root/Development/ray/src/common/rglsurf.c
Wed Apr 25 22:21:06 2012 UTC (13 years, 6 months ago) by greg
CVS Tags: HEAD, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Changes since 3.12: +4 -4 lines
Diff to previous 3.12
Tue Mar 30 20:40:03 2004 UTC (21 years, 7 months ago) by greg
Changes since 3.11: +5 -5 lines
Diff to previous 3.11
Fri Nov 14 17:22:06 2003 UTC (22 years ago) by schorsch
Changes since 3.10: +10 -9 lines
Diff to previous 3.10
Thu Jul 17 09:21:29 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 3.9: +3 -3 lines
Diff to previous 3.9
Sun May 25 15:41:31 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.8: +6 -6 lines
Diff to previous 3.8
Fixed another bug pointed out by Thoms Bleicher, but this isn't it, either
Sun May 25 06:09:44 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.7: +14 -6 lines
Diff to previous 3.7
Fixed bug in cylinder rotation, but not the one causing all the problems
Wed Apr 23 02:28:06 2003 UTC (22 years, 6 months ago) by greg
Changes since 3.6: +6 -2 lines
Diff to previous 3.6
Added check for mesh primitive and warning when encountered
Thu Mar 27 04:16:33 2003 UTC (22 years, 7 months ago) by greg
Diff to previous 3.5
Portability fixes immediately following 3.5 release
Tue Feb 25 02:47:22 2003 UTC (22 years, 8 months ago) by greg
Changes since 3.4: +1 -56 lines
Diff to previous 3.4
Sat Feb 22 02:07:22 2003 UTC (22 years, 8 months ago) by greg
Changes since 3.3: +76 -16 lines
Diff to previous 3.3
Fri Dec 11 13:53:32 1998 UTC (26 years, 11 months ago) by gwlarson
Changes since 3.2: +24 -4 lines
Diff to previous 3.2
added combine callback for polygon tessellator
Wed Jun 17 16:45:08 1998 UTC (27 years, 5 months ago) by gwlarson
Changes since 3.1: +1 -4 lines
eliminated partially redundant error checks in quadric routines
Tue Jun 9 11:18:36 1998 UTC (27 years, 5 months ago) by gwlarson
