1 |
gwlarson |
3.1 |
#ifndef lint |
2 |
schorsch |
3.11 |
static const char RCSid[] = "$Id: rglfile.c,v 3.10 2003/11/14 17:22:06 schorsch Exp $"; |
3 |
gwlarson |
3.1 |
#endif |
4 |
5 |
* Load Radiance object(s) and create OpenGL display lists |
6 |
7 |
8 |
greg |
3.5 |
#include "copyright.h" |
9 |
schorsch |
3.10 |
10 |
#include <ctype.h> |
11 |
greg |
3.4 |
12 |
schorsch |
3.9 |
#include "rtprocess.h" |
13 |
gwlarson |
3.1 |
#include "radogl.h" |
14 |
15 |
#ifndef NLIST2ALLOC |
16 |
#define NLIST2ALLOC 16 /* batch of display lists to get */ |
17 |
#endif |
18 |
19 |
FUN ofun[NUMOTYPE] = INIT_OTYPE; |
20 |
21 |
gwlarson |
3.3 |
static int nextlist, nlistleft = 0; |
22 |
gwlarson |
3.1 |
23 |
gwlarson |
3.3 |
24 |
schorsch |
3.11 |
void |
25 |
initotypes(void) /* initialize ofun array */ |
26 |
gwlarson |
3.1 |
27 |
if (ofun[OBJ_SPHERE].funp == o_sphere) |
28 |
return; /* already done */ |
29 |
/* assign surface types */ |
30 |
ofun[OBJ_SPHERE].funp = |
31 |
ofun[OBJ_BUBBLE].funp = o_sphere; |
32 |
ofun[OBJ_FACE].funp = o_face; |
33 |
ofun[OBJ_CONE].funp = |
34 |
ofun[OBJ_CUP].funp = |
35 |
ofun[OBJ_CYLINDER].funp = |
36 |
ofun[OBJ_TUBE].funp = o_cone; |
37 |
ofun[OBJ_RING].funp = o_ring; |
38 |
ofun[OBJ_SOURCE].funp = o_source; |
39 |
ofun[OBJ_INSTANCE].funp = o_instance; |
40 |
greg |
3.7 |
ofun[OBJ_MESH].funp = o_unsupported; |
41 |
gwlarson |
3.1 |
/* assign material types */ |
42 |
ofun[MAT_TRANS].funp = |
43 |
ofun[MAT_PLASTIC].funp = |
44 |
ofun[MAT_METAL].funp = m_normal; |
45 |
ofun[MAT_GLASS].funp = |
46 |
ofun[MAT_DIELECTRIC].funp = |
47 |
ofun[MAT_INTERFACE].funp = m_glass; |
48 |
ofun[MAT_PLASTIC2].funp = |
49 |
ofun[MAT_METAL2].funp = |
50 |
ofun[MAT_TRANS2].funp = m_aniso; |
51 |
ofun[MAT_TDATA].funp = |
52 |
ofun[MAT_PDATA].funp = |
53 |
ofun[MAT_MDATA].funp = |
54 |
ofun[MAT_TFUNC].funp = |
55 |
ofun[MAT_PFUNC].funp = |
56 |
ofun[MAT_MFUNC].funp = m_brdf; |
57 |
ofun[MAT_BRTDF].funp = m_brdf2; |
58 |
ofun[MAT_GLOW].funp = |
59 |
ofun[MAT_LIGHT].funp = |
60 |
ofun[MAT_SPOT].funp = |
61 |
ofun[MAT_ILLUM].funp = m_light; |
62 |
ofun[MAT_MIRROR].funp = m_mirror; |
63 |
ofun[MAT_DIRECT1].funp = |
64 |
ofun[MAT_DIRECT2].funp = m_prism; |
65 |
66 |
67 |
68 |
int |
69 |
newglist() /* allocate an OGL list id */ |
70 |
71 |
gwlarson |
3.3 |
if (!nlistleft--) { |
72 |
gwlarson |
3.1 |
nextlist = glGenLists(NLIST2ALLOC); |
73 |
gwlarson |
3.3 |
if (!nextlist) |
74 |
error(SYSTEM, "no list space left in newglist"); |
75 |
nlistleft = NLIST2ALLOC-1; |
76 |
gwlarson |
3.1 |
77 |
return(nextlist++); |
78 |
79 |
80 |
81 |
greg |
3.4 |
void |
82 |
gwlarson |
3.1 |
rgl_checkerr(where) /* check for GL or GLU error */ |
83 |
char *where; |
84 |
85 |
register GLenum errcode; |
86 |
87 |
while ((errcode = glGetError()) != GL_NO_ERROR) { |
88 |
sprintf(errmsg, "OpenGL error %s: %s", |
89 |
where, gluErrorString(errcode)); |
90 |
error(WARNING, errmsg); |
91 |
92 |
93 |
94 |
95 |
int |
96 |
gwlarson |
3.3 |
rgl_filelist(ic, inp, nl) /* load scene files into display list */ |
97 |
gwlarson |
3.1 |
int ic; |
98 |
char **inp; |
99 |
gwlarson |
3.3 |
int *nl; /* returned number of lists (optional) */ |
100 |
gwlarson |
3.1 |
101 |
int listid; |
102 |
103 |
initotypes(); /* prepare */ |
104 |
listid = newglist(); |
105 |
glNewList(listid, GL_COMPILE); |
106 |
lightinit(); /* start light source list */ |
107 |
while (ic--) /* load each file */ |
108 |
rgl_load(*inp++); |
109 |
surfclean(); /* clean up first pass */ |
110 |
lightclean(); /* clean up light sources also */ |
111 |
glEndList(); /* end of top display list */ |
112 |
lightdefs(); /* define light sources */ |
113 |
loadoctrees(); /* load octrees (sublists) for instances */ |
114 |
gwlarson |
3.3 |
if (nl != NULL) /* return total number of lists allocated */ |
