| 1 | #ifndef lint |
| 2 | static const char       RCSid[] = "$Id: rglinst.c,v 3.17 2016/03/22 03:56:17 greg Exp $"; |
| 3 | #endif |
| 4 | /* |
| 5 | * Routines for reading instances and converting to OpenGL. |
| 6 | */ |
| 7 |  |
| 8 | #include "copyright.h" |
| 9 |  |
| 10 | #include <stdio.h> |
| 11 | #include <string.h> |
| 12 | #include <time.h> |
| 13 |  |
| 14 | #include "platform.h" |
| 15 | #include "resolu.h" |
| 16 | #include "radogl.h" |
| 17 | #include "octree.h" |
| 18 |  |
| 19 | #define MAXLEVEL        16              /* maximum instance hierarchy level */ |
| 20 |  |
| 21 | typedef struct { |
| 22 | int     listid;                         /* our list id */ |
| 23 | short   localmatl;                      /* uses local material only */ |
| 24 | FVECT   cent;                           /* center of octree cube */ |
| 25 | char    octfile[256];                   /* octree file path */ |
| 26 | } OCTINST;                              /* octree to instantiate */ |
| 27 |  |
| 28 | static double  ogetflt(void); |
| 29 | static long  ogetint(int); |
| 30 | static char  *ogetstr(char *); |
| 31 | static int  loadobj(void); |
| 32 | static void  skiptree(void); |
| 33 | static void  octerror(int etyp, char *msg); |
| 34 | static OCTINST  *getoct(char *); |
| 35 |  |
| 36 | static char  *infn;                     /* input file name */ |
| 37 | static FILE  *infp;                     /* input file stream */ |
| 38 | static int  objsize;                    /* size of stored OBJECT's */ |
| 39 | static short  otypmap[NUMOTYPE+8];      /* object type map */ |
| 40 |  |
| 41 | static unsigned long    imhash(const char *mod) {return((unsigned long)mod);} |
| 42 | static LUTAB    imtab = {imhash,NULL,NULL,NULL,0,NULL,0}; |
| 43 |  |
| 44 | static LUTAB    ottab = LU_SINIT(free,free); |
| 45 |  |
| 46 |  |
| 47 | int |
| 48 | o_instance(o)                           /* convert instance to list call */ |
| 49 | register OBJREC *o; |
| 50 | { |
| 51 | XF      xfs; |
| 52 | register OCTINST        *ot; |
| 53 | /* set up */ |
| 54 | if (o->oargs.nsargs < 1) |
| 55 | objerror(o, USER, "missing octree"); |
| 56 | setmaterial(NULL, NULL, 0); |
| 57 | /* put out transform (if any) */ |
| 58 | if (o->oargs.nsargs > 1) { |
| 59 | if (xf(&xfs, o->oargs.nsargs-1, o->oargs.sarg+1) != |
| 60 | o->oargs.nsargs-1) |
| 61 | objerror(o, USER, "bad transform"); |
| 62 | glPushAttrib(GL_TRANSFORM_BIT); |
| 63 | if ((xfs.sca < 1.-FTINY) | (xfs.sca > 1.+FTINY)) |
| 64 | glEnable(GL_NORMALIZE); |
| 65 | glMatrixMode(GL_MODELVIEW); |
| 66 | glPushMatrix(); |
| 67 | /* matrix order works out to same */ |
| 68 | #ifdef SMLFLT |
| 69 | glMultMatrixf((GLfloat *)xfs.xfm); |
| 70 | #else |
| 71 | glMultMatrixd((GLdouble *)xfs.xfm); |
| 72 | #endif |
| 73 | } |
| 74 | ot = getoct(o->oargs.sarg[0]);  /* get octree reference */ |
| 75 | if (ot->localmatl &= o->os != NULL)     /* set material */ |
| 76 | setmaterial((MATREC *)o->os, ot->cent, 0); |
| 77 | /* call the assigned list */ |
| 78 | glCallList(ot->listid); |
| 79 |  |
| 80 | if (o->oargs.nsargs > 1) {      /* end transform */ |
| 81 | glMatrixMode(GL_MODELVIEW); |
| 82 | glPopMatrix(); |
| 83 | glPopAttrib(); |
| 84 | } |
| 85 | rgl_checkerr("creating instance"); |
| 86 | return(0); |
| 87 | } |
| 88 |  |
| 89 |  |
| 90 | static int |
