root/radiance/ray/src/common/rexpr.c
Revision: 2.2
Committed: Sun Nov 1 11:31:34 1992 UTC (32 years, 6 months ago) by greg
Changes since 2.1: +9 -12 lines
real fix for \< problems
1 /* Copyright (c) 1990 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 #include <stdio.h>
8 #include <ctype.h>
9 /*
10 * rexpr.c - regular expression parser (ala grep)
11 */
12
13 #define CCHR 2
14 #define CDOT 4
15 #define CCL 6
16 #define NCCL 8
17 #define CDOL 10
18 #define CEOF 11
19 #define CBRC 14
20 #define CLET 15
21 #define STAR 01
22
23 #define ESIZE 255
24
25 #define same(a,b) (a==b || (iflag && (a^b)==' ' && isalpha(a)))
26
27 #ifdef BSD
28 #define memcpy(to,from,len) bcopy(from,to,len)
29 #endif
30
31 static int advance(), cclass();
32
33 static char expbuf[ESIZE];
34 static int iflag;
35 static int circf;
36
37 int explen; /* length of the last expression found */
38
39 int
40 ecompile(sp, iflg, wflag) /* compile the expression */
41 register char *sp;
42 int iflg, wflag;
43 {
44 register c;
45 register char *ep;
46 char *lastep;
47 int cclcnt;
48
49 iflag = iflg;
50 ep = expbuf;
51 explen = 0;
52 if (*sp == '^') {
53 circf = 1;
54 sp++;
55 } else
56 circf = 0;
57 if (wflag)
58 *ep++ = CBRC;
59 for (;;) {
60 if (ep >= &expbuf[ESIZE])
61 return(-1);
62 if ((c = *sp++) != '*')
63 lastep = ep;
64 switch (c) {
65
66 case '\0':
67 if (wflag)
68 *ep++ = CLET;
69 *ep++ = CEOF;
70 explen = ep - expbuf;
71 return(0);
72
73 case '.':
74 *ep++ = CDOT;
75 continue;
76
77 case '*':
78 if (lastep==0)
79 goto defchar;
80 *lastep |= STAR;
81 continue;
82
83 case '$':
84 if (*sp != '\0')
85 goto defchar;
86 *ep++ = CDOL;
87 continue;
88
89 case '[':
90 *ep++ = CCL;
91 *ep++ = 0;
92 cclcnt = 1;
93 if ((c = *sp++) == '^') {
94 c = *sp++;
95 ep[-2] = NCCL;
96 }
97 do {
98 *ep++ = c;
99 cclcnt++;
100 if (c=='\0' || ep >= &expbuf[ESIZE])
101 return(-1);
102 } while ((c = *sp++) != ']');
103 lastep[1] = cclcnt;
104 continue;
105
106 case '\\':
107 if ((c = *sp++) == '\0')
108 return(-1);
109 if (c == '<') {
110 if (ep == expbuf || ep[-1] != CBRC)
111 *ep++ = CBRC;
112 continue;
113 }
114 if (c == '>') {
115 *ep++ = CLET;
116 continue;
117 }
118 defchar:
119 default:
120 *ep++ = CCHR;
121 *ep++ = c;
122 }
123 }
124 }
125
126 char *
127 expsave() /* save compiled string */
128 {
129 extern char *malloc();
130 register char *ep;
131
132 if (explen == 0)
133 return(NULL);
134 if ((ep = malloc(explen+3)) == NULL)
135 return(NULL);
136 ep[0] = iflag;
137 ep[1] = circf;
138 ep[2] = explen;
139 (void)memcpy(ep+3, expbuf, explen);
140 return(ep);
141 }
142
143 expset(ep) /* install saved string */
144 register char *ep;
145 {
146 iflag = ep[0];
147 circf = ep[1];
148 (void)memcpy(expbuf, ep+3, ep[2]&0xff);
149 }
150
151 char *
152 eindex(sp) /* find the expression in string sp */
153 register char *sp;
154 {
155 /* check for match at beginning of line, watch CBRC */
156 if (advance(sp, expbuf[0]==CBRC ? expbuf+1 : expbuf))
157 return(sp);
158 if (circf)
159 return(NULL);
160 /* fast check for first character */
161 if (expbuf[0]==CCHR) {
162 register c = expbuf[1];
163 while (*++sp)
164 if (same(*sp, c) && advance(sp, expbuf))
165 return(sp);
166 return(NULL);
167 }
168 /* regular algorithm */
169 while (*++sp)
170 if (advance(sp, expbuf))
171 return(sp);
172 return(NULL);
173 }
174
175 static int
176 advance(alp, ep)
177 char *alp;
178 register char *ep;
179 {
180 register char *lp;
181 char *curlp;
182
183 lp = alp;
184 for (;;) switch (*ep++) {
185
186 case CCHR:
187 if (!same(*ep, *lp))
188 return (0);
189 ep++, lp++;
190 continue;
191
192 case CDOT:
193 if (*lp++)
194 continue;
195 return(0);
196
197 case CDOL:
198 if (*lp==0)
199 continue;
200 return(0);
201
202 case CEOF:
203 explen = lp - alp;
204 return(1);
205
206 case CCL:
207 if (cclass(ep, *lp++, 1)) {
208 ep += *ep;
209 continue;
210 }
211 return(0);
212
213 case NCCL:
214 if (cclass(ep, *lp++, 0)) {
215 ep += *ep;
216 continue;
217 }
218 return(0);
219
220 case CDOT|STAR:
221 curlp = lp;
222 while (*lp++);
223 goto star;
224
225 case CCHR|STAR:
226 curlp = lp;
227 while (same(*lp, *ep))
228 lp++;
229 lp++;
230 ep++;
231 goto star;
232
233 case CCL|STAR:
234 case NCCL|STAR:
235 curlp = lp;
236 while (cclass(ep, *lp++, ep[-1]==(CCL|STAR)));
237 ep += *ep;
238 star:
239 do {
240 lp--;
241 if (advance(lp, ep)) {
242 explen += lp - alp;
243 return(1);
244 }
245 } while (lp > curlp);
246 return(0);
247
248 case CBRC:
249 if ((isalnum(*lp) || *lp == '_') && !(isalnum(lp[-1]) || lp[-1] == '_'))
250 continue;
251 return (0);
252
253 case CLET:
254 if (!isalnum(*lp) && *lp != '_')
255 continue;
256 return (0);
257
258 default:
259 fprintf(stderr, "RE botch\n");
260 }
261 }
262
263 static int
264 cclass(set, c, af)
265 register char *set;
266 register c;
267 {
268 register n;
269
270 if (c == 0)
271 return(0);
272 n = *set++;
273 while (--n)
274 if (n > 2 && set[1] == '-') {
275 if (c >= set[0] && c <= set[2])
276 return (af);
277 set += 3;
278 n -= 2;
279 } else
280 if (*set++ == c)
281 return(af);
282 return(!af);
283 }
