root/radiance/ray/src/common/rglfile.c
Revision: 3.7
Committed: Wed Apr 23 02:28:06 2003 UTC (22 years, 1 month ago) by greg
Changes since 3.6: +1 -0 lines
Added check for mesh primitive and warning when encountered
5 * Load Radiance object(s) and create OpenGL display lists
6 */
7
8 #include "copyright.h"
9
10 #include "radogl.h"
11
12 #ifndef NLIST2ALLOC
13 #define NLIST2ALLOC 16 /* batch of display lists to get */
14 #endif
15
16 FUN ofun[NUMOTYPE] = INIT_OTYPE;
17
18 static int nextlist, nlistleft = 0;
19
20
21 static void
22 initotypes() /* initialize ofun array */
23 {
24 if (ofun[OBJ_SPHERE].funp == o_sphere)
25 return; /* already done */
26 /* assign surface types */
27 ofun[OBJ_SPHERE].funp =
28 ofun[OBJ_BUBBLE].funp = o_sphere;
29 ofun[OBJ_FACE].funp = o_face;
30 ofun[OBJ_CONE].funp =
31 ofun[OBJ_CUP].funp =
32 ofun[OBJ_CYLINDER].funp =
33 ofun[OBJ_TUBE].funp = o_cone;
34 ofun[OBJ_RING].funp = o_ring;
35 ofun[OBJ_SOURCE].funp = o_source;
36 ofun[OBJ_INSTANCE].funp = o_instance;
37 ofun[OBJ_MESH].funp = o_unsupported;
38 /* assign material types */
39 ofun[MAT_TRANS].funp =
40 ofun[MAT_PLASTIC].funp =
41 ofun[MAT_METAL].funp = m_normal;
42 ofun[MAT_GLASS].funp =
43 ofun[MAT_DIELECTRIC].funp =
44 ofun[MAT_INTERFACE].funp = m_glass;
45 ofun[MAT_PLASTIC2].funp =
46 ofun[MAT_METAL2].funp =
47 ofun[MAT_TRANS2].funp = m_aniso;
48 ofun[MAT_TDATA].funp =
49 ofun[MAT_PDATA].funp =
50 ofun[MAT_MDATA].funp =
51 ofun[MAT_TFUNC].funp =
52 ofun[MAT_PFUNC].funp =
53 ofun[MAT_MFUNC].funp = m_brdf;
54 ofun[MAT_BRTDF].funp = m_brdf2;
55 ofun[MAT_GLOW].funp =
56 ofun[MAT_LIGHT].funp =
57 ofun[MAT_SPOT].funp =
58 ofun[MAT_ILLUM].funp = m_light;
59 ofun[MAT_MIRROR].funp = m_mirror;
60 ofun[MAT_DIRECT1].funp =
61 ofun[MAT_DIRECT2].funp = m_prism;
62 }
63
64
65 int
66 newglist() /* allocate an OGL list id */
67 {
68 if (!nlistleft--) {
69 nextlist = glGenLists(NLIST2ALLOC);
70 if (!nextlist)
71 error(SYSTEM, "no list space left in newglist");
72 nlistleft = NLIST2ALLOC-1;
73 }
74 return(nextlist++);
75 }
76
77
78 void
79 rgl_checkerr(where) /* check for GL or GLU error */
80 char *where;
81 {
82 register GLenum errcode;
83
84 while ((errcode = glGetError()) != GL_NO_ERROR) {
85 sprintf(errmsg, "OpenGL error %s: %s",
86 where, gluErrorString(errcode));
87 error(WARNING, errmsg);
88 }
89 }
90
91
92 int
93 rgl_filelist(ic, inp, nl) /* load scene files into display list */
94 int ic;
95 char **inp;
96 int *nl; /* returned number of lists (optional) */
97 {
98 int listid;
99
100 initotypes(); /* prepare */
101 listid = newglist();
102 glNewList(listid, GL_COMPILE);
103 lightinit(); /* start light source list */
104 while (ic--) /* load each file */
105 rgl_load(*inp++);
106 surfclean(); /* clean up first pass */
107 lightclean(); /* clean up light sources also */
108 glEndList(); /* end of top display list */
109 lightdefs(); /* define light sources */
110 loadoctrees(); /* load octrees (sublists) for instances */
111 if (nl != NULL) /* return total number of lists allocated */
112 *nl = nextlist - listid;
113 return(listid); /* all done -- return list id */
114 }
115
116
117 int
118 rgl_octlist(fname, cent, radp, nl) /* load scen into display list */
119 char *fname;
120 FVECT cent; /* returned octree center (optional) */
