root/radiance/ray/src/common/rtio.h
Revision: 3.2
Committed: Mon Jun 30 14:59:11 2003 UTC (22 years ago) by schorsch
Changes since 3.1: +2 -6 lines
1 /* RCSid $Id: rtio.h,v 3.1 2003/06/27 06:53:21 greg Exp $ */
2 /*
3 * Radiance i/o and string routines
4 */
5
6 #ifndef _RAD_RTIO_H_
7 #define _RAD_RTIO_H_
8 #ifdef __cplusplus
9 extern "C" {
10 #endif
11
12 #include <stdio.h>
13 #include <sys/types.h>
14 #include <fcntl.h>
15 #include <string.h>
16
17 /* XXX include paths.h instead */
18 #ifndef F_OK /* mode bits for access(2) call */
19 #define R_OK 4 /* readable */
20 #define W_OK 2 /* writable */
21 #define X_OK 1 /* executable */
22 #define F_OK 0 /* exists */
23 #endif
24
25 /* <unistd.h> is missing on some systems */
26 extern off_t lseek(int, off_t, int);
27
28 /* defined in badarg.c */
29 extern int badarg(int ac, char **av, char *fl);
30 /* defined in expandarg.c */
31 extern int expandarg(int *acp, char ***avp, int n);
32 /* defined in fdate.c */
33 extern time_t fdate(char *fname);
34 extern int setfdate(char *fname, long ftim);
35 /* defined in fgetline.c */
36 extern char *fgetline(char *s, int n, FILE *fp);
37 /* defined in fgetval.c */
38 extern int fgetval(FILE *fp, int ty, char *vp);
39 /* defined in fgetword.c */
40 extern char *fgetword(char *s, int n, FILE *fp);
41 /* defined in fputword.c */
42 extern void fputword(char *s, FILE *fp);
43 /* defined in fixargv0.c */
44 /*extern char *fixargv0(char *av0);*/ /* XXX include paths.h instead */
45 /* defined in fropen.c */
46 extern FILE *frlibopen(char *fname);
47 /* defined in getlibpath.c */
48 extern char *getrlibpath(void);
49 /* defined in getpath.c */
50 extern char *getpath(char *fname, char *searchpath, int mode);
51 /* defined in portio.c */
52 extern void putstr(char *s, FILE *fp);
53 extern void putint(long i, int siz, FILE *fp);
54 extern void putflt(double f, FILE *fp);
55 extern char *getstr(char *s, FILE *fp);
56 extern long getint(int siz, FILE *fp);
57 extern double getflt(FILE *fp);
58 /* defined in rexpr.c */
59 extern int ecompile(char *sp, int iflg, int wflag);
60 extern char *expsave(void);
61 extern void expset(char *ep);
62 extern char *eindex(char *sp);
63 /* defined in savestr.c */
64 extern char *savestr(char *str);
65 extern void freestr(char *s);
66 extern int shash(char *s);
67 /* defined in savqstr.c */
68 extern char *savqstr(char *s);
69 extern void freeqstr(char *s);
70 /* defined in wordfile.c */
71 extern int wordfile(char **words, char *fname);
72 extern int wordstring(char **avl, char *str);
73 /* defined in words.c */
74 extern char *atos(char *rs, int nb, char *s);
75 extern char *nextword(char *cp, int nb, char *s);
76 extern char *sskip(char *s);
77 extern char *sskip2(char *s, int n);
78 extern char *iskip(char *s);
79 extern char *fskip(char *s);
80 extern int isint(char *s);
81 extern int isintd(char *s, char *ds);
82 extern int isflt(char *s);
83 extern int isfltd(char *s, char *ds);
84 /* defined in lamp.c */
85 extern float * matchlamp(char *s);
86 extern int loadlamps(char *file);
87 extern void freelamps(void);
88
89 #ifdef __cplusplus
90 }
91 #endif
92 #endif /* _RAD_RTIO_H_ */
93
