root/radiance/ray/src/common/rglmat.c
Fri Feb 18 00:40:25 2011 UTC (14 years, 5 months ago) by greg
CVS Tags: HEAD, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Changes since 3.6: +26 -18 lines
Diff to previous 3.6 , to selected 3.1
Fri Nov 14 17:22:06 2003 UTC (21 years, 8 months ago) by schorsch
Changes since 3.5: +2 -1 lines
Diff to previous 3.5 , to selected 3.1
Tue Sep 16 06:31:48 2003 UTC (21 years, 10 months ago) by greg
Changes since 3.4: +7 -5 lines
Diff to previous 3.4 , to selected 3.1
Fixed prototype for freemtl() to match function pointer in lookup.h
Wed Apr 23 02:28:06 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.3: +19 -1 lines
Diff to previous 3.3 , to selected 3.1
Added check for mesh primitive and warning when encountered
Tue Feb 25 02:47:22 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.2: +1 -56 lines
Diff to previous 3.2 , to selected 3.1
Sat Feb 22 02:07:22 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.1: +72 -9 lines
Diff to previous 3.1
Revision 3.1 - (view) (download) (annotate) - [selected]
Tue Jun 9 11:18:35 1998 UTC (27 years, 2 months ago) by gwlarson
