| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rexpr.c,v 2.8 2003/06/30 14:59:11 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Regular expression parsing routines.
| 6 |
| 7 |
* External symbols declared in standard.h
| 8 |
| 9 |
| 10 |
#include "copyright.h"
| 11 |
| 12 |
#include <stdio.h>
| 13 |
#include <stdlib.h>
| 14 |
#include <ctype.h>
| 15 |
#include <string.h>
| 16 |
| 17 |
#include "rtio.h"
| 18 |
| 19 |
| 20 |
* rexpr.c - regular expression parser (ala grep)
| 21 |
| 22 |
| 23 |
#define CCHR 2
| 24 |
#define CDOT 4
| 25 |
#define CCL 6
| 26 |
#define NCCL 8
| 27 |
#define CDOL 10
| 28 |
#define CEOF 11
| 29 |
#define CBRC 14
| 30 |
#define CLET 15
| 31 |
#define STAR 01
| 32 |
| 33 |
#define ESIZE 255
| 34 |
| 35 |
#define same(a,b) (a==b || (iflag && (a^b)==' ' && isalpha(a)))
| 36 |
| 37 |
| 38 |
static int advance(char *, char *);
| 39 |
static int cclass(char *, int c, int af);
| 40 |
| 41 |
static char expbuf[ESIZE];
| 42 |
static int iflag;
| 43 |
static int circf;
| 44 |
| 45 |
int explen; /* length of the last expression found */
| 46 |
| 47 |
int
| 48 |
ecompile(sp, iflg, wflag) /* compile the expression */
| 49 |
register char *sp;
| 50 |
int iflg, wflag;
| 51 |
| 52 |
register int c;
| 53 |
register char *ep;
| 54 |
char *lastep = NULL;
| 55 |
int cclcnt;
| 56 |
| 57 |
iflag = iflg;
| 58 |
ep = expbuf;
| 59 |
explen = 0;
| 60 |
if (*sp == '^') {
| 61 |
circf = 1;
| 62 |
sp++;
| 63 |
} else
| 64 |
circf = 0;
| 65 |
if (wflag)
| 66 |
*ep++ = CBRC;
| 67 |
for (;;) {
| 68 |
if (ep >= &expbuf[ESIZE])
| 69 |
return(-1);
| 70 |
if ((c = *sp++) != '*')
| 71 |
lastep = ep;
| 72 |
switch (c) {
| 73 |
| 74 |
case '\0':
| 75 |
if (wflag)
| 76 |
*ep++ = CLET;
| 77 |
*ep++ = CEOF;
| 78 |
explen = ep - expbuf;
| 79 |
return(0);
| 80 |
| 81 |
case '.':
| 82 |
*ep++ = CDOT;
| 83 |
continue;
| 84 |
| 85 |
case '*':
| 86 |
if (lastep==0)
| 87 |
goto defchar;
| 88 |
*lastep |= STAR;
| 89 |
continue;
| 90 |
| 91 |
case '$':
| 92 |
if (*sp != '\0')
| 93 |
goto defchar;
| 94 |
*ep++ = CDOL;
| 95 |
continue;
| 96 |
| 97 |
case '[':
| 98 |
*ep++ = CCL;
| 99 |
*ep++ = 0;
| 100 |
cclcnt = 1;
| 101 |
if ((c = *sp++) == '^') {
| 102 |
c = *sp++;
| 103 |
ep[-2] = NCCL;
| 104 |
| 105 |
do {
| 106 |
*ep++ = c;
| 107 |
cclcnt++;
| 108 |
if (c=='\0' || ep >= &expbuf[ESIZE])
| 109 |
return(-1);
| 110 |
} while ((c = *sp++) != ']');
| 111 |
lastep[1] = cclcnt;
| 112 |
continue;
| 113 |
| 114 |
case '\\':
| 115 |
if ((c = *sp++) == '\0')
| 116 |
return(-1);
| 117 |
if (c == '<') {
| 118 |
if (ep == expbuf || ep[-1] != CBRC)
| 119 |
*ep++ = CBRC;
| 120 |
continue;
| 121 |
| 122 |
if (c == '>') {
| 123 |
*ep++ = CLET;
| 124 |
continue;
| 125 |
| 126 |
defchar:
| 127 |
default:
| 128 |
*ep++ = CCHR;
| 129 |
*ep++ = c;
| 130 |
| 131 |
| 132 |
| 133 |
| 134 |
char *
| 135 |
expsave() /* save compiled string */
| 136 |
| 137 |
register char *ep;
| 138 |
| 139 |
if (explen == 0)
| 140 |
return(NULL);
| 141 |
if ((ep = (char *)malloc(explen+3)) == NULL)
| 142 |
return(NULL);
| 143 |
ep[0] = iflag;
| 144 |
ep[1] = circf;
| 145 |
ep[2] = explen;
| 146 |