| 91 | buildoctlist(lp, p)                     /* build octree list */ |
| 92 | const LUENT     *lp; |
| 93 | void    *p; |
| 94 | { |
| 95 | int     old_dolights = dolights, old_domats = domats; |
| 96 | register OCTINST        *op = (OCTINST *)lp->data; |
| 97 |  |
| 98 | domats = !op->localmatl;        /* do materials only if needed */ |
| 99 | dolights = 0;                   /* never do light sources */ |
| 100 | glNewList(op->listid, GL_COMPILE); |
| 101 | loadoct(op->octfile);           /* load objects into display list */ |
| 102 | surfclean();                    /* clean up */ |
| 103 | glEndList(); |
| 104 | dolights = old_dolights;        /* restore */ |
| 105 | domats = old_domats; |
| 106 | return(1);                      /* return success */ |
| 107 | } |
| 108 |  |
| 109 |  |
| 110 | int |
| 111 | loadoctrees()                           /* load octrees we've saved up */ |
| 112 | { |
| 113 | int     levelsleft = MAXLEVEL; |
| 114 | int     nocts = 0; |
| 115 | LUTAB   looptab; |
| 116 | /* loop through new octree references */ |
| 117 | while (ottab.tsiz) { |
| 118 | if (!levelsleft--) |
| 119 | error(USER, "too many octree levels -- instance loop?"); |
| 120 | looptab = ottab; |
| 121 | ottab.tsiz = 0; |
| 122 | nocts += lu_doall(&looptab, buildoctlist, NULL); |
| 123 | lu_done(&looptab); |
| 124 | } |
| 125 | return(nocts); |
| 126 | } |
| 127 |  |
| 128 |  |
| 129 | static OCTINST * |
| 130 | getoct(name)                            /* get/assign octree list id */ |
| 131 | char    *name; |
| 132 | { |
| 133 | char    *path; |
| 134 | register LUENT  *lp; |
| 135 | register OCTINST        *op; |
| 136 |  |
| 137 | if ((lp = lu_find(&ottab, name)) == NULL) |
| 138 | goto memerr; |
| 139 | if (lp->key == NULL) { |
| 140 | lp->key = (char *)malloc(strlen(name)+1); |
| 141 | if (lp->key == NULL) |
| 142 | goto memerr; |
| 143 | strcpy(lp->key, name); |
| 144 | } |
| 145 | if ((op = (OCTINST *)lp->data) == NULL) { |
| 146 | path = getpath(name, getrlibpath(), R_OK); |
| 147 | if (path == NULL) { |
| 148 | sprintf(errmsg, "cannot find octree \"%s\"", name); |
| 149 | error(SYSTEM, errmsg); |
| 150 | } |
| 151 | op = (OCTINST *)(lp->data = (char *)malloc(sizeof(OCTINST))); |
| 152 | strcpy(op->octfile, path); |
| 153 | checkoct(op->octfile, op->cent); |
| 154 | op->listid = newglist(); |
| 155 | op->localmatl = ~0; |
| 156 | } |
| 157 | return(op); |
| 158 | memerr: |
| 159 | error(SYSTEM, "out of memory in getoct"); |
| 160 | return NULL; /* pro forma return */ |
| 161 | } |
| 162 |  |
| 163 |  |
| 164 | double |
| 165 | checkoct(fname, cent)                   /* check octree file for validity */ |
| 166 | char    *fname; |
| 167 | FVECT   cent; |
| 168 | { |
| 169 | char  sbuf[64]; |
| 170 | FILE    *fp = infp; |
| 171 | char    *fn = infn; |
| 172 | double  siz = 0.; |
| 173 | register int  i; |
| 174 |  |
| 175 | if ((infp = fopen(infn=fname, "r")) == NULL) { |
| 176 | sprintf(errmsg, "cannot open octree file \"%s\"", fname); |
| 177 | error(SYSTEM, errmsg); |
| 178 | } |
| 179 | SET_FILE_BINARY(infp); |
| 180 | /* get header */ |
| 181 | if (checkheader(infp, OCTFMT, NULL) < 0) |
| 182 | octerror(USER, "not an octree"); |
| 183 | /* check format */ |
| 184 | if ((objsize = ogetint(2)-OCTMAGIC) <= 0 || |
| 185 | objsize > MAXOBJSIZ || objsize > sizeof(long)) |
| 186 | octerror(USER, "incompatible octree format"); |
