1 |
/* RCSid $Id: resolu.h,v 2.15 2020/04/06 04:00:08 greg Exp $ */ |
2 |
3 |
* Definitions for resolution line in image file. |
4 |
5 |
* Include after <stdio.h> |
6 |
7 |
* True image orientation is defined by an xy coordinate system |
8 |
* whose origin is at the lower left corner of the image, with |
9 |
* x increasing to the right and y increasing in the upward direction. |
10 |
* This true orientation is independent of how the pixels are actually |
11 |
* ordered in the file, which is indicated by the resolution line. |
12 |
* This line is of the form "{+-}{XY} xyres {+-}{YX} yxres\n". |
13 |
* A typical line for a 1024x600 image might be "-Y 600 +X 1024\n", |
14 |
* indicating that the scanlines are in English text order (PIXSTANDARD). |
15 |
16 |
#ifndef _RAD_RESOLU_H_ |
17 |
#define _RAD_RESOLU_H_ |
18 |
19 |
#ifdef __cplusplus |
20 |
extern "C" { |
21 |
#endif |
22 |
23 |
/* flags for scanline ordering */ |
24 |
#define XDECR 1 |
25 |
#define YDECR 2 |
26 |
#define YMAJOR 4 |
27 |
28 |
/* standard scanline ordering */ |
29 |
#define PIXSTANDARD (YMAJOR|YDECR) |
30 |
#define PIXSTDFMT "-Y %8d +X %8d\n" |
31 |
32 |
/* structure for image dimensions */ |
33 |
typedef struct { |
34 |
int rt; /* orientation (from flags above) */ |
35 |
int xr, yr; /* x and y resolution */ |
36 |
} RESOLU; |
37 |
38 |
/* macros to get scanline length and number */ |
39 |
#define scanlen(rs) ((rs)->rt & YMAJOR ? (rs)->xr : (rs)->yr) |
40 |
#define numscans(rs) ((rs)->rt & YMAJOR ? (rs)->yr : (rs)->xr) |
41 |
42 |
/* resolution string buffer and its size */ |
43 |
#define RESOLU_BUFLEN 32 |
44 |
extern char resolu_buf[RESOLU_BUFLEN]; |
45 |
46 |
/* macros for reading/writing resolution struct */ |
47 |
#define fputsresolu(rs,fp) fputs(resolu2str(resolu_buf,rs),fp) |
48 |
#define fgetsresolu(rs,fp) str2resolu(rs, \ |
49 |
fgets(resolu_buf,RESOLU_BUFLEN,fp)) |
50 |
51 |
/* reading/writing of standard ordering */ |
52 |
#define fprtresolu(sl,ns,fp) fprintf(fp,PIXSTDFMT,ns,sl) |
53 |
#define fscnresolu(sl,ns,fp) (fgetresolu(sl,ns,fp)==PIXSTANDARD) |
54 |
55 |
/* defined in resolu.c */ |
56 |
extern void fputresolu(int ord, int sl, int ns, FILE *fp); |
57 |
extern int fgetresolu(int *sl, int *ns, FILE *fp); |
58 |
extern char * resolu2str(char *buf, RESOLU *rp); |
59 |
extern int str2resolu(RESOLU *rp, char *buf); |
60 |
61 |
62 |
63 |
#endif |
64 |
#endif /* _RAD_RESOLU_H_ */ |
65 |
