root/radiance/ray/src/common/resolu.h
Thu Mar 3 03:55:13 2022 UTC (2 years, 2 months ago) by greg
CVS Tags: HEAD, rad5R4
Diff to previous 2.15
feat: Added float and double alignment to i/o routines for future mmap() use
Mon Apr 6 04:00:08 2020 UTC (4 years ago) by greg
Diff to previous 2.14
Fixed bug where fscnresolu() would over-read string if followed by white space
Fri Jul 19 17:37:56 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.13: +2 -33 lines
Diff to previous 2.13
Thu Aug 2 18:33:42 2018 UTC (5 years, 9 months ago) by greg
Diff to previous 2.12
Wed May 10 18:02:08 2017 UTC (6 years, 11 months ago) by greg
Changes since 2.11: +8 -8 lines
Added const modifiers to a number of char * parameters
Thu May 21 18:08:43 2009 UTC (14 years, 11 months ago) by greg
Changes since 2.10: +15 -4 lines
Tue Feb 1 01:28:16 2005 UTC (19 years, 3 months ago) by greg
Eliminated redundant include files.
Fri Jan 2 11:35:17 2004 UTC (20 years, 4 months ago) by schorsch
Changes since 2.8: +3 -2 lines
Changes since 2.7: +5 -1 lines
Mon Jun 30 19:04:29 2003 UTC (20 years, 10 months ago) by greg
Changes since 2.6: +1 -2 lines
Changes since 2.5: +2 -4 lines
Fri Jun 6 16:38:47 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.4: +7 -28 lines
*** empty log message ***
Changes since 2.3: +2 -57 lines
Changes since 2.2: +116 -8 lines
Fri Jun 4 17:01:29 1993 UTC (30 years, 11 months ago) by greg
Tue Nov 12 16:56:16 1991 UTC (32 years, 5 months ago) by greg
Changes since 1.1: +0 -0 lines
Diff to previous 1.1
Mon Nov 11 14:03:22 1991 UTC (32 years, 5 months ago) by greg