| 187 | if (cent != NULL) {             /* get boundaries (compute center) */ |
| 188 | for (i = 0; i < 3; i++) |
| 189 | cent[i] = atof(ogetstr(sbuf)); |
| 190 | siz = atof(ogetstr(sbuf))*.5; |
| 191 | cent[0] += siz; cent[1] += siz; cent[2] += siz; |
| 192 | } else {                        /* get size (radius) only */ |
| 193 | for (i = 0; i < 3; i++) |
| 194 | ogetstr(sbuf); |
| 195 | siz = atof(ogetstr(sbuf))*.5; |
| 196 | } |
| 197 | fclose(infp); |
| 198 | infp = fp; |
| 199 | infn = fn; |
| 200 | return(siz); |
| 201 | } |
| 202 |  |
| 203 |  |
| 204 | int |
| 205 | loadoct(fname)                          /* read in objects from octree */ |
| 206 | char  *fname; |
| 207 | { |
| 208 | OBJECT  fnobjects; |
| 209 | char  sbuf[256]; |
| 210 | int  nf; |
| 211 | register int  i; |
| 212 | long  m; |
| 213 |  |
| 214 | infn = fname; |
| 215 | infp = fopen(fname, "r");       /* assume already checked */ |
| 216 | SET_FILE_BINARY(infp); |
| 217 | /* skip header */ |
| 218 | getheader(infp, NULL, NULL); |
| 219 | /* get format */ |
| 220 | objsize = ogetint(2)-OCTMAGIC; |
| 221 | /* skip boundaries */ |
| 222 | for (i = 0; i < 4; i++) |
| 223 | ogetstr(sbuf); |
| 224 | nf = 0;                         /* load object files */ |
| 225 | while (*ogetstr(sbuf)) { |
| 226 | rgl_load(sbuf); |
| 227 | nf++; |
| 228 | } |
| 229 | /* get number of objects */ |
| 230 | fnobjects = m = ogetint(objsize); |
| 231 | if (fnobjects != m) |
| 232 | octerror(USER, "too many objects"); |
| 233 |  |
| 234 | if (nf == 0) { |
| 235 | skiptree(); |
| 236 | for (i = 0; *ogetstr(sbuf); i++) |
| 237 | if ((otypmap[i] = otype(sbuf)) < 0) { |
| 238 | sprintf(errmsg, "unknown type \"%s\"", sbuf); |
| 239 | octerror(WARNING, errmsg); |
| 240 | } |
| 241 | lu_init(&imtab, 1000); nobjects = 0; |
| 242 | while (loadobj() != OVOID) |
| 243 | ; |
| 244 | lu_done(&imtab); |
| 245 | if (nobjects != fnobjects) |
| 246 | octerror(USER, "inconsistent object count"); |
| 247 | } |
| 248 | fclose(infp); |
| 249 | return(nf); |
| 250 | } |
| 251 |  |
| 252 |  |
| 253 | static char * |
| 254 | ogetstr(s)                      /* get null-terminated string */ |
| 255 | char  *s; |
| 256 | { |
| 257 | extern char  *getstr(); |
| 258 |  |
| 259 | if (getstr(s, infp) == NULL) |
| 260 | octerror(USER, "truncated octree"); |
| 261 | return(s); |
| 262 | } |
| 263 |  |
| 264 |  |
| 265 | static long |
| 266 | ogetint(siz)                    /* get a siz-byte integer */ |
| 267 | int  siz; |
| 268 | { |
| 269 | extern long  getint(); |
| 270 | register long  r; |
| 271 |  |
| 272 | r = getint(siz, infp); |
| 273 | if (feof(infp)) |
| 274 | octerror(USER, "truncated octree"); |
| 275 | return(r); |
| 276 | } |
| 277 |  |
| 278 |  |
| 279 | static double |
| 280 | ogetflt()                       /* get a floating point number */ |
| 281 | { |
| 282 | extern double  getflt(); |
| 283 | double  r; |
| 284 |  |
| 285 | r = getflt(infp); |
| 286 | if (feof(infp)) |
| 287 | octerror(USER, "truncated octree"); |
| 288 | return(r); |
| 289 | } |
| 290 |  |
| 291 |  |
| 292 | static void |
| 293 | skiptree()                              /* skip octree on input */ |
| 294 | { |
| 295 | register int  i; |
| 296 |  |
| 297 | switch (getc(infp)) { |
| 298 | case OT_EMPTY: |
| 299 | return; |
| 300 | case OT_FULL: |
| 301 | for (i = ogetint(objsize)*objsize; i-- > 0; ) |
