root/Development/ray/src/common/rglfile.c
Revision: 3.11
Committed: Sun Mar 28 20:33:12 2004 UTC (21 years, 8 months ago) by schorsch
CVS Tags: rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6
Changes since 3.10: +3 -3 lines
2 static const char RCSid[] = "$Id: rglfile.c,v 3.10 2003/11/14 17:22:06 schorsch Exp $";
5 * Load Radiance object(s) and create OpenGL display lists
6 */
7
8 #include "copyright.h"
9
10 #include <ctype.h>
11
12 #include "rtprocess.h"
13 #include "radogl.h"
14
15 #ifndef NLIST2ALLOC
16 #define NLIST2ALLOC 16 /* batch of display lists to get */
17 #endif
18
19 FUN ofun[NUMOTYPE] = INIT_OTYPE;
20
21 static int nextlist, nlistleft = 0;
22
23
24 void
25 initotypes(void) /* initialize ofun array */
26 {
27 if (ofun[OBJ_SPHERE].funp == o_sphere)
28 return; /* already done */
29 /* assign surface types */
30 ofun[OBJ_SPHERE].funp =
31 ofun[OBJ_BUBBLE].funp = o_sphere;
32 ofun[OBJ_FACE].funp = o_face;
33 ofun[OBJ_CONE].funp =
34 ofun[OBJ_CUP].funp =
35 ofun[OBJ_CYLINDER].funp =
36 ofun[OBJ_TUBE].funp = o_cone;
37 ofun[OBJ_RING].funp = o_ring;
38 ofun[OBJ_SOURCE].funp = o_source;
39 ofun[OBJ_INSTANCE].funp = o_instance;
40 ofun[OBJ_MESH].funp = o_unsupported;
41 /* assign material types */
42 ofun[MAT_TRANS].funp =
43 ofun[MAT_PLASTIC].funp =
44 ofun[MAT_METAL].funp = m_normal;
45 ofun[MAT_GLASS].funp =
46 ofun[MAT_DIELECTRIC].funp =
47 ofun[MAT_INTERFACE].funp = m_glass;
48 ofun[MAT_PLASTIC2].funp =
49 ofun[MAT_METAL2].funp =
50 ofun[MAT_TRANS2].funp = m_aniso;
51 ofun[MAT_TDATA].funp =
52 ofun[MAT_PDATA].funp =
53 ofun[MAT_MDATA].funp =
54 ofun[MAT_TFUNC].funp =
55 ofun[MAT_PFUNC].funp =
56 ofun[MAT_MFUNC].funp = m_brdf;
57 ofun[MAT_BRTDF].funp = m_brdf2;
58 ofun[MAT_GLOW].funp =
59 ofun[MAT_LIGHT].funp =
60 ofun[MAT_SPOT].funp =
61 ofun[MAT_ILLUM].funp = m_light;
62 ofun[MAT_MIRROR].funp = m_mirror;
63 ofun[MAT_DIRECT1].funp =
64 ofun[MAT_DIRECT2].funp = m_prism;
65 }
66
67
68 int
69 newglist() /* allocate an OGL list id */
70 {
71 if (!nlistleft--) {
72 nextlist = glGenLists(NLIST2ALLOC);
73 if (!nextlist)
74 error(SYSTEM, "no list space left in newglist");
75 nlistleft = NLIST2ALLOC-1;
76 }
77 return(nextlist++);
78 }
79
80
81 void
82 rgl_checkerr(where) /* check for GL or GLU error */
83 char *where;
84 {
85 register GLenum errcode;
86
87 while ((errcode = glGetError()) != GL_NO_ERROR) {
88 sprintf(errmsg, "OpenGL error %s: %s",
89 where, gluErrorString(errcode));
90 error(WARNING, errmsg);
91 }
92 }
93
94
95 int
96 rgl_filelist(ic, inp, nl) /* load scene files into display list */
97 int ic;
98 char **inp;
99 int *nl; /* returned number of lists (optional) */
100 {
101 int listid;
102
103 initotypes(); /* prepare */
104 listid = newglist();
105 glNewList(listid, GL_COMPILE);
106 lightinit(); /* start light source list */
107 while (ic--) /* load each file */
108 rgl_load(*inp++);
109 surfclean(); /* clean up first pass */
110 lightclean(); /* clean up light sources also */
111 glEndList(); /* end of top display list */
112 lightdefs(); /* define light sources */
113 loadoctrees(); /* load octrees (sublists) for instances */
114 if (nl != NULL) /* return total number of lists allocated */
115 *nl = nextlist - listid;
116 return(listid); /* all done -- return list id */
117 }
118
119
120 int
121 rgl_octlist(fname, cent, radp, nl) /* load scen into display list */
