root/Development/ray/src/common/rglsrc.c
Revision: 3.6
Committed: Fri Nov 14 17:22:06 2003 UTC (22 years, 1 month ago) by schorsch
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6, HEAD
Changes since 3.5: +1 -4 lines
# User Rev Content
1 gwlarson 3.1 #ifndef lint
2 schorsch 3.6 static const char RCSid[] = "$Id: rglsrc.c,v 3.5 2003/07/17 09:21:29 schorsch Exp $";
3 gwlarson 3.1 #endif
4     /*
5     * Routines for handling OpenGL light sources
6     */
7
8 greg 3.4 #include "copyright.h"
9 greg 3.3
10 gwlarson 3.1 #include "radogl.h"
11
12     double expval = 0.; /* global exposure value */
13
14     COLOR ambval = {0.2, 0.2, 0.2}; /* global ambient value */
15
16     int dolights = MAXLIGHTS; /* do how many more light sources? */
17
18 gwlarson 3.2 int glightid[MAXLIGHTS] = {GL_LIGHT0, GL_LIGHT1, GL_LIGHT2,
19 gwlarson 3.1 GL_LIGHT3, GL_LIGHT4, GL_LIGHT5, GL_LIGHT6, GL_LIGHT7};
20
21     static int lightlist; /* light list id */
22
23     /* source types */
24     #define L_NONE 0
25     #define L_SOURCE 1
26     #define L_FLAT 2
27     #define L_SPHERE 3
28
29     static struct {
30     int type; /* light type (0 if none) */
31     MATREC *m; /* light material */
32     FVECT pos; /* light position (or direction) */
33     FVECT norm; /* flat source normal */
34     double area; /* source area (or solid angle) */
35     } lightrec[MAXLIGHTS]; /* light source list */
36
37     static int nlights; /* number of defined lights */
38
39 schorsch 3.5 static void l_flatsrc(int), l_sphsrc(int), l_source(int);
40 gwlarson 3.1
41
42 greg 3.3 void
43 gwlarson 3.1 lightinit() /* initialize lighting */
44     {
45     GLfloat ambv[4];
46
47     if (!dolights)
48     return;
49     glPushAttrib(GL_LIGHTING_BIT);
50     if (expval <= FTINY && bright(ambval) > FTINY)
51     expval = 0.2/bright(ambval);
52     ambv[0] = expval*colval(ambval,RED);
53     ambv[1] = expval*colval(ambval,GRN);
54     ambv[2] = expval*colval(ambval,BLU);
55     ambv[3] = 1.;
56     glLightModelfv(GL_LIGHT_MODEL_AMBIENT, ambv);
57     glCallList(lightlist = newglist());
58     rgl_checkerr("in lightinit");
59     nlights = 0;
60     }
61
62
63 greg 3.3 void
64 gwlarson 3.1 lightclean() /* clean up light source commands */
65     {
66     if ((dolights += nlights) <= 0)
67     return;
68     glPopAttrib();
69     }
70
71
72 greg 3.3 void
73 gwlarson 3.1 lightdefs() /* define light source list */
74     {
75     if (!nlights)
76     return;
77     glNewList(lightlist, GL_COMPILE);
78     while (nlights--) {
79     switch (lightrec[nlights].type) {
80     case L_FLAT:
81     l_flatsrc(nlights);
82     break;
83     case L_SPHERE:
84     l_sphsrc(nlights);
85     break;
86     case L_SOURCE:
87     l_source(nlights);
88     break;
89     default:
90     error(CONSISTENCY, "botched light type in lightdefs");
91     }
92     freemtl(lightrec[nlights].m);
93     lightrec[nlights].type = L_NONE;
94     }
95     glEndList();
96     rgl_checkerr("defining lights");
97     }
98
99
100 greg 3.3 int
101 gwlarson 3.1 o_source(o) /* record a distant source */
102     register OBJREC *o;
103     {
104     if (!dolights || !issrcmat((MATREC *)o->os))
105     return(0);
106     if (o->oargs.nfargs != 4)
107     objerror(o, USER, "bad # real arguments");
108     /* record type & material */
109     lightrec[nlights].type = L_SOURCE;
110     (lightrec[nlights].m = (MATREC *)o->os)->nlinks++;
111     /* assign direction */
112     VCOPY(lightrec[nlights].pos, o->oargs.farg);
113     /* compute solid angle */
114     if (o->oargs.farg[3] <= FTINY)
115     objerror(o, USER, "zero size");
116     lightrec[nlights].area = 2.*PI*(1. - cos(PI/180./2.*o->oargs.farg[3]));
117     nlights++; dolights--;
118     return(1);
119     }
120
121
122     int
123     doflatsrc(m, pos, norm, area) /* record a flat source */
124     MATREC *m;
125     FVECT pos, norm;
126     double area;
127     {
128     if (!dolights || !issrcmat(m) || area <= FTINY)
129     return(0);
130     /* record type & material */
131     lightrec[nlights].type = L_FLAT;
132     (lightrec[nlights].m = m)->nlinks++;
133     /* assign geometry */
134     VCOPY(lightrec[nlights].pos, pos);
135     VCOPY(lightrec[nlights].norm, norm);
136     lightrec[nlights].area = area;
137     nlights++; dolights--;
