| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id$";
| 3 |
#endif
| 4 |
| 5 |
* Routines for reading instances and converting to OpenGL.
| 6 |
| 7 |
| 8 |
| 9 |
* The Radiance Software License, Version 1.0
| 10 |
| 11 |
* Copyright (c) 1990 - 2002 The Regents of the University of California,
| 12 |
* through Lawrence Berkeley National Laboratory. All rights reserved.
| 13 |
| 14 |
* Redistribution and use in source and binary forms, with or without
| 15 |
* modification, are permitted provided that the following conditions
| 16 |
* are met:
| 17 |
| 18 |
* 1. Redistributions of source code must retain the above copyright
| 19 |
* notice, this list of conditions and the following disclaimer.
| 20 |
| 21 |
* 2. Redistributions in binary form must reproduce the above copyright
| 22 |
* notice, this list of conditions and the following disclaimer in
| 23 |
* the documentation and/or other materials provided with the
| 24 |
* distribution.
| 25 |
| 26 |
* 3. The end-user documentation included with the redistribution,
| 27 |
* if any, must include the following acknowledgment:
| 28 |
* "This product includes Radiance software
| 29 |
* (http://radsite.lbl.gov/)
| 30 |
* developed by the Lawrence Berkeley National Laboratory
| 31 |
* (http://www.lbl.gov/)."
| 32 |
* Alternately, this acknowledgment may appear in the software itself,
| 33 |
* if and wherever such third-party acknowledgments normally appear.
| 34 |
| 35 |
* 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
| 36 |
* and "The Regents of the University of California" must
| 37 |
* not be used to endorse or promote products derived from this
| 38 |
* software without prior written permission. For written
| 39 |
* permission, please contact [email protected].
| 40 |
| 41 |
* 5. Products derived from this software may not be called "Radiance",
| 42 |
* nor may "Radiance" appear in their name, without prior written
| 43 |
* permission of Lawrence Berkeley National Laboratory.
| 44 |
| 45 |
* THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
| 46 |
* WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
| 47 |
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
| 48 |
* DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
| 49 |
* ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
| 50 |
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
| 51 |
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
| 52 |
* USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
| 53 |
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
| 54 |
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
| 55 |
* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
| 56 |
* SUCH DAMAGE.
| 57 |
| 58 |
| 59 |
* This software consists of voluntary contributions made by many
| 60 |
* individuals on behalf of Lawrence Berkeley National Laboratory. For more
| 61 |
* information on Lawrence Berkeley National Laboratory, please see
| 62 |
* <http://www.lbl.gov/>.
| 63 |
| 64 |
| 65 |
#include "radogl.h"
| 66 |
#include "octree.h"
| 67 |
| 68 |
#define MAXLEVEL 16 /* maximum instance hierarchy level */
| 69 |
| 70 |
typedef struct {
| 71 |
int listid; /* our list id */
| 72 |
short localmatl; /* uses local material only */
| 73 |
FVECT cent; /* center of octree cube */
| 74 |
char octfile[256]; /* octree file path */
| 75 |
} OCTINST; /* octree to instantiate */
| 76 |
| 77 |
static double ogetflt();
| 78 |
static long ogetint();
| 79 |
static char *ogetstr();
| 80 |
