root/radiance/ray/src/common/resolu.h
Revision: 2.13
Committed: Thu Aug 2 18:33:42 2018 UTC (7 years ago) by greg
1 /* RCSid $Id: resolu.h,v 2.12 2017/05/10 18:02:08 greg Exp $ */
2 /*
3 * Definitions for resolution line in image file.
4 *
5 * Include after <stdio.h>
6 *
7 * True image orientation is defined by an xy coordinate system
8 * whose origin is at the lower left corner of the image, with
9 * x increasing to the right and y increasing in the upward direction.
10 * This true orientation is independent of how the pixels are actually
11 * ordered in the file, which is indicated by the resolution line.
12 * This line is of the form "{+-}{XY} xyres {+-}{YX} yxres\n".
13 * A typical line for a 1024x600 image might be "-Y 600 +X 1024\n",
14 * indicating that the scanlines are in English text order (PIXSTANDARD).
15 */
16 #ifndef _RAD_RESOLU_H_
17 #define _RAD_RESOLU_H_
18
19 #include <time.h>
20
21
22 #ifdef __cplusplus
23 extern "C" {
24 #endif
25
26 /* flags for scanline ordering */
27 #define XDECR 1
28 #define YDECR 2
29 #define YMAJOR 4
30
31 /* standard scanline ordering */
32 #define PIXSTANDARD (YMAJOR|YDECR)
33 #define PIXSTDFMT "-Y %d +X %d\n"
34
35 /* structure for image dimensions */
36 typedef struct {
37 int rt; /* orientation (from flags above) */
38 int xr, yr; /* x and y resolution */
39 } RESOLU;
40
41 /* macros to get scanline length and number */
42 #define scanlen(rs) ((rs)->rt & YMAJOR ? (rs)->xr : (rs)->yr)
43 #define numscans(rs) ((rs)->rt & YMAJOR ? (rs)->yr : (rs)->xr)
44
45 /* resolution string buffer and its size */
46 #define RESOLU_BUFLEN 32
47 extern char resolu_buf[RESOLU_BUFLEN];
48
49 /* macros for reading/writing resolution struct */
50 #define fputsresolu(rs,fp) fputs(resolu2str(resolu_buf,rs),fp)
51 #define fgetsresolu(rs,fp) str2resolu(rs, \
52 fgets(resolu_buf,RESOLU_BUFLEN,fp))
53
54 /* reading/writing of standard ordering */
55 #define fprtresolu(sl,ns,fp) fprintf(fp,PIXSTDFMT,ns,sl)
56 #define fscnresolu(sl,ns,fp) (fscanf(fp,PIXSTDFMT,ns,sl)==2)
57
58 /* identify header lines */
59 #define MAXFMTLEN 64
60 #define isheadid(s) headidval(NULL,s)
61 #define isformat(s) formatval(NULL,s)
62 #define isdate(s) dateval(NULL,s)
63 #define isgmt(s) gmtval(NULL,s)
64
65 #define LATLONSTR "LATLONG="
66 #define LLATLONSTR 8
67 #define islatlon(hl) (!strncmp(hl,LATLONSTR,LLATLONSTR))
68 #define latlonval(ll,hl) sscanf((hl)+LLATLONSTR, "%f %f", \
69 &(ll)[0],&(ll)[1])
70 #define fputlatlon(lat,lon,fp) fprintf(fp,"%s %.6f %.6f\n",LATLONSTR,lat,lon)
71
72 /* defined in resolu.c */
73 extern void fputresolu(int ord, int sl, int ns, FILE *fp);
74 extern int fgetresolu(int *sl, int *ns, FILE *fp);
75 extern char * resolu2str(char *buf, RESOLU *rp);
76 extern int str2resolu(RESOLU *rp, char *buf);
77 /* defined in header.c */
78 extern void newheader(const char *t, FILE *fp);
79 extern int headidval(char *r, const char *s);
80 extern int dateval(time_t *t, const char *s);
81 extern int gmtval(time_t *t, const char *s);
82 extern void fputdate(time_t t, FILE *fp);
83 extern void fputnow(FILE *fp);
84 extern void printargs(int ac, char **av, FILE *fp);
85 extern int formatval(char fmt[MAXFMTLEN], const char *s);
86 extern void fputformat(const char *s, FILE *fp);
87 typedef int gethfunc(char *s, void *p); /* callback to process header lines */
88 extern int getheader(FILE *fp, gethfunc *f, void *p);
89 extern int globmatch(const char *pat, const char *str);
90 extern int checkheader(FILE *fin, char fmt[MAXFMTLEN], FILE *fout);
91
92 #ifdef __cplusplus
93 }
94 #endif
95 #endif /* _RAD_RESOLU_H_ */
96
