| 1 |
/* RCSid $Id: rterror.h,v 3.2 2003/07/14 22:23:59 schorsch Exp $ */
| 2 |
| 3 |
* Header for Radiance error-handling routines
| 4 |
| 5 |
| 6 |
#ifndef _RAD_RTERROR_H_
| 7 |
#define _RAD_RTERROR_H_
| 8 |
| 9 |
#include <errno.h>
| 10 |
| 11 |
#ifdef __cplusplus
| 12 |
extern "C" {
| 13 |
#endif
| 14 |
| 15 |
/* error codes */
| 16 |
#define WARNING 0 /* non-fatal error */
| 17 |
#define USER 1 /* fatal user-caused error */
| 18 |
#define SYSTEM 2 /* fatal system-related error */
| 19 |
#define INTERNAL 3 /* fatal program-related error */
| 20 |
#define CONSISTENCY 4 /* bad consistency check, abort */
| 21 |
#define COMMAND 5 /* interactive error */
| 22 |
#define NERRS 6
| 23 |
/* error struct */
| 24 |
extern struct erract {
| 25 |
char pre[16]; /* prefix message */
| 26 |
void (*pf)(char *s); /* put function (resettable) */
| 27 |
int ec; /* exit code (0 means non-fatal) */
| 28 |
} erract[NERRS]; /* list of error actions */
| 29 |
| 30 |
#define ERRACT_INIT { {"warning - ", wputs, 0}, \
| 31 |
{"fatal - ", eputs, 1}, \
| 32 |
{"system - ", eputs, 2}, \
| 33 |
{"internal - ", eputs, 3}, \
| 34 |
{"consistency - ", eputs, -1}, \
| 35 |
{"", NULL, 0} }
| 36 |
| 37 |
extern char errmsg[]; /* global buffer for error messages */
| 38 |
| 39 |
/* custom version of assert(3) */
| 40 |
#define CHECK(be,et,em) if (be) error(et,em); else
| 41 |
#ifdef DEBUG
| 42 |
#define DCHECK CHECK
| 43 |
#else
| 44 |
#define DCHECK(be,et,em) (void)0
| 45 |
#endif
| 46 |
/* defined in error.c */
| 47 |
extern void error(int etype, char *emsg);
| 48 |
/* error & warning output & exit */
| 49 |
extern void eputs(char *s);
| 50 |
extern void wputs(char *s);
| 51 |
extern void quit(int code);
| 52 |
| 53 |
#ifdef __cplusplus
| 54 |
| 55 |
#endif
| 56 |
#endif /* _RAD_RTERROR_H_ */
| 57 |