static int loadobj();
| 81 |
static void skiptree();
| 82 |
static void octerror();
| 83 |
static OCTINST *getoct();
| 84 |
| 85 |
static char *infn; /* input file name */
| 86 |
static FILE *infp; /* input file stream */
| 87 |
static int objsize; /* size of stored OBJECT's */
| 88 |
static short otypmap[NUMOTYPE+8]; /* object type map */
| 89 |
| 90 |
static unsigned long imhash(mod) char *mod; {return((unsigned long)mod);}
| 91 |
static LUTAB imtab = {imhash,NULL,NULL,NULL,0,NULL,0};
| 92 |
| 93 |
static LUTAB ottab = LU_SINIT(free,free);
| 94 |
| 95 |
| 96 |
int
| 97 |
o_instance(o) /* convert instance to list call */
| 98 |
register OBJREC *o;
| 99 |
| 100 |
XF xfs;
| 101 |
register OCTINST *ot;
| 102 |
/* set up */
| 103 |
if (o->oargs.nsargs < 1)
| 104 |
objerror(o, USER, "missing octree");
| 105 |
setmaterial(NULL, NULL, 0);
| 106 |
/* put out transform (if any) */
| 107 |
if (o->oargs.nsargs > 1) {
| 108 |
if (xf(&xfs, o->oargs.nsargs-1, o->oargs.sarg+1) !=
| 109 |
o->oargs.nsargs-1)
| 110 |
objerror(o, USER, "bad transform");
| 111 |
glPushAttrib(GL_TRANSFORM_BIT);
| 112 |
if (xfs.sca < 1.-FTINY | xfs.sca > 1.+FTINY)
| 113 |
glEnable(GL_NORMALIZE);
| 114 |
glMatrixMode(GL_MODELVIEW);
| 115 |
glPushMatrix();
| 116 |
/* matrix order works out to same */
| 117 |
#ifdef SMLFLT
| 118 |
glMultMatrixf((GLfloat *)xfs.xfm);
| 119 |
#else
| 120 |
glMultMatrixd((GLdouble *)xfs.xfm);
| 121 |
#endif
| 122 |
| 123 |
ot = getoct(o->oargs.sarg[0]); /* get octree reference */
| 124 |
if (ot->localmatl &= o->os != NULL) /* set material */
| 125 |
setmaterial((MATREC *)o->os, ot->cent, 0);
| 126 |
/* call the assigned list */
| 127 |
glCallList(ot->listid);
| 128 |
| 129 |
if (o->oargs.nsargs > 1) { /* end transform */
| 130 |
| 131 |
glPopMatrix();
| 132 |
glPopAttrib();
| 133 |
| 134 |
rgl_checkerr("creating instance");
| 135 |
| 136 |
| 137 |
| 138 |
static int
| 139 |
buildoctlist(lp) /* build octree list */
| 140 |
LUENT *lp;
| 141 |
| 142 |
int old_dolights = dolights, old_domats = domats;
| 143 |
register OCTINST *op = (OCTINST *)lp->data;
| 144 |
| 145 |
domats = !op->localmatl; /* do materials only if needed */
| 146 |
dolights = 0; /* never do light sources */
| 147 |
glNewList(op->listid, GL_COMPILE);
| 148 |
loadoct(op->octfile); /* load objects into display list */
| 149 |
surfclean(); /* clean up */
| 150 |
glEndList();
| 151 |
dolights = old_dolights; /* restore */
| 152 |
domats = old_domats;
| 153 |
return(1); /* return success */
| 154 |
| 155 |
| 156 |
| 157 |
int
| 158 |
loadoctrees() /* load octrees we've saved up */
| 159 |
| 160 |
int levelsleft = MAXLEVEL;
| 161 |
int nocts = 0;
| 162 |
LUTAB looptab;
| 163 |
/* loop through new octree references */
| 164 |
while (ottab.tsiz) {
| 165 |
if (!levelsleft--)
| 166 |
error(USER, "too many octree levels -- instance loop?");
| 167 |
copystruct(&looptab, &ottab);
| 168 |
ottab.tsiz = 0;
| 169 |
nocts += lu_doall(&looptab, buildoctlist);
| 170 |
lu_done(&looptab);
| 171 |
| 172 |
return(nocts);
| 173 |
| 174 |
| 175 |
| 176 |
static OCTINST *
| 177 |
getoct(name) /* get/assign octree list id */
| 178 |
char *name;
| 179 |
| 180 |
extern char *getpath(), *getlibpath();
| 181 |
char *path;
| 182 |
register LUENT *lp;
| 183 |
register OCTINST *op;
| 184 |
| 185 |
if ((lp = lu_find(&ottab, name)) == NULL)
| 186 |
goto memerr;
| 187 |
if (lp->key == NULL) {
| 188 |
lp->key = (char *)malloc(strlen(name)+1);
| 189 |
| 190 |
goto memerr;
| 191 |
strcpy(lp->key, name);
| 192 |
| 193 |
