root/radiance/ray/src/common/rterror.h
Revision: 3.3
Committed: Mon May 8 16:58:52 2017 UTC (7 years ago) by greg
CVS Tags: rad5R2, rad5R1, rad5R3
ANSIfication needs pointed out by Nathaniel Jones
# User Rev Content
1 greg 3.3 /* RCSid $Id: rterror.h,v 3.2 2003/07/14 22:23:59 schorsch Exp $ */
2 greg 3.1 /*
3     * Header for Radiance error-handling routines
4     */
5
6     #ifndef _RAD_RTERROR_H_
7     #define _RAD_RTERROR_H_
8 schorsch 3.2
9     #include <errno.h>
10
11 greg 3.1 #ifdef __cplusplus
12     extern "C" {
13     #endif
14
15     /* error codes */
16     #define WARNING 0 /* non-fatal error */
17     #define USER 1 /* fatal user-caused error */
18     #define SYSTEM 2 /* fatal system-related error */
19     #define INTERNAL 3 /* fatal program-related error */
20     #define CONSISTENCY 4 /* bad consistency check, abort */
21     #define COMMAND 5 /* interactive error */
22     #define NERRS 6
23     /* error struct */
24     extern struct erract {
25     char pre[16]; /* prefix message */
26 greg 3.3 void (*pf)(char *s); /* put function (resettable) */
27 greg 3.1 int ec; /* exit code (0 means non-fatal) */
28     } erract[NERRS]; /* list of error actions */
29
30     #define ERRACT_INIT { {"warning - ", wputs, 0}, \
31     {"fatal - ", eputs, 1}, \
32     {"system - ", eputs, 2}, \
33     {"internal - ", eputs, 3}, \
34     {"consistency - ", eputs, -1}, \
35     {"", NULL, 0} }
36
37     extern char errmsg[]; /* global buffer for error messages */
38
39     /* custom version of assert(3) */
40     #define CHECK(be,et,em) if (be) error(et,em); else
41     #ifdef DEBUG
42     #define DCHECK CHECK
43     #else
44     #define DCHECK(be,et,em) (void)0
45     #endif
46     /* defined in error.c */
47     extern void error(int etype, char *emsg);
48     /* error & warning output & exit */
49     extern void eputs(char *s);
50     extern void wputs(char *s);
51     extern void quit(int code);
52
53     #ifdef __cplusplus
54     }
55     #endif
56     #endif /* _RAD_RTERROR_H_ */
57