(void)memcpy(ep+3, expbuf, explen);
| 147 |
return(ep);
| 148 |
| 149 |
| 150 |
void
| 151 |
expset(ep) /* install saved string */
| 152 |
register char *ep;
| 153 |
| 154 |
iflag = ep[0];
| 155 |
circf = ep[1];
| 156 |
(void)memcpy(expbuf, ep+3, ep[2]&0xff);
| 157 |
| 158 |
| 159 |
char *
| 160 |
eindex(sp) /* find the expression in string sp */
| 161 |
register char *sp;
| 162 |
| 163 |
/* check for match at beginning of line, watch CBRC */
| 164 |
if (advance(sp, expbuf[0]==CBRC ? expbuf+1 : expbuf))
| 165 |
return(sp);
| 166 |
if (circf)
| 167 |
return(NULL);
| 168 |
/* fast check for first character */
| 169 |
if (expbuf[0]==CCHR) {
| 170 |
register int c = expbuf[1];
| 171 |
while (*++sp)
| 172 |
if (same(*sp, c) && advance(sp, expbuf))
| 173 |
return(sp);
| 174 |
return(NULL);
| 175 |
| 176 |
/* regular algorithm */
| 177 |
while (*++sp)
| 178 |
if (advance(sp, expbuf))
| 179 |
return(sp);
| 180 |
return(NULL);
| 181 |
| 182 |
| 183 |
static int
| 184 |
advance(alp, ep)
| 185 |
char *alp;
| 186 |
register char *ep;
| 187 |
| 188 |
register char *lp;
| 189 |
char *curlp;
| 190 |
| 191 |
lp = alp;
| 192 |
for (;;) switch (*ep++) {
| 193 |
| 194 |
case CCHR:
| 195 |
if (!same(*ep, *lp))
| 196 |
return (0);
| 197 |
ep++, lp++;
| 198 |
continue;
| 199 |
| 200 |
case CDOT:
| 201 |
if (*lp++)
| 202 |
continue;
| 203 |
return(0);
| 204 |
| 205 |
case CDOL:
| 206 |
if (*lp==0)
| 207 |
continue;
| 208 |
return(0);
| 209 |
| 210 |
case CEOF:
| 211 |
explen = lp - alp;
| 212 |
return(1);
| 213 |
| 214 |
case CCL:
| 215 |
if (cclass(ep, *lp++, 1)) {
| 216 |
ep += *ep;
| 217 |
continue;
| 218 |
| 219 |
return(0);
| 220 |
| 221 |
case NCCL:
| 222 |
if (cclass(ep, *lp++, 0)) {
| 223 |
ep += *ep;
| 224 |
continue;
| 225 |
| 226 |
return(0);
| 227 |
| 228 |
case CDOT|STAR:
| 229 |
curlp = lp;
| 230 |
while (*lp++);
| 231 |
goto star;
| 232 |
| 233 |
case CCHR|STAR:
| 234 |
curlp = lp;
| 235 |
while (same(*lp, *ep))
| 236 |
lp++;
| 237 |
lp++;
| 238 |
ep++;
| 239 |
goto star;
| 240 |
| 241 |
case CCL|STAR:
| 242 |
case NCCL|STAR:
| 243 |
curlp = lp;
| 244 |
while (cclass(ep, *lp++, ep[-1]==(CCL|STAR)));
| 245 |
ep += *ep;
| 246 |
star:
| 247 |
do {
| 248 |
lp--;
| 249 |
if (advance(lp, ep)) {
| 250 |
explen += lp - alp;
| 251 |
return(1);
| 252 |
| 253 |
} while (lp > curlp);
| 254 |
return(0);
| 255 |
| 256 |
case CBRC:
| 257 |
if ((isalnum(*lp) || *lp == '_') && !(isalnum(lp[-1]) || lp[-1] == '_'))
| 258 |
continue;
| 259 |
return (0);
| 260 |
| 261 |
case CLET:
| 262 |
if (!isalnum(*lp) && *lp != '_')
| 263 |
continue;
| 264 |
return (0);
| 265 |
| 266 |
default:
| 267 |
fprintf(stderr, "RE botch\n");
| 268 |
| 269 |
| 270 |
| 271 |
static int
| 272 |
cclass(set, c, af)
| 273 |
register char *set;
| 274 |
register int c;
| 275 |
int af;
| 276 |
| 277 |
register int n;
| 278 |
| 279 |
if (c == 0)
| 280 |
return(0);
| 281 |
n = *set++;
| 282 |
while (--n)
| 283 |
if (n > 2 && set[1] == '-') {
| 284 |
if (c >= set[0] && c <= set[2])
| 285 |
return (af);
| 286 |
set += 3;
| 287 |
n -= 2;
| 288 |
} else
| 289 |
if (*set++ == c)
| 290 |
return(af);
| 291 |
return(!af);
| 292 |