if ((op = (OCTINST *)lp->data) == NULL) {
| 194 |
path = getpath(name, getlibpath(), R_OK);
| 195 |
if (path == NULL) {
| 196 |
sprintf(errmsg, "cannot find octree \"%s\"", name);
| 197 |
error(USER, errmsg);
| 198 |
| 199 |
op = (OCTINST *)(lp->data = (char *)malloc(sizeof(OCTINST)));
| 200 |
strcpy(op->octfile, path);
| 201 |
checkoct(op->octfile, op->cent);
| 202 |
op->listid = newglist();
| 203 |
op->localmatl = ~0;
| 204 |
| 205 |
return(op);
| 206 |
memerr:
| 207 |
error(SYSTEM, "out of memory in getoct");
| 208 |
| 209 |
| 210 |
| 211 |
double
| 212 |
checkoct(fname, cent) /* check octree file for validity */
| 213 |
char *fname;
| 214 |
FVECT cent;
| 215 |
| 216 |
char sbuf[64];
| 217 |
FILE *fp = infp;
| 218 |
char *fn = infn;
| 219 |
double siz = 0.;
| 220 |
register int i;
| 221 |
| 222 |
if ((infp = fopen(infn=fname, "r")) == NULL) {
| 223 |
sprintf(errmsg, "cannot open octree file \"%s\"", fname);
| 224 |
error(SYSTEM, errmsg);
| 225 |
| 226 |
#ifdef MSDOS
| 227 |
setmode(fileno(infp), O_BINARY);
| 228 |
#endif
| 229 |
/* get header */
| 230 |
if (checkheader(infp, OCTFMT, NULL) < 0)
| 231 |
octerror(USER, "not an octree");
| 232 |
/* check format */
| 233 |
if ((objsize = ogetint(2)-OCTMAGIC) <= 0 ||
| 234 |
objsize > MAXOBJSIZ || objsize > sizeof(long))
| 235 |
octerror("incompatible octree format");
| 236 |
if (cent != NULL) { /* get boundaries (compute center) */
| 237 |
for (i = 0; i < 3; i++)
| 238 |
cent[i] = atof(ogetstr(sbuf));
| 239 |
siz = atof(ogetstr(sbuf))*.5;
| 240 |
cent[0] += siz; cent[1] += siz; cent[2] += siz;
| 241 |
} else { /* get size (radius) only */
| 242 |
| 243 |
ogetstr(sbuf);
| 244 |
| 245 |
| 246 |
fclose(infp);
| 247 |
infp = fp;
| 248 |
infn = fn;
| 249 |
return(siz);
| 250 |
| 251 |
| 252 |
| 253 |
int
| 254 |
loadoct(fname) /* read in objects from octree */
| 255 |
char *fname;
| 256 |
| 257 |
OBJECT fnobjects;
| 258 |
char sbuf[256];
| 259 |
int nf;
| 260 |
register int i;
| 261 |
long m;
| 262 |
| 263 |
infn = fname;
| 264 |
infp = fopen(fname, "r"); /* assume already checked */
| 265 |
#ifdef MSDOS
| 266 |
| 267 |
#endif
| 268 |
/* skip header */
| 269 |
getheader(infp, NULL, NULL);
| 270 |
/* get format */
| 271 |
objsize = ogetint(2)-OCTMAGIC;
| 272 |
/* skip boundaries */
| 273 |
for (i = 0; i < 4; i++)
| 274 |
ogetstr(sbuf);
| 275 |
nf = 0; /* load object files */
| 276 |
while (*ogetstr(sbuf)) {
| 277 |
rgl_load(sbuf);
| 278 |
nf++;
| 279 |
| 280 |
/* get number of objects */
| 281 |
fnobjects = m = ogetint(objsize);
| 282 |
if (fnobjects != m)
| 283 |
octerror(USER, "too many objects");
| 284 |
| 285 |
if (nf == 0) {
| 286 |
skiptree();
| 287 |
for (i = 0; *ogetstr(sbuf); i++)
| 288 |
if ((otypmap[i] = otype(sbuf)) < 0) {
| 289 |
sprintf(errmsg, "unknown type \"%s\"", sbuf);
| 290 |
octerror(WARNING, errmsg);
| 291 |
| 292 |
lu_init(&imtab, 1000); nobjects = 0;
| 293 |
while (loadobj() != OVOID)
| 294 |
| 295 |
lu_done(&imtab);
| 296 |
if (nobjects != fnobjects)
| 297 |
octerror(USER, "inconsistent object count");
| 298 |
| 299 |
fclose(infp);
| 300 |
return(nf);
| 301 |
| 302 |
| 303 |
| 304 |
static char *
| 305 |
ogetstr(s) /* get null-terminated string */
| 306 |
char *s;
| 307 |
| 308 |
extern char *getstr();
| 309 |
| 310 |
if (getstr(s, infp) == NULL)
| 311 |
octerror(USER, "truncated octree");
| 312 |
return(s);
| 313 |
| 314 |
| 315 |
| 316 |
static long
| 317 |
ogetint(siz) /* get a siz-byte integer */
| 318 |
int siz;
| 319 |
| 320 |
extern long getint();
