root/radiance/ray/src/common/rglmat.c
Fri Feb 18 00:40:25 2011 UTC (14 years, 3 months ago) by greg
Changes since 3.6: +26 -18 lines
Diff to previous 3.6
Fri Nov 14 17:22:06 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 3.5: +2 -1 lines
Diff to previous 3.5
Tue Sep 16 06:31:48 2003 UTC (21 years, 8 months ago) by greg
Changes since 3.4: +7 -5 lines
Diff to previous 3.4
Fixed prototype for freemtl() to match function pointer in lookup.h
Wed Apr 23 02:28:06 2003 UTC (22 years, 1 month ago) by greg
Changes since 3.3: +19 -1 lines
Diff to previous 3.3
Added check for mesh primitive and warning when encountered
Tue Feb 25 02:47:22 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.2: +1 -56 lines
Diff to previous 3.2
Changes since 3.1: +72 -9 lines
Diff to previous 3.1
Tue Jun 9 11:18:35 1998 UTC (26 years, 11 months ago) by gwlarson