121 FLOAT *radp; /* returned octree size (optional) */
122 int *nl; /* returned number of lists (optional) */
123 {
124 double r;
125 int listid;
126 /* modeled after rgl_filelist() */
127 initotypes();
128 /* check the octree and get its size */
129 r = checkoct(fname, cent);
130 if (radp != NULL) *radp = r;
131 /* start the display list */
132 listid = newglist();
133 glNewList(listid, GL_COMPILE);
134 lightinit(); /* start light source list */
135 loadoct(fname); /* load octree objects into display list */
136 surfclean(); /* clean up and close top list */
137 lightclean(); /* clean up light sources also */
138 glEndList(); /* close top list */
139 lightdefs(); /* define light sources */
140 loadoctrees(); /* load referenced octrees into sublists */
141 if (nl != NULL) /* return total number of lists allocated */
142 *nl = nextlist - listid;
143 return(listid);
144 }
145
146
147 void
148 rgl_load(inpspec) /* convert scene description into OGL calls */
149 char *inpspec;
150 {
151 FILE *popen();
152 char *fgetline();
153 FILE *infp;
154 char buf[1024];
155 register int c;
156
157 if (inpspec == NULL) {
158 infp = stdin;
159 inpspec = "standard input";
160 } else if (inpspec[0] == '!') {
161 if ((infp = popen(inpspec+1, "r")) == NULL) {
162 sprintf(errmsg, "cannot execute \"%s\"", inpspec);
163 error(SYSTEM, errmsg);
164 }
165 } else if ((infp = fopen(inpspec, "r")) == NULL) {
166 sprintf(errmsg, "cannot open scene file \"%s\"", inpspec);
167 error(SYSTEM, errmsg);
168 }
169 while ((c = getc(infp)) != EOF) {
170 if (isspace(c))
171 continue;
172 if (c == '#') { /* comment */
173 fgets(buf, sizeof(buf), infp);
174 } else if (c == '!') { /* command */
175 ungetc(c, infp);
176 fgetline(buf, sizeof(buf), infp);
177 rgl_load(buf);
178 } else { /* object */
179 ungetc(c, infp);
180 rgl_object(inpspec, infp);
181 }
182 }
183 if (inpspec[0] == '!')
184 pclose(infp);
185 else
186 fclose(infp);
187 }
188
189
190 void
191 rgl_object(name, fp) /* read the next object */
192 char *name;
193 FILE *fp;
194 {
195 static OBJREC ob;
196 char sbuf[MAXSTR];
197 int rval;
198 /* get modifier */
199 strcpy(sbuf, "EOF");
200 fgetword(sbuf, MAXSTR, fp);
201 ob.omod = 0; /* use ob.os for pointer to material */
202 if (!strcmp(sbuf, VOIDID) || !strcmp(sbuf, ALIASMOD))
203 ob.os = NULL;
204 else
205 ob.os = (char *)getmatp(sbuf);
206 /* get type */
207 strcpy(sbuf, "EOF");
208 fgetword(sbuf, MAXSTR, fp);
209 if ((ob.otype = otype(sbuf)) < 0) {
210 sprintf(errmsg, "(%s): unknown type \"%s\"", name, sbuf);
211 error(USER, errmsg);
212 }
213 /* get identifier */
214 sbuf[0] = '\0';
215 fgetword(sbuf, MAXSTR, fp);
216 ob.oname = sbuf;
217 /* get arguments */
218 if (ob.otype == MOD_ALIAS) {
219 char sbuf2[MAXSTR]; /* get alias */
220 strcpy(sbuf2, "EOF");
221 fgetword(sbuf2, MAXSTR, fp);
222 if (ob.os == NULL)
223 ob.os = (char *)getmatp(sbuf2);
224 o_default(&ob); /* fake reference */
225 return;
226 }
227 if ((rval = readfargs(&ob.oargs, fp)) == 0) {
228 sprintf(errmsg, "(%s): bad arguments", name);
229 objerror(&ob, USER, errmsg);
230 } else if (rval < 0) {
231 sprintf(errmsg, "(%s): error reading scene", name);
232 error(SYSTEM, errmsg);
233 }
234 /* execute */
235 (*ofun[ob.otype].funp)(&ob);
236 /* free arguments */
237 freefargs(&ob.oargs);
238 }
