root/radiance/ray/src/common/rglfile.c
Revision: 3.6
Committed: Tue Mar 11 19:29:04 2003 UTC (22 years, 4 months ago) by greg
Changes since 3.5: +3 -5 lines
5 * Load Radiance object(s) and create OpenGL display lists
6 */
7
8 #include "copyright.h"
9
10 #include "radogl.h"
11
12 #ifndef NLIST2ALLOC
13 #define NLIST2ALLOC 16 /* batch of display lists to get */
14 #endif
15
16 FUN ofun[NUMOTYPE] = INIT_OTYPE;
17
18 static int nextlist, nlistleft = 0;
19
20
21 static void
22 initotypes() /* initialize ofun array */
23 {
24 if (ofun[OBJ_SPHERE].funp == o_sphere)
25 return; /* already done */
26 /* assign surface types */
27 ofun[OBJ_SPHERE].funp =
28 ofun[OBJ_BUBBLE].funp = o_sphere;
29 ofun[OBJ_FACE].funp = o_face;
30 ofun[OBJ_CONE].funp =
31 ofun[OBJ_CUP].funp =
32 ofun[OBJ_CYLINDER].funp =
33 ofun[OBJ_TUBE].funp = o_cone;
34 ofun[OBJ_RING].funp = o_ring;
35 ofun[OBJ_SOURCE].funp = o_source;
36 ofun[OBJ_INSTANCE].funp = o_instance;
37 /* assign material types */
38 ofun[MAT_TRANS].funp =
39 ofun[MAT_PLASTIC].funp =
40 ofun[MAT_METAL].funp = m_normal;
41 ofun[MAT_GLASS].funp =
42 ofun[MAT_DIELECTRIC].funp =
43 ofun[MAT_INTERFACE].funp = m_glass;
44 ofun[MAT_PLASTIC2].funp =
45 ofun[MAT_METAL2].funp =
46 ofun[MAT_TRANS2].funp = m_aniso;
47 ofun[MAT_TDATA].funp =
48 ofun[MAT_PDATA].funp =
49 ofun[MAT_MDATA].funp =
50 ofun[MAT_TFUNC].funp =
51 ofun[MAT_PFUNC].funp =
52 ofun[MAT_MFUNC].funp = m_brdf;
53 ofun[MAT_BRTDF].funp = m_brdf2;
54 ofun[MAT_GLOW].funp =
55 ofun[MAT_LIGHT].funp =
56 ofun[MAT_SPOT].funp =
57 ofun[MAT_ILLUM].funp = m_light;
58 ofun[MAT_MIRROR].funp = m_mirror;
59 ofun[MAT_DIRECT1].funp =
60 ofun[MAT_DIRECT2].funp = m_prism;
61 }
62
63
64 int
65 newglist() /* allocate an OGL list id */
66 {
67 if (!nlistleft--) {
68 nextlist = glGenLists(NLIST2ALLOC);
69 if (!nextlist)
70 error(SYSTEM, "no list space left in newglist");
71 nlistleft = NLIST2ALLOC-1;
72 }
73 return(nextlist++);
74 }
75
76
77 void
78 rgl_checkerr(where) /* check for GL or GLU error */
79 char *where;
80 {
81 register GLenum errcode;
82
83 while ((errcode = glGetError()) != GL_NO_ERROR) {
84 sprintf(errmsg, "OpenGL error %s: %s",
85 where, gluErrorString(errcode));
86 error(WARNING, errmsg);
87 }
88 }
89
90
91 int
92 rgl_filelist(ic, inp, nl) /* load scene files into display list */
93 int ic;
94 char **inp;
95 int *nl; /* returned number of lists (optional) */
96 {
97 int listid;
98
99 initotypes(); /* prepare */
100 listid = newglist();
101 glNewList(listid, GL_COMPILE);
102 lightinit(); /* start light source list */
103 while (ic--) /* load each file */
104 rgl_load(*inp++);
105 surfclean(); /* clean up first pass */
106 lightclean(); /* clean up light sources also */
107 glEndList(); /* end of top display list */
108 lightdefs(); /* define light sources */
109 loadoctrees(); /* load octrees (sublists) for instances */
110 if (nl != NULL) /* return total number of lists allocated */
111 *nl = nextlist - listid;
112 return(listid); /* all done -- return list id */
113 }
114
115
116 int
117 rgl_octlist(fname, cent, radp, nl) /* load scen into display list */
118 char *fname;
119 FVECT cent; /* returned octree center (optional) */
120 FLOAT *radp; /* returned octree size (optional) */
