Made error messages more consistent when library file not found
Added argument for client data to lu_doall()
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Fixed incorrect octerror() call found by Randolph Fritz. Added prototypes and all necessary includes.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Added check for mesh primitive and warning when encountered
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
changed lookup routines to use unsigned long hash values
added paranoid setting of glMatrixMode()
added (probably unnecessary) test for octree instance loops
