--- ray/src/common/rglinst.c 2003/05/13 17:58:32 3.8 +++ ray/src/common/rglinst.c 2003/07/21 22:30:17 3.12 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rglinst.c,v 3.8 2003/05/13 17:58:32 greg Exp $"; +static const char RCSid[] = "$Id: rglinst.c,v 3.12 2003/07/21 22:30:17 schorsch Exp $"; #endif /* * Routines for reading instances and converting to OpenGL. @@ -7,6 +7,12 @@ static const char RCSid[] = "$Id: rglinst.c,v 3.8 2003 #include "copyright.h" +#include +#include +#include + +#include "platform.h" +#include "resolu.h" #include "radogl.h" #include "octree.h" @@ -19,13 +25,13 @@ typedef struct { char octfile[256]; /* octree file path */ } OCTINST; /* octree to instantiate */ -static double ogetflt(); -static long ogetint(); -static char *ogetstr(); -static int loadobj(); -static void skiptree(); -static void octerror(); -static OCTINST *getoct(); +static double ogetflt(void); +static long ogetint(int); +static char *ogetstr(char *); +static int loadobj(void); +static void skiptree(void); +static void octerror(int etyp, char *msg); +static OCTINST *getoct(char *); static char *infn; /* input file name */ static FILE *infp; /* input file stream */ @@ -110,7 +116,7 @@ loadoctrees() /* load octrees we've saved up */ while (ottab.tsiz) { if (!levelsleft--) error(USER, "too many octree levels -- instance loop?"); - copystruct(&looptab, &ottab); + looptab = ottab; ottab.tsiz = 0; nocts += lu_doall(&looptab, buildoctlist); lu_done(&looptab); @@ -168,16 +174,14 @@ FVECT cent; sprintf(errmsg, "cannot open octree file \"%s\"", fname); error(SYSTEM, errmsg); } -#ifdef MSDOS - setmode(fileno(infp), O_BINARY); -#endif + SET_FILE_BINARY(infp); /* get header */ if (checkheader(infp, OCTFMT, NULL) < 0) octerror(USER, "not an octree"); /* check format */ if ((objsize = ogetint(2)-OCTMAGIC) <= 0 || objsize > MAXOBJSIZ || objsize > sizeof(long)) - octerror("incompatible octree format"); + octerror(USER, "incompatible octree format"); if (cent != NULL) { /* get boundaries (compute center) */ for (i = 0; i < 3; i++) cent[i] = atof(ogetstr(sbuf)); @@ -207,9 +211,7 @@ char *fname; infn = fname; infp = fopen(fname, "r"); /* assume already checked */ -#ifdef MSDOS - setmode(fileno(infp), O_BINARY); -#endif + SET_FILE_BINARY(infp); /* skip header */ getheader(infp, NULL, NULL); /* get format */ @@ -359,8 +361,8 @@ loadobj() /* get next object */ #endif /* get real arguments */ if (ob.oargs.nfargs = ogetint(2)) { - ob.oargs.farg = (FLOAT *)malloc - (ob.oargs.nfargs*sizeof(FLOAT)); + ob.oargs.farg = (RREAL *)malloc + (ob.oargs.nfargs*sizeof(RREAL)); if (ob.oargs.farg == NULL) goto memerr; for (i = 0; i < ob.oargs.nfargs; i++)
