root/radiance/ray/src/common/rglsurf.c
Tue Mar 30 20:40:03 2004 UTC (20 years, 2 months ago) by greg
Changes since 3.11: +5 -5 lines
Diff to previous 3.11 , to selected 3.10
Fri Nov 14 17:22:06 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 3.10: +10 -9 lines
Diff to previous 3.10
Revision 3.10 - (view) (download) (annotate) - [selected]
Thu Jul 17 09:21:29 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 3.9: +3 -3 lines
Diff to previous 3.9
Sun May 25 15:41:31 2003 UTC (21 years, 1 month ago) by greg
Changes since 3.8: +6 -6 lines
Diff to previous 3.8 , to selected 3.10
Fixed another bug pointed out by Thoms Bleicher, but this isn't it, either
Sun May 25 06:09:44 2003 UTC (21 years, 1 month ago) by greg
Changes since 3.7: +14 -6 lines
Diff to previous 3.7 , to selected 3.10
Fixed bug in cylinder rotation, but not the one causing all the problems
Wed Apr 23 02:28:06 2003 UTC (21 years, 2 months ago) by greg
Changes since 3.6: +6 -2 lines
Diff to previous 3.6 , to selected 3.10
Added check for mesh primitive and warning when encountered
Thu Mar 27 04:16:33 2003 UTC (21 years, 3 months ago) by greg
Diff to previous 3.5 , to selected 3.10
Portability fixes immediately following 3.5 release
Changes since 3.4: +1 -56 lines
Diff to previous 3.4 , to selected 3.10
Sat Feb 22 02:07:22 2003 UTC (21 years, 4 months ago) by greg
Changes since 3.3: +76 -16 lines
Diff to previous 3.3 , to selected 3.10
Fri Dec 11 13:53:32 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.2: +24 -4 lines
Diff to previous 3.2 , to selected 3.10
added combine callback for polygon tessellator
Wed Jun 17 16:45:08 1998 UTC (26 years ago) by gwlarson
Changes since 3.1: +1 -4 lines
Diff to previous 3.1 , to selected 3.10
eliminated partially redundant error checks in quadric routines
Tue Jun 9 11:18:36 1998 UTC (26 years ago) by gwlarson
Diff to selected 3.10
