--- ray/src/common/rglinst.c 2003/07/21 22:30:17 3.12 +++ ray/src/common/rglinst.c 2004/05/25 06:30:46 3.14 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rglinst.c,v 3.12 2003/07/21 22:30:17 schorsch Exp $"; +static const char RCSid[] = "$Id: rglinst.c,v 3.14 2004/05/25 06:30:46 greg Exp $"; #endif /* * Routines for reading instances and converting to OpenGL. @@ -12,6 +12,7 @@ static const char RCSid[] = "$Id: rglinst.c,v 3.12 200 #include #include "platform.h" +#include "paths.h" #include "resolu.h" #include "radogl.h" #include "octree.h" @@ -60,7 +61,7 @@ register OBJREC *o; o->oargs.nsargs-1) objerror(o, USER, "bad transform"); glPushAttrib(GL_TRANSFORM_BIT); - if (xfs.sca < 1.-FTINY | xfs.sca > 1.+FTINY) + if ((xfs.sca < 1.-FTINY) | (xfs.sca > 1.+FTINY)) glEnable(GL_NORMALIZE); glMatrixMode(GL_MODELVIEW); glPushMatrix(); @@ -88,8 +89,9 @@ register OBJREC *o; static int -buildoctlist(lp) /* build octree list */ +buildoctlist(lp, p) /* build octree list */ LUENT *lp; +void *p; { int old_dolights = dolights, old_domats = domats; register OCTINST *op = (OCTINST *)lp->data; @@ -118,7 +120,7 @@ loadoctrees() /* load octrees we've saved up */ error(USER, "too many octree levels -- instance loop?"); looptab = ottab; ottab.tsiz = 0; - nocts += lu_doall(&looptab, buildoctlist); + nocts += lu_doall(&looptab, buildoctlist, NULL); lu_done(&looptab); } return(nocts); @@ -156,6 +158,7 @@ char *name; return(op); memerr: error(SYSTEM, "out of memory in getoct"); + return NULL; /* pro forma return */ } @@ -338,7 +341,7 @@ loadobj() /* get next object */ /* get name id */ ob.oname = ogetstr(idbuf); /* get string arguments */ - if (ob.oargs.nsargs = ogetint(2)) { + if ((ob.oargs.nsargs = ogetint(2))) { ob.oargs.sarg = (char **)malloc (ob.oargs.nsargs*sizeof(char *)); if (ob.oargs.sarg == NULL) @@ -360,7 +363,7 @@ loadobj() /* get next object */ ob.oargs.iarg = NULL; #endif /* get real arguments */ - if (ob.oargs.nfargs = ogetint(2)) { + if ((ob.oargs.nfargs = ogetint(2))) { ob.oargs.farg = (RREAL *)malloc (ob.oargs.nfargs*sizeof(RREAL)); if (ob.oargs.farg == NULL) @@ -382,6 +385,7 @@ loadobj() /* get next object */ return(nobjects++); /* return object id */ memerr: error(SYSTEM, "out of memory in loadobj"); + return OVOID; /* pro forma return */ }
