -6 lines
Diff to previous 3.23
More 64-bit addressing fixes
Thu Nov 7 23:20:28 2019 UTC (4 years, 6 months ago) by greg
Changes since 3.22: +3 -1 lines
Diff to previous 3.22
Wed Aug 14 18:20:02 2019 UTC (4 years, 9 months ago) by greg
Changes since 3.21: +4 -1 lines
Diff to previous 3.21
Fri Aug 9 23:34:39 2019 UTC (4 years, 9 months ago) by greg
Changes since 3.20: +3 -1 lines
Diff to previous 3.20
Added retrofit for macOS Sierra+
Fri Jul 19 17:37:56 2019 UTC (4 years, 10 months ago) by greg
Changes since 3.19: +29 -1 lines
Diff to previous 3.19
Fri Jun 1 16:38:37 2018 UTC (6 years ago) by greg
Changes since 3.18: +2 -2 lines
Diff to previous 3.18
Fixed compiling under Darwin (OS X)
Wed May 30 14:14:56 2018 UTC (6 years ago) by greg
Changes since 3.17: +4 -2 lines
Diff to previous 3.17
Avoid declaration complaints in OS X
Fri May 4 21:22:44 2018 UTC (6 years, 1 month ago) by greg
Changes since 3.16: +4 -1 lines
Diff to previous 3.16
Added compatible declarations for strlcpy() and strlcat()
Tue Apr 10 23:38:40 2018 UTC (6 years, 1 month ago) by greg
Changes since 3.15: +5 -1 lines
Diff to previous 3.15
Made reading uncompressed scanlines a bit faster
Tue Mar 20 18:45:04 2018 UTC (6 years, 2 months ago) by greg
Changes since 3.14: +5 -1 lines
Diff to previous 3.14
Added missing rtio.h include to redefine getc, putc, etc.
Tue Dec 13 18:38:35 2016 UTC (7 years, 5 months ago) by greg
Changes since 3.13: +2 -1 lines
Diff to previous 3.13
Added missing extern variable declarations
Thu Aug 18 00:52:48 2016 UTC (7 years, 9 months ago) by greg
Changes since 3.12: +3 -3 lines
Diff to previous 3.12
Mon Mar 21 19:06:08 2016 UTC (8 years, 2 months ago) by greg
Changes since 3.11: +3 -3 lines
Diff to previous 3.11
Thu Mar 3 22:09:59 2016 UTC (8 years, 3 months ago) by greg
Changes since 3.10: +8 -1 lines
Diff to previous 3.10
Moved putc and getc overrides to rtio.h
Thu Mar 3 22:06:18 2016 UTC (8 years, 3 months ago) by greg
Changes since 3.9: +4 -2 lines
Diff to previous 3.9
Added fread() and fwrite() replacements
Sat Dec 23 17:27:45 2006 UTC (17 years, 5 months ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Changes since 3.8: +5 -1 lines
Diff to previous 3.8
Changes since 3.7: +2 -2 lines
Diff to previous 3.7
Thu Feb 12 18:55:50 2004 UTC (20 years, 3 months ago) by greg
Diff to previous 3.6
Changes since 3.5: +3 -11 lines
Diff to previous 3.5
Mon Oct 27 10:19:31 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 3.4: +3 -1 lines
Diff to previous 3.4
Changes since 3.3: +1 -4 lines
Diff to previous 3.3
Mon Jul 14 22:23:59 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 3.2: +5 -4 lines
Changes since 3.1: +2 -6 lines