| 321 |
register long r;
| 322 |
| 323 |
r = getint(siz, infp);
| 324 |
if (feof(infp))
| 325 |
| 326 |
return(r);
| 327 |
| 328 |
| 329 |
| 330 |
static double
| 331 |
ogetflt() /* get a floating point number */
| 332 |
| 333 |
extern double getflt();
| 334 |
double r;
| 335 |
| 336 |
r = getflt(infp);
| 337 |
if (feof(infp))
| 338 |
| 339 |
return(r);
| 340 |
| 341 |
| 342 |
| 343 |
static void
| 344 |
skiptree() /* skip octree on input */
| 345 |
| 346 |
register int i;
| 347 |
| 348 |
switch (getc(infp)) {
| 349 |
case OT_EMPTY:
| 350 |
return;
| 351 |
case OT_FULL:
| 352 |
for (i = ogetint(objsize)*objsize; i-- > 0; )
| 353 |
if (getc(infp) == EOF)
| 354 |
| 355 |
return;
| 356 |
case OT_TREE:
| 357 |
for (i = 0; i < 8; i++)
| 358 |
skiptree();
| 359 |
return;
| 360 |
case EOF:
| 361 |
| 362 |
default:
| 363 |
octerror(USER, "damaged octree");
| 364 |
| 365 |
| 366 |
| 367 |
| 368 |
static int
| 369 |
loadobj() /* get next object */
| 370 |
| 371 |
static OBJREC ob;
| 372 |
char idbuf[MAXSTR], sbuf[MAXSTR];
| 373 |
register LUENT *lep;
| 374 |
register int i;
| 375 |
register long m;
| 376 |
/* get type */
| 377 |
i = ogetint(1);
| 378 |
if (i == -1)
| 379 |
return(OVOID); /* terminator */
| 380 |
if ((ob.otype = otypmap[i]) < 0)
| 381 |
octerror(USER, "reference to unknown type");
| 382 |
/* get modifier */
| 383 |
if ((m = ogetint(objsize)) != OVOID && (OBJECT)m != m)
| 384 |
| 385 |
if ((ob.omod = m) != OVOID && domats) {
| 386 |
if ((lep = lu_find(&imtab, (char *)m)) == NULL)
| 387 |
goto memerr;
| 388 |
ob.os = lep->data;
| 389 |
} else
| 390 |
ob.os = NULL;
| 391 |
/* get name id */
| 392 |
ob.oname = ogetstr(idbuf);
| 393 |
/* get string arguments */
| 394 |
if (ob.oargs.nsargs = ogetint(2)) {
| 395 |
ob.oargs.sarg = (char **)malloc
| 396 |
(ob.oargs.nsargs*sizeof(char *));
| 397 |
if (ob.oargs.sarg == NULL)
| 398 |
goto memerr;
| 399 |
for (i = 0; i < ob.oargs.nsargs; i++)
| 400 |
ob.oargs.sarg[i] = savestr(ogetstr(sbuf));
| 401 |
} else
| 402 |
ob.oargs.sarg = NULL;
| 403 |
/* get integer arguments */
| 404 |
#ifdef IARGS
| 405 |
if (ob.oargs.niargs = ogetint(2)) {
| 406 |
ob.oargs.iarg = (long *)malloc
| 407 |
(ob.oargs.niargs*sizeof(long));
| 408 |
if (ob.oargs.iarg == NULL)
| 409 |
goto memerr;
| 410 |
for (i = 0; i < ob.oargs.niargs; i++)
| 411 |
ob.oargs.iarg[i] = ogetint(4);
| 412 |
} else
| 413 |
ob.oargs.iarg = NULL;
| 414 |
#endif
| 415 |
/* get real arguments */
| 416 |
if (ob.oargs.nfargs = ogetint(2)) {
| 417 |
ob.oargs.farg = (FLOAT *)malloc
| 418 |
(ob.oargs.nfargs*sizeof(FLOAT));
| 419 |
if (ob.oargs.farg == NULL)
| 420 |
goto memerr;
| 421 |
for (i = 0; i < ob.oargs.nfargs; i++)
| 422 |
ob.oargs.farg[i] = ogetflt();
| 423 |
} else
| 424 |
ob.oargs.farg = NULL;
| 425 |
/* process object */
| 426 |
(*ofun[ob.otype].funp)(&ob);
| 427 |
/* record material if modifier */
| 428 |
if (ismodifier(ob.otype)) {
| 429 |
if ((lep = lu_find(&imtab, (char *)nobjects)) == NULL)
| 430 |
goto memerr;
| 431 |
lep->key = (char *)nobjects;
| 432 |
lep->data = (char *)getmatp(ob.oname);
| 433 |
| 434 |
freefargs(&ob.oargs); /* free arguments */
| 435 |
return(nobjects++); /* return object id */
| 436 |
memerr:
| 437 |
error(SYSTEM, "out of memory in loadobj");
| 438 |
| 439 |
| 440 |
| 441 |
static void
| 442 |
octerror(etyp, msg) /* octree error */
| 443 |
int etyp;
| 444 |
char *msg;
| 445 |
| 446 |
char msgbuf[128];
| 447 |
| 448 |
sprintf(msgbuf, "(%s): %s", infn, msg);
| 449 |
error(etyp, msgbuf);
| 450 |
