--- ray/src/common/resolu.h 2003/06/06 16:38:47 2.5 +++ ray/src/common/resolu.h 2022/03/03 03:55:13 2.16 @@ -1,8 +1,8 @@ -/* RCSid $Id: resolu.h,v 2.5 2003/06/06 16:38:47 schorsch Exp $ */ +/* RCSid $Id: resolu.h,v 2.16 2022/03/03 03:55:13 greg Exp $ */ /* * Definitions for resolution line in image file. * - * Include after , , and + * Include after * * True image orientation is defined by an xy coordinate system * whose origin is at the lower left corner of the image, with @@ -15,12 +15,11 @@ */ #ifndef _RAD_RESOLU_H_ #define _RAD_RESOLU_H_ + #ifdef __cplusplus extern "C" { #endif -#include "copyright.h" - /* flags for scanline ordering */ #define XDECR 1 #define YDECR 2 @@ -28,7 +27,7 @@ extern "C" { /* standard scanline ordering */ #define PIXSTANDARD (YMAJOR|YDECR) -#define PIXSTDFMT "-Y %d +X %d\n" +#define PIXSTDFMT "-Y %8d +X %8d\n" /* structure for image dimensions */ typedef struct { @@ -51,29 +50,13 @@ extern char resolu_buf[RESOLU_BUFLEN]; /* reading/writing of standard ordering */ #define fprtresolu(sl,ns,fp) fprintf(fp,PIXSTDFMT,ns,sl) -#define fscnresolu(sl,ns,fp) (fscanf(fp,PIXSTDFMT,ns,sl)==2) +#define fscnresolu(sl,ns,fp) (fgetresolu(sl,ns,fp)==PIXSTANDARD) - /* defined in resolu.c */ + /* defined in resolu.c */ extern void fputresolu(int ord, int sl, int ns, FILE *fp); extern int fgetresolu(int *sl, int *ns, FILE *fp); extern char * resolu2str(char *buf, RESOLU *rp); extern int str2resolu(RESOLU *rp, char *buf); - /* defined in header.c */ -extern void newheader(char *t, FILE *fp); -extern int isheadid(char *s); -extern int headidval(char *r, char *s); -extern int dateval(time_t *t, char *s); -extern int isdate(char *s); -extern void fputdate(time_t t, FILE *fp); -extern void fputnow(FILE *fp); -extern void printargs(int ac, char **av, FILE *fp); -extern int isformat(char *s); -extern int formatval(char *r, char *s); -extern void fputformat(char *s, FILE *fp); -extern int getheader(FILE *fp, int (*f)(), char *p); -extern int globmatch(char *pat, char *str); -extern int checkheader(FILE *fin, char *fmt, FILE *fout); - #ifdef __cplusplus }
