--- ray/src/common/rglinst.c 2003/05/13 17:58:32 3.8 +++ ray/src/common/rglinst.c 2004/05/25 22:04:13 3.15 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rglinst.c,v 3.8 2003/05/13 17:58:32 greg Exp $"; +static const char RCSid[] = "$Id: rglinst.c,v 3.15 2004/05/25 22:04:13 greg Exp $"; #endif /* * Routines for reading instances and converting to OpenGL. @@ -7,6 +7,13 @@ static const char RCSid[] = "$Id: rglinst.c,v 3.8 2003 #include "copyright.h" +#include +#include +#include + +#include "platform.h" +#include "paths.h" +#include "resolu.h" #include "radogl.h" #include "octree.h" @@ -19,13 +26,13 @@ typedef struct { char octfile[256]; /* octree file path */ } OCTINST; /* octree to instantiate */ -static double ogetflt(); -static long ogetint(); -static char *ogetstr(); -static int loadobj(); -static void skiptree(); -static void octerror(); -static OCTINST *getoct(); +static double ogetflt(void); +static long ogetint(int); +static char *ogetstr(char *); +static int loadobj(void); +static void skiptree(void); +static void octerror(int etyp, char *msg); +static OCTINST *getoct(char *); static char *infn; /* input file name */ static FILE *infp; /* input file stream */ @@ -54,7 +61,7 @@ register OBJREC *o; o->oargs.nsargs-1) objerror(o, USER, "bad transform"); glPushAttrib(GL_TRANSFORM_BIT); - if (xfs.sca < 1.-FTINY | xfs.sca > 1.+FTINY) + if ((xfs.sca < 1.-FTINY) | (xfs.sca > 1.+FTINY)) glEnable(GL_NORMALIZE); glMatrixMode(GL_MODELVIEW); glPushMatrix(); @@ -82,8 +89,9 @@ register OBJREC *o; static int -buildoctlist(lp) /* build octree list */ -LUENT *lp; +buildoctlist(lp, p) /* build octree list */ +const LUENT *lp; +void *p; { int old_dolights = dolights, old_domats = domats; register OCTINST *op = (OCTINST *)lp->data; @@ -110,9 +118,9 @@ loadoctrees() /* load octrees we've saved up */ while (ottab.tsiz) { if (!levelsleft--) error(USER, "too many octree levels -- instance loop?"); - copystruct(&looptab, &ottab); + looptab = ottab; ottab.tsiz = 0; - nocts += lu_doall(&looptab, buildoctlist); + nocts += lu_doall(&looptab, buildoctlist, NULL); lu_done(&looptab); } return(nocts); @@ -150,6 +158,7 @@ char *name; return(op); memerr: error(SYSTEM, "out of memory in getoct"); + return NULL; /* pro forma return */ } @@ -168,16 +177,14 @@ FVECT cent; sprintf(errmsg, "cannot open octree file \"%s\"", fname); error(SYSTEM, errmsg); } -#ifdef MSDOS - setmode(fileno(infp), O_BINARY); -#endif + SET_FILE_BINARY(infp); /* get header */ if (checkheader(infp, OCTFMT, NULL) < 0) octerror(USER, "not an octree"); /* check format */ if ((objsize = ogetint(2)-OCTMAGIC) <= 0 || objsize > MAXOBJSIZ || objsize > sizeof(long)) - octerror("incompatible octree format"); + octerror(USER, "incompatible octree format"); if (cent != NULL) { /* get boundaries (compute center) */ for (i = 0; i < 3; i++) cent[i] = atof(ogetstr(sbuf)); @@ -207,9 +214,7 @@ char *fname; infn = fname; infp = fopen(fname, "r"); /* assume already checked */ -#ifdef MSDOS - setmode(fileno(infp), O_BINARY); -#endif + SET_FILE_BINARY(infp); /* skip header */ getheader(infp, NULL, NULL); /* get format */ @@ -336,7 +341,7 @@ loadobj() /* get next object */ /* get name id */ ob.oname = ogetstr(idbuf); /* get string arguments */ - if (ob.oargs.nsargs = ogetint(2)) { + if ((ob.oargs.nsargs = ogetint(2))) { ob.oargs.sarg = (char **)malloc (ob.oargs.nsargs*sizeof(char *)); if (ob.oargs.sarg == NULL) @@ -358,9 +363,9 @@ loadobj() /* get next object */ ob.oargs.iarg = NULL; #endif /* get real arguments */ - if (ob.oargs.nfargs = ogetint(2)) { - ob.oargs.farg = (FLOAT *)malloc - (ob.oargs.nfargs*sizeof(FLOAT)); + if ((ob.oargs.nfargs = ogetint(2))) { + ob.oargs.farg = (RREAL *)malloc + (ob.oargs.nfargs*sizeof(RREAL)); if (ob.oargs.farg == NULL) goto memerr; for (i = 0; i < ob.oargs.nfargs; i++) @@ -380,6 +385,7 @@ loadobj() /* get next object */ return(nobjects++); /* return object id */ memerr: error(SYSTEM, "out of memory in loadobj"); + return OVOID; /* pro forma return */ }