115 |
*nl = nextlist - listid; |
116 |
gwlarson |
3.1 |
return(listid); /* all done -- return list id */ |
117 |
118 |
119 |
120 |
int |
121 |
gwlarson |
3.3 |
rgl_octlist(fname, cent, radp, nl) /* load scen into display list */ |
122 |
gwlarson |
3.1 |
char *fname; |
123 |
FVECT cent; /* returned octree center (optional) */ |
124 |
schorsch |
3.8 |
RREAL *radp; /* returned octree size (optional) */ |
125 |
gwlarson |
3.3 |
126 |
gwlarson |
3.1 |
127 |
double r; |
128 |
int listid; |
129 |
/* modeled after rgl_filelist() */ |
130 |
initotypes(); |
131 |
/* check the octree and get its size */ |
132 |
r = checkoct(fname, cent); |
133 |
if (radp != NULL) *radp = r; |
134 |
/* start the display list */ |
135 |
136 |
137 |
138 |
loadoct(fname); /* load octree objects into display list */ |
139 |
surfclean(); /* clean up and close top list */ |
140 |
141 |
glEndList(); /* close top list */ |
142 |
143 |
loadoctrees(); /* load referenced octrees into sublists */ |
144 |
gwlarson |
3.3 |
145 |
146 |
gwlarson |
3.1 |
return(listid); |
147 |
148 |
149 |
150 |
greg |
3.4 |
void |
151 |
gwlarson |
3.1 |
rgl_load(inpspec) /* convert scene description into OGL calls */ |
152 |
char *inpspec; |
153 |
154 |
char *fgetline(); |
155 |
FILE *infp; |
156 |
char buf[1024]; |
157 |
register int c; |
158 |
159 |
if (inpspec == NULL) { |
160 |
infp = stdin; |
161 |
inpspec = "standard input"; |
162 |
} else if (inpspec[0] == '!') { |
163 |
if ((infp = popen(inpspec+1, "r")) == NULL) { |
164 |
sprintf(errmsg, "cannot execute \"%s\"", inpspec); |
165 |
error(SYSTEM, errmsg); |
166 |
167 |
} else if ((infp = fopen(inpspec, "r")) == NULL) { |
168 |
sprintf(errmsg, "cannot open scene file \"%s\"", inpspec); |
169 |
170 |
171 |
while ((c = getc(infp)) != EOF) { |
172 |
if (isspace(c)) |
173 |
continue; |
174 |
if (c == '#') { /* comment */ |
175 |
fgets(buf, sizeof(buf), infp); |
176 |
} else if (c == '!') { /* command */ |
177 |
ungetc(c, infp); |
178 |
fgetline(buf, sizeof(buf), infp); |
179 |
rgl_load(buf); |
180 |
} else { /* object */ |
181 |
ungetc(c, infp); |
182 |
rgl_object(inpspec, infp); |
183 |
184 |
185 |
if (inpspec[0] == '!') |
186 |
pclose(infp); |
187 |
else |
188 |
fclose(infp); |
189 |
190 |
191 |
192 |
greg |
3.4 |
void |
193 |
gwlarson |
3.1 |
rgl_object(name, fp) /* read the next object */ |
194 |
char *name; |
195 |
FILE *fp; |
196 |
197 |
static OBJREC ob; |
198 |
char sbuf[MAXSTR]; |
199 |
int rval; |
200 |
/* get modifier */ |
201 |
strcpy(sbuf, "EOF"); |
202 |
fgetword(sbuf, MAXSTR, fp); |
203 |
ob.omod = 0; /* use ob.os for pointer to material */ |
204 |
greg |
3.6 |
if (!strcmp(sbuf, VOIDID) || !strcmp(sbuf, ALIASMOD)) |
205 |
gwlarson |
3.1 |
ob.os = NULL; |
206 |
else |
207 |
ob.os = (char *)getmatp(sbuf); |
208 |
/* get type */ |
209 |
210 |
211 |
greg |
3.6 |
if ((ob.otype = otype(sbuf)) < 0) { |
212 |
gwlarson |
3.1 |
sprintf(errmsg, "(%s): unknown type \"%s\"", name, sbuf); |
213 |
error(USER, errmsg); |
214 |
215 |
/* get identifier */ |
216 |
sbuf[0] = '\0'; |
217 |
218 |
ob.oname = sbuf; |
219 |
/* get arguments */ |
220 |
greg |
3.6 |
if (ob.otype == MOD_ALIAS) { |
221 |
gwlarson |
3.1 |
char sbuf2[MAXSTR]; /* get alias */ |
222 |
strcpy(sbuf2, "EOF"); |
223 |
fgetword(sbuf2, MAXSTR, fp); |
224 |
if (ob.os == NULL) |
225 |
ob.os = (char *)getmatp(sbuf2); |
226 |
o_default(&ob); /* fake reference */ |
227 |
return; |
228 |
229 |
if ((rval = readfargs(&ob.oargs, fp)) == 0) { |
230 |
sprintf(errmsg, "(%s): bad arguments", name); |
231 |
objerror(&ob, USER, errmsg); |
232 |
} else if (rval < 0) { |
233 |
sprintf(errmsg, "(%s): error reading scene", name); |
234 |
235 |
236 |
/* execute */ |
237 |
(*ofun[ob.otype].funp)(&ob); |
238 |
/* free arguments */ |
239 |
freefargs(&ob.oargs); |
240 |
