root/radiance/ray/src/common/rglinst.c
Tue May 25 22:04:13 2004 UTC (19 years, 11 months ago) by greg
Diff to previous 3.14 , to selected 3.5
Tue May 25 06:30:46 2004 UTC (19 years, 11 months ago) by greg
Changes since 3.13: +4 -3 lines
Diff to previous 3.13 , to selected 3.5
Added argument for client data to lu_doall()
Changes since 3.12: +7 -4 lines
Diff to previous 3.12 , to selected 3.5
Mon Jul 21 22:30:17 2003 UTC (20 years, 9 months ago) by schorsch
Diff to previous 3.11 , to selected 3.5
Sat Jul 12 09:55:13 2003 UTC (20 years, 9 months ago) by schorsch
Changes since 3.10: +15 -10 lines
Diff to previous 3.10 , to selected 3.5
Fixed incorrect octerror() call found by Randolph Fritz.
Added prototypes and all necessary includes.
Changes since 3.9: +3 -3 lines
Diff to previous 3.9 , to selected 3.5
Changes since 3.8: +4 -7 lines
Diff to previous 3.8 , to selected 3.5
Tue May 13 17:58:32 2003 UTC (20 years, 11 months ago) by greg
Changes since 3.7: +1 -2 lines
Diff to previous 3.7 , to selected 3.5
Wed Apr 23 02:28:06 2003 UTC (21 years ago) by greg
Changes since 3.6: +1 -0 lines
Diff to previous 3.6 , to selected 3.5
Added check for mesh primitive and warning when encountered
Changes since 3.5: +1 -56 lines
Diff to previous 3.5
Revision 3.5 - (view) (download) (annotate) - [selected]
Changes since 3.4: +67 -13 lines
Diff to previous 3.4
Wed Sep 2 18:42:11 1998 UTC (25 years, 8 months ago) by gwlarson
Diff to previous 3.3 , to selected 3.5
changed lookup routines to use unsigned long hash values
Wed Jul 15 17:52:16 1998 UTC (25 years, 9 months ago) by gwlarson
Diff to previous 3.2 , to selected 3.5
added paranoid setting of glMatrixMode()
Wed Jun 17 17:18:38 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 3.1: +5 -0 lines
Diff to previous 3.1 , to selected 3.5
added (probably unnecessary) test for octree instance loops
Tue Jun 9 11:18:35 1998 UTC (25 years, 11 months ago) by gwlarson
Diff to selected 3.5
