root/radiance/ray/src/common/rexpr.c
Revision: 2.9
Committed: Thu Jul 17 09:21:29 2003 UTC (20 years, 9 months ago) by schorsch
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1
Changes since 2.8: +10 -7 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 2.9 static const char RCSid[] = "$Id: rexpr.c,v 2.8 2003/06/30 14:59:11 schorsch Exp $";
3 greg 1.1 #endif
4 greg 2.4 /*
5     * Regular expression parsing routines.
6     *
7     * External symbols declared in standard.h
8     */
9
10 greg 2.5 #include "copyright.h"
11 greg 1.1
12     #include <stdio.h>
13 greg 2.4 #include <stdlib.h>
14 greg 1.1 #include <ctype.h>
15 schorsch 2.7 #include <string.h>
16
17 schorsch 2.9 #include "rtio.h"
18
19 greg 1.1 /*
20     * rexpr.c - regular expression parser (ala grep)
21     */
22
23     #define CCHR 2
24     #define CDOT 4
25     #define CCL 6
26     #define NCCL 8
27     #define CDOL 10
28     #define CEOF 11
29     #define CBRC 14
30     #define CLET 15
31     #define STAR 01
32
33     #define ESIZE 255
34
35     #define same(a,b) (a==b || (iflag && (a^b)==' ' && isalpha(a)))
36
37 greg 1.2
38 schorsch 2.9 static int advance(char *, char *);
39     static int cclass(char *, int c, int af);
40 greg 1.4
41 greg 1.1 static char expbuf[ESIZE];
42     static int iflag;
43     static int circf;
44
45     int explen; /* length of the last expression found */
46
47     int
48     ecompile(sp, iflg, wflag) /* compile the expression */
49     register char *sp;
50     int iflg, wflag;
51     {
52 schorsch 2.9 register int c;
53 greg 1.1 register char *ep;
54 schorsch 2.9 char *lastep = NULL;
55 greg 1.1 int cclcnt;
56
57     iflag = iflg;
58     ep = expbuf;
59     explen = 0;
60     if (*sp == '^') {
61     circf = 1;
62     sp++;
63     } else
64     circf = 0;
65     if (wflag)
66     *ep++ = CBRC;
67     for (;;) {
68     if (ep >= &expbuf[ESIZE])
69     return(-1);
70     if ((c = *sp++) != '*')
71     lastep = ep;
72     switch (c) {
73
74     case '\0':
75     if (wflag)
76     *ep++ = CLET;
77     *ep++ = CEOF;
78     explen = ep - expbuf;
79     return(0);
80
81     case '.':
82     *ep++ = CDOT;
83     continue;
84
85     case '*':
86     if (lastep==0)
87     goto defchar;
88     *lastep |= STAR;
89     continue;
90
91     case '$':
92     if (*sp != '\0')
93     goto defchar;
94     *ep++ = CDOL;
95     continue;
96
97     case '[':
98     *ep++ = CCL;
99     *ep++ = 0;
100     cclcnt = 1;
101     if ((c = *sp++) == '^') {
102     c = *sp++;
103     ep[-2] = NCCL;
104     }
105     do {
106     *ep++ = c;
107     cclcnt++;
108     if (c=='\0' || ep >= &expbuf[ESIZE])
109     return(-1);
110     } while ((c = *sp++) != ']');
111     lastep[1] = cclcnt;
112     continue;
113
114     case '\\':
115     if ((c = *sp++) == '\0')
116     return(-1);
117     if (c == '<') {
118 greg 2.2 if (ep == expbuf || ep[-1] != CBRC)
119     *ep++ = CBRC;
120 greg 1.1 continue;
121     }
122     if (c == '>') {
123     *ep++ = CLET;
124     continue;
125     }
126     defchar:
127     default:
128     *ep++ = CCHR;
129     *ep++ = c;
130     }
131     }
132     }
133
134     char *
135     expsave() /* save compiled string */
136     {
137     register char *ep;
138
139     if (explen == 0)
140     return(NULL);
141 greg 2.4 if ((ep = (char *)malloc(explen+3)) == NULL)
