root/radiance/ray/src/common/rglfile.c
Sun Mar 28 20:33:12 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 3.10: +3 -3 lines
Diff to previous 3.10 , to selected 3.5
Fri Nov 14 17:22:06 2003 UTC (21 years, 5 months ago) by schorsch
Changes since 3.9: +3 -1 lines
Diff to previous 3.9 , to selected 3.5
Mon Oct 27 10:19:31 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 3.8: +2 -2 lines
Diff to previous 3.8 , to selected 3.5
Thu Jun 26 00:58:09 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 3.7: +2 -2 lines
Diff to previous 3.7 , to selected 3.5
Wed Apr 23 02:28:06 2003 UTC (22 years ago) by greg
Changes since 3.6: +1 -0 lines
Diff to previous 3.6 , to selected 3.5
Added check for mesh primitive and warning when encountered
Tue Mar 11 19:29:04 2003 UTC (22 years, 1 month ago) by greg
Changes since 3.5: +3 -5 lines
Diff to previous 3.5
Revision 3.5 - (view) (download) (annotate) - [selected]
Tue Feb 25 02:47:22 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.4: +1 -56 lines
Diff to previous 3.4
Sat Feb 22 02:07:22 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.3: +62 -11 lines
Diff to previous 3.3 , to selected 3.5
Fri Jan 29 15:27:22 1999 UTC (26 years, 3 months ago) by gwlarson
Changes since 3.2: +14 -6 lines
Diff to previous 3.2 , to selected 3.5
return number of lists allocated for proper deallocation
Mon Aug 17 17:57:59 1998 UTC (26 years, 8 months ago) by gwlarson
Diff to previous 3.1 , to selected 3.5
changed return value from double * to FLOAT *
Tue Jun 9 11:18:35 1998 UTC (26 years, 11 months ago) by gwlarson
Diff to selected 3.5