122 char *fname;
123 FVECT cent; /* returned octree center (optional) */
124 RREAL *radp; /* returned octree size (optional) */
125 int *nl; /* returned number of lists (optional) */
126 {
127 double r;
128 int listid;
129 /* modeled after rgl_filelist() */
130 initotypes();
131 /* check the octree and get its size */
132 r = checkoct(fname, cent);
133 if (radp != NULL) *radp = r;
134 /* start the display list */
135 listid = newglist();
136 glNewList(listid, GL_COMPILE);
137 lightinit(); /* start light source list */
138 loadoct(fname); /* load octree objects into display list */
139 surfclean(); /* clean up and close top list */
140 lightclean(); /* clean up light sources also */
141 glEndList(); /* close top list */
142 lightdefs(); /* define light sources */
143 loadoctrees(); /* load referenced octrees into sublists */
144 if (nl != NULL) /* return total number of lists allocated */
145 *nl = nextlist - listid;
146 return(listid);
147 }
148
149
150 void
151 rgl_load(inpspec) /* convert scene description into OGL calls */
152 char *inpspec;
153 {
154 char *fgetline();
155 FILE *infp;
156 char buf[1024];
157 register int c;
158
159 if (inpspec == NULL) {
160 infp = stdin;
161 inpspec = "standard input";
162 } else if (inpspec[0] == '!') {
163 if ((infp = popen(inpspec+1, "r")) == NULL) {
164 sprintf(errmsg, "cannot execute \"%s\"", inpspec);
165 error(SYSTEM, errmsg);
166 }
167 } else if ((infp = fopen(inpspec, "r")) == NULL) {
168 sprintf(errmsg, "cannot open scene file \"%s\"", inpspec);
169 error(SYSTEM, errmsg);
170 }
171 while ((c = getc(infp)) != EOF) {
172 if (isspace(c))
173 continue;
174 if (c == '#') { /* comment */
175 fgets(buf, sizeof(buf), infp);
176 } else if (c == '!') { /* command */
177 ungetc(c, infp);
178 fgetline(buf, sizeof(buf), infp);
179 rgl_load(buf);
180 } else { /* object */
181 ungetc(c, infp);
182 rgl_object(inpspec, infp);
183 }
184 }
185 if (inpspec[0] == '!')
186 pclose(infp);
187 else
188 fclose(infp);
189 }
190
191
192 void
193 rgl_object(name, fp) /* read the next object */
194 char *name;
195 FILE *fp;
196 {
197 static OBJREC ob;
198 char sbuf[MAXSTR];
199 int rval;
200 /* get modifier */
201 strcpy(sbuf, "EOF");
202 fgetword(sbuf, MAXSTR, fp);
203 ob.omod = 0; /* use ob.os for pointer to material */
204 if (!strcmp(sbuf, VOIDID) || !strcmp(sbuf, ALIASMOD))
205 ob.os = NULL;
206 else
207 ob.os = (char *)getmatp(sbuf);
208 /* get type */
209 strcpy(sbuf, "EOF");
210 fgetword(sbuf, MAXSTR, fp);
211 if ((ob.otype = otype(sbuf)) < 0) {
212 sprintf(errmsg, "(%s): unknown type \"%s\"", name, sbuf);
213 error(USER, errmsg);
214 }
215 /* get identifier */
216 sbuf[0] = '\0';
217 fgetword(sbuf, MAXSTR, fp);
218 ob.oname = sbuf;
219 /* get arguments */
220 if (ob.otype == MOD_ALIAS) {
221 char sbuf2[MAXSTR]; /* get alias */
222 strcpy(sbuf2, "EOF");
223 fgetword(sbuf2, MAXSTR, fp);
224 if (ob.os == NULL)
225 ob.os = (char *)getmatp(sbuf2);
226 o_default(&ob); /* fake reference */
227 return;
228 }
229 if ((rval = readfargs(&ob.oargs, fp)) == 0) {
230 sprintf(errmsg, "(%s): bad arguments", name);
231 objerror(&ob, USER, errmsg);
232 } else if (rval < 0) {
233 sprintf(errmsg, "(%s): error reading scene", name);
234 error(SYSTEM, errmsg);
235 }
236 /* execute */
237 (*ofun[ob.otype].funp)(&ob);
238 /* free arguments */
239 freefargs(&ob.oargs);
240 }