121 int *nl; /* returned number of lists (optional) */
122 {
123 double r;
124 int listid;
125 /* modeled after rgl_filelist() */
126 initotypes();
127 /* check the octree and get its size */
128 r = checkoct(fname, cent);
129 if (radp != NULL) *radp = r;
130 /* start the display list */
131 listid = newglist();
132 glNewList(listid, GL_COMPILE);
133 lightinit(); /* start light source list */
134 loadoct(fname); /* load octree objects into display list */
135 surfclean(); /* clean up and close top list */
136 lightclean(); /* clean up light sources also */
137 glEndList(); /* close top list */
138 lightdefs(); /* define light sources */
139 loadoctrees(); /* load referenced octrees into sublists */
140 if (nl != NULL) /* return total number of lists allocated */
141 *nl = nextlist - listid;
142 return(listid);
143 }
144
145
146 void
147 rgl_load(inpspec) /* convert scene description into OGL calls */
148 char *inpspec;
149 {
150 FILE *popen();
151 char *fgetline();
152 FILE *infp;
153 char buf[1024];
154 register int c;
155
156 if (inpspec == NULL) {
157 infp = stdin;
158 inpspec = "standard input";
159 } else if (inpspec[0] == '!') {
160 if ((infp = popen(inpspec+1, "r")) == NULL) {
161 sprintf(errmsg, "cannot execute \"%s\"", inpspec);
162 error(SYSTEM, errmsg);
163 }
164 } else if ((infp = fopen(inpspec, "r")) == NULL) {
165 sprintf(errmsg, "cannot open scene file \"%s\"", inpspec);
166 error(SYSTEM, errmsg);
167 }
168 while ((c = getc(infp)) != EOF) {
169 if (isspace(c))
170 continue;
171 if (c == '#') { /* comment */
172 fgets(buf, sizeof(buf), infp);
173 } else if (c == '!') { /* command */
174 ungetc(c, infp);
175 fgetline(buf, sizeof(buf), infp);
176 rgl_load(buf);
177 } else { /* object */
178 ungetc(c, infp);
179 rgl_object(inpspec, infp);
180 }
181 }
182 if (inpspec[0] == '!')
183 pclose(infp);
184 else
185 fclose(infp);
186 }
187
188
189 void
190 rgl_object(name, fp) /* read the next object */
191 char *name;
192 FILE *fp;
193 {
194 static OBJREC ob;
195 char sbuf[MAXSTR];
196 int rval;
197 /* get modifier */
198 strcpy(sbuf, "EOF");
199 fgetword(sbuf, MAXSTR, fp);
200 ob.omod = 0; /* use ob.os for pointer to material */
201 if (!strcmp(sbuf, VOIDID) || !strcmp(sbuf, ALIASMOD))
202 ob.os = NULL;
203 else
204 ob.os = (char *)getmatp(sbuf);
205 /* get type */
206 strcpy(sbuf, "EOF");
207 fgetword(sbuf, MAXSTR, fp);
208 if ((ob.otype = otype(sbuf)) < 0) {
209 sprintf(errmsg, "(%s): unknown type \"%s\"", name, sbuf);
210 error(USER, errmsg);
211 }
212 /* get identifier */
213 sbuf[0] = '\0';
214 fgetword(sbuf, MAXSTR, fp);
215 ob.oname = sbuf;
216 /* get arguments */
217 if (ob.otype == MOD_ALIAS) {
218 char sbuf2[MAXSTR]; /* get alias */
219 strcpy(sbuf2, "EOF");
220 fgetword(sbuf2, MAXSTR, fp);
221 if (ob.os == NULL)
222 ob.os = (char *)getmatp(sbuf2);
223 o_default(&ob); /* fake reference */
224 return;
225 }
226 if ((rval = readfargs(&ob.oargs, fp)) == 0) {
227 sprintf(errmsg, "(%s): bad arguments", name);
228 objerror(&ob, USER, errmsg);
229 } else if (rval < 0) {
230 sprintf(errmsg, "(%s): error reading scene", name);
231 error(SYSTEM, errmsg);
232 }
233 /* execute */
234 (*ofun[ob.otype].funp)(&ob);
235 /* free arguments */
236 freefargs(&ob.oargs);
237 }