138     return(1);
139     }
140
141
142     int
143     dosphsrc(m, pos, area) /* record a spherical source */
144     register MATREC *m;
145     FVECT pos;
146     double area;
147     {
148     if (!dolights || !issrcmat(m) || area <= FTINY)
149     return(0);
150     /* record type & material */
151     lightrec[nlights].type = L_SPHERE;
152     (lightrec[nlights].m = m)->nlinks++;
153     /* assign geometry */
154     VCOPY(lightrec[nlights].pos, pos);
155     lightrec[nlights].area = area;
156     nlights++; dolights--;
157     return(1);
158     }
159
160
161 greg 3.3 static void
162 gwlarson 3.1 l_source(n) /* convert a distant source */
163     register int n;
164     {
165     register MATREC *m = lightrec[n].m;
166 gwlarson 3.2 int thislight = glightid[n];
167 gwlarson 3.1 GLfloat vec[4];
168     /* assign direction */
169     VCOPY(vec, lightrec[n].pos);
170     vec[3] = 0.;
171     glLightfv(thislight, GL_POSITION, vec);
172     /* assign color */
173     vec[0] = expval*lightrec[n].area*colval(m->u.l.emission,RED);
174     vec[1] = expval*lightrec[n].area*colval(m->u.l.emission,GRN);
175     vec[2] = expval*lightrec[n].area*colval(m->u.l.emission,BLU);
176     vec[3] = 1.;
177     glLightfv(thislight, GL_SPECULAR, vec);
178     glLightfv(thislight, GL_DIFFUSE, vec);
179     vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
180     glLightfv(thislight, GL_AMBIENT, vec);
181     glEnable(thislight);
182     }
183
184
185 greg 3.3 static void
186 gwlarson 3.1 l_flatsrc(n) /* convert a flat source */
187     register int n;
188     {
189     GLfloat vec[4];
190     register MATREC *m = lightrec[n].m;
191 gwlarson 3.2 int thislight = glightid[n];
192 gwlarson 3.1 /* assign position */
193     VCOPY(vec, lightrec[n].pos); vec[3] = 1.;
194     glLightfv(thislight, GL_POSITION, vec);
195     /* assign color */
196     vec[0] = expval*lightrec[n].area*colval(m->u.l.emission,RED);
197     vec[1] = expval*lightrec[n].area*colval(m->u.l.emission,GRN);
198     vec[2] = expval*lightrec[n].area*colval(m->u.l.emission,BLU);
199     vec[3] = 1.;
200     glLightfv(thislight, GL_SPECULAR, vec);
201     glLightfv(thislight, GL_DIFFUSE, vec);
202     vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
203     glLightfv(thislight, GL_AMBIENT, vec);
204     glLightf(thislight, GL_SPOT_EXPONENT, 1.);
205     glLightf(thislight, GL_CONSTANT_ATTENUATION, 0.);
206     glLightf(thislight, GL_LINEAR_ATTENUATION, 0.);
207     glLightf(thislight, GL_QUADRATIC_ATTENUATION, 1.);
208     if (m->type == MAT_SPOT && m->u.l.spotang < 90.) {
209     glLightf(thislight, GL_SPOT_CUTOFF, m->u.l.spotang);
210     glLightfv(thislight, GL_SPOT_DIRECTION, m->u.l.spotdir);
211     } else {
212     glLightf(thislight, GL_SPOT_CUTOFF, 90.);
213     VCOPY(vec, lightrec[n].norm);
214     glLightfv(thislight, GL_SPOT_DIRECTION, vec);
215     }
216     glEnable(thislight);
217     }
218
219
220 greg 3.3 static void
221 gwlarson 3.1 l_sphsrc(n) /* convert a spherical source */
222     register int n;
223     {
224     GLfloat vec[4];
225     register MATREC *m = lightrec[n].m;
226 gwlarson 3.2 int thislight = glightid[n];
227 gwlarson 3.1 /* assign position */
228     VCOPY(vec, lightrec[n].pos); vec[3] = 1.;
229     glLightfv(thislight, GL_POSITION, vec);
230     /* assign color */
231     vec[0] = expval*lightrec[n].area*colval(m->u.l.emission,RED);
232     vec[1] = expval*lightrec[n].area*colval(m->u.l.emission,GRN);
233     vec[2] = expval*lightrec[n].area*colval(m->u.l.emission,BLU);
234     vec[3] = 1.;
235     glLightfv(thislight, GL_SPECULAR, vec);
236     glLightfv(thislight, GL_DIFFUSE, vec);
237     vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
238     glLightfv(thislight, GL_AMBIENT, vec);
239     glLightf(thislight, GL_SPOT_EXPONENT, 0.);
240     glLightf(thislight, GL_CONSTANT_ATTENUATION, 0.);
241     glLightf(thislight, GL_LINEAR_ATTENUATION, 0.);
242     glLightf(thislight, GL_QUADRATIC_ATTENUATION, 1.);
243     if (m->type == MAT_SPOT && m->u.l.spotang <= 90.) {
244     glLightf(thislight, GL_SPOT_CUTOFF, m->u.l.spotang);
245     glLightfv(thislight, GL_SPOT_DIRECTION, m->u.l.spotdir);
246     } else
247     glLightf(thislight, GL_SPOT_CUTOFF, 180.);
248     glEnable(thislight);
249     }