142 greg 1.1 return(NULL);
143     ep[0] = iflag;
144     ep[1] = circf;
145     ep[2] = explen;
146     (void)memcpy(ep+3, expbuf, explen);
147     return(ep);
148     }
149
150 greg 2.4 void
151 greg 1.1 expset(ep) /* install saved string */
152     register char *ep;
153     {
154     iflag = ep[0];
155     circf = ep[1];
156     (void)memcpy(expbuf, ep+3, ep[2]&0xff);
157     }
158
159     char *
160 greg 2.2 eindex(sp) /* find the expression in string sp */
161 greg 1.1 register char *sp;
162     {
163 greg 2.2 /* check for match at beginning of line, watch CBRC */
164     if (advance(sp, expbuf[0]==CBRC ? expbuf+1 : expbuf))
165     return(sp);
166     if (circf)
167 greg 1.1 return(NULL);
168     /* fast check for first character */
169     if (expbuf[0]==CCHR) {
170 schorsch 2.9 register int c = expbuf[1];
171 greg 2.2 while (*++sp)
172 greg 1.1 if (same(*sp, c) && advance(sp, expbuf))
173     return(sp);
174     return(NULL);
175     }
176     /* regular algorithm */
177 greg 2.2 while (*++sp)
178 greg 1.1 if (advance(sp, expbuf))
179     return(sp);
180     return(NULL);
181     }
182
183     static int
184     advance(alp, ep)
185     char *alp;
186     register char *ep;
187     {
188     register char *lp;
189     char *curlp;
190
191     lp = alp;
192     for (;;) switch (*ep++) {
193
194     case CCHR:
195     if (!same(*ep, *lp))
196     return (0);
197     ep++, lp++;
198     continue;
199
200     case CDOT:
201     if (*lp++)
202     continue;
203     return(0);
204
205     case CDOL:
206     if (*lp==0)
207     continue;
208     return(0);
209
210     case CEOF:
211     explen = lp - alp;
212     return(1);
213
214     case CCL:
215     if (cclass(ep, *lp++, 1)) {
216     ep += *ep;
217     continue;
218     }
219     return(0);
220
221     case NCCL:
222     if (cclass(ep, *lp++, 0)) {
223     ep += *ep;
224     continue;
225     }
226     return(0);
227
228     case CDOT|STAR:
229     curlp = lp;
230     while (*lp++);
231     goto star;
232
233     case CCHR|STAR:
234     curlp = lp;
235     while (same(*lp, *ep))
236     lp++;
237     lp++;
238     ep++;
239     goto star;
240
241     case CCL|STAR:
242     case NCCL|STAR:
243     curlp = lp;
244     while (cclass(ep, *lp++, ep[-1]==(CCL|STAR)));
245     ep += *ep;
246     star:
247     do {
248     lp--;
249     if (advance(lp, ep)) {
250     explen += lp - alp;
251     return(1);
252     }
253     } while (lp > curlp);
254     return(0);
255
256     case CBRC:
257     if ((isalnum(*lp) || *lp == '_') && !(isalnum(lp[-1]) || lp[-1] == '_'))
258     continue;
259     return (0);
260
261     case CLET:
262     if (!isalnum(*lp) && *lp != '_')
263     continue;
264     return (0);
265
266     default:
267     fprintf(stderr, "RE botch\n");
268     }
269     }
270
271     static int
272     cclass(set, c, af)
273     register char *set;
274 schorsch 2.9 register int c;
275 greg 2.3 int af;
276 greg 1.1 {
277 schorsch 2.9 register int n;
278 greg 1.1
279     if (c == 0)
280     return(0);
281     n = *set++;
282     while (--n)
283     if (n > 2 && set[1] == '-') {
284     if (c >= set[0] && c <= set[2])
285     return (af);
286     set += 3;
287     n -= 2;
288     } else
289     if (*set++ == c)
290     return(af);
291     return(!af);
292     }
