root/Development/ray/src/common/rglinst.c
Tue May 25 22:04:13 2004 UTC (21 years, 7 months ago) by greg
Diff to previous 3.14
Tue May 25 06:30:46 2004 UTC (21 years, 7 months ago) by greg
Changes since 3.13: +4 -3 lines
Diff to previous 3.13
Added argument for client data to lu_doall()
Fri Nov 14 17:22:06 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 3.12: +7 -4 lines
Diff to previous 3.12
Mon Jul 21 22:30:17 2003 UTC (22 years, 5 months ago) by schorsch
Diff to previous 3.11
Sat Jul 12 09:55:13 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 3.10: +15 -10 lines
Diff to previous 3.10
Fixed incorrect octerror() call found by Randolph Fritz.
Added prototypes and all necessary includes.
Thu Jun 26 00:58:09 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 3.9: +3 -3 lines
Diff to previous 3.9
Thu Jun 5 19:29:34 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 3.8: +4 -7 lines
Diff to previous 3.8
Tue May 13 17:58:32 2003 UTC (22 years, 7 months ago) by greg
Changes since 3.7: +1 -2 lines
Diff to previous 3.7
Wed Apr 23 02:28:06 2003 UTC (22 years, 8 months ago) by greg
Changes since 3.6: +1 -0 lines
Diff to previous 3.6
Added check for mesh primitive and warning when encountered
Tue Feb 25 02:47:22 2003 UTC (22 years, 10 months ago) by greg
Changes since 3.5: +1 -56 lines
Diff to previous 3.5
Sat Feb 22 02:07:22 2003 UTC (22 years, 10 months ago) by greg
Changes since 3.4: +67 -13 lines
Diff to previous 3.4
Wed Sep 2 18:42:11 1998 UTC (27 years, 3 months ago) by gwlarson
Diff to previous 3.3
changed lookup routines to use unsigned long hash values
Wed Jul 15 17:52:16 1998 UTC (27 years, 5 months ago) by gwlarson
Diff to previous 3.2
added paranoid setting of glMatrixMode()
Wed Jun 17 17:18:38 1998 UTC (27 years, 6 months ago) by gwlarson
Changes since 3.1: +5 -0 lines
added (probably unnecessary) test for octree instance loops
Tue Jun 9 11:18:35 1998 UTC (27 years, 6 months ago) by gwlarson