| 302 | if (getc(infp) == EOF) |
| 303 | octerror(USER, "truncated octree"); |
| 304 | return; |
| 305 | case OT_TREE: |
| 306 | for (i = 0; i < 8; i++) |
| 307 | skiptree(); |
| 308 | return; |
| 309 | case EOF: |
| 310 | octerror(USER, "truncated octree"); |
| 311 | default: |
| 312 | octerror(USER, "damaged octree"); |
| 313 | } |
| 314 | } |
| 315 |  |
| 316 |  |
| 317 | static int |
| 318 | loadobj()                               /* get next object */ |
| 319 | { |
| 320 | static OBJREC    ob; |
| 321 | char  idbuf[MAXSTR], sbuf[MAXSTR]; |
| 322 | register LUENT  *lep; |
| 323 | register int  i; |
| 324 | register long  m; |
| 325 | /* get type */ |
| 326 | i = ogetint(1); |
| 327 | if (i == -1) |
| 328 | return(OVOID);          /* terminator */ |
| 329 | if ((ob.otype = otypmap[i]) < 0) |
| 330 | octerror(USER, "reference to unknown type"); |
| 331 | /* get modifier */ |
| 332 | if ((m = ogetint(objsize)) != OVOID && (OBJECT)m != m) |
| 333 | octerror(USER, "too many objects"); |
| 334 | if ((ob.omod = m) != OVOID && domats) { |
| 335 | if ((lep = lu_find(&imtab, (char *)m)) == NULL) |
| 336 | goto memerr; |
| 337 | ob.os = lep->data; |
| 338 | } else |
| 339 | ob.os = NULL; |
| 340 | /* get name id */ |
| 341 | ob.oname = ogetstr(idbuf); |
| 342 | /* get string arguments */ |
| 343 | if ((ob.oargs.nsargs = ogetint(2))) { |
| 344 | ob.oargs.sarg = (char **)malloc |
| 345 | (ob.oargs.nsargs*sizeof(char *)); |
| 346 | if (ob.oargs.sarg == NULL) |
| 347 | goto memerr; |
| 348 | for (i = 0; i < ob.oargs.nsargs; i++) |
| 349 | ob.oargs.sarg[i] = savestr(ogetstr(sbuf)); |
| 350 | } else |
| 351 | ob.oargs.sarg = NULL; |
| 352 | /* get integer arguments */ |
| 353 | #ifdef  IARGS |
| 354 | if (ob.oargs.niargs = ogetint(2)) { |
| 355 | ob.oargs.iarg = (long *)malloc |
| 356 | (ob.oargs.niargs*sizeof(long)); |
| 357 | if (ob.oargs.iarg == NULL) |
| 358 | goto memerr; |
| 359 | for (i = 0; i < ob.oargs.niargs; i++) |
| 360 | ob.oargs.iarg[i] = ogetint(4); |
| 361 | } else |
| 362 | ob.oargs.iarg = NULL; |
| 363 | #endif |
| 364 | /* get real arguments */ |
| 365 | if ((ob.oargs.nfargs = ogetint(2))) { |
| 366 | ob.oargs.farg = (RREAL *)malloc |
| 367 | (ob.oargs.nfargs*sizeof(RREAL)); |
| 368 | if (ob.oargs.farg == NULL) |
| 369 | goto memerr; |
| 370 | for (i = 0; i < ob.oargs.nfargs; i++) |
| 371 | ob.oargs.farg[i] = ogetflt(); |
| 372 | } else |
| 373 | ob.oargs.farg = NULL; |
| 374 | /* process object */ |
| 375 | (*ofun[ob.otype].funp)(&ob); |
| 376 | /* record material if modifier */ |
| 377 | if (ismodifier(ob.otype)) { |
| 378 | if ((lep = lu_find(&imtab, (char *)(size_t)nobjects)) == NULL) |
| 379 | goto memerr; |
| 380 | lep->key = (char *)(size_t)nobjects; |
| 381 | lep->data = (char *)getmatp(ob.oname); |
| 382 | } |
| 383 | freefargs(&ob.oargs);           /* free arguments */ |
| 384 | return(nobjects++);             /* return object id */ |
| 385 | memerr: |
| 386 | error(SYSTEM, "out of memory in loadobj"); |
| 387 | return OVOID; /* pro forma return */ |
| 388 | } |
| 389 |  |
| 390 |  |
| 391 | static void |
| 392 | octerror(etyp, msg)                     /* octree error */ |
| 393 | int  etyp; |
| 394 | char  *msg; |
| 395 | { |
| 396 | char  msgbuf[128]; |
| 397 |  |
| 398 | sprintf(msgbuf, "(%s): %s", infn, msg); |
| 399 | error(etyp, msgbuf); |
| 400 | } |
