root/radiance/ray/src/common/resolu.h
Revision: 2.4
Committed: Tue Feb 25 02:47:22 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.3: +2 -57 lines
1 /* RCSid $Id$ */
2 /*
3 * Definitions for resolution line in image file.
4 *
5 * Include after <stdio.h>, <string.h>, and <time.h>
6 *
7 * True image orientation is defined by an xy coordinate system
8 * whose origin is at the lower left corner of the image, with
9 * x increasing to the right and y increasing in the upward direction.
10 * This true orientation is independent of how the pixels are actually
11 * ordered in the file, which is indicated by the resolution line.
12 * This line is of the form "{+-}{XY} xyres {+-}{YX} yxres\n".
13 * A typical line for a 1024x600 image might be "-Y 600 +X 1024\n",
14 * indicating that the scanlines are in English text order (PIXSTANDARD).
15 */
16
17 #include "copyright.h"
18
19 #ifdef __cplusplus
20 extern "C" {
21 #endif
22
23 /* flags for scanline ordering */
24 #define XDECR 1
25 #define YDECR 2
26 #define YMAJOR 4
27
28 /* standard scanline ordering */
29 #define PIXSTANDARD (YMAJOR|YDECR)
30 #define PIXSTDFMT "-Y %d +X %d\n"
31
32 /* structure for image dimensions */
33 typedef struct {
34 int rt; /* orientation (from flags above) */
35 int xr, yr; /* x and y resolution */
36 } RESOLU;
37
38 /* macros to get scanline length and number */
39 #define scanlen(rs) ((rs)->rt & YMAJOR ? (rs)->xr : (rs)->yr)
40 #define numscans(rs) ((rs)->rt & YMAJOR ? (rs)->yr : (rs)->xr)
41
42 /* resolution string buffer and its size */
43 #define RESOLU_BUFLEN 32
44 extern char resolu_buf[RESOLU_BUFLEN];
45
46 /* macros for reading/writing resolution struct */
47 #define fputsresolu(rs,fp) fputs(resolu2str(resolu_buf,rs),fp)
48 #define fgetsresolu(rs,fp) str2resolu(rs, \
49 fgets(resolu_buf,RESOLU_BUFLEN,fp))
50
51 /* reading/writing of standard ordering */
52 #define fprtresolu(sl,ns,fp) fprintf(fp,PIXSTDFMT,ns,sl)
53 #define fscnresolu(sl,ns,fp) (fscanf(fp,PIXSTDFMT,ns,sl)==2)
54
55 #ifdef NOPROTO
56 /* defined in resolu.c */
57 extern void fputresolu();
58 extern int fgetresolu();
59 extern char *resolu2str();
60 extern int str2resolu();
61 /* defined in header.c */
62 extern void newheader();
63 extern int isheadid();
64 extern int headidval();
65 extern int dateval();
66 extern int isdate();
67 extern void fputdate();
68 extern void fputnow();
69 extern void printargs();
70 extern int isformat();
71 extern int formatval();
72 extern void fputformat();
73 extern int getheader();
74 extern int globmatch();
75 extern int checkheader();
76
77 #else
78 /* defined in resolu.c */
79 extern void fputresolu(int ord, int sl, int ns, FILE *fp);
80 extern int fgetresolu(int *sl, int *ns, FILE *fp);
81 extern char * resolu2str(char *buf, RESOLU *rp);
82 extern int str2resolu(RESOLU *rp, char *buf);
83 /* defined in header.c */
84 extern void newheader(char *t, FILE *fp);
85 extern int isheadid(char *s);
86 extern int headidval(char *r, char *s);
87 extern int dateval(time_t *t, char *s);
88 extern int isdate(char *s);
89 extern void fputdate(time_t t, FILE *fp);
90 extern void fputnow(FILE *fp);
91 extern void printargs(int ac, char **av, FILE *fp);
92 extern int isformat(char *s);
93 extern int formatval(char *r, char *s);
94 extern void fputformat(char *s, FILE *fp);
95 extern int getheader(FILE *fp, int (*f)(), char *p);
96 extern int globmatch(char *pat, char *str);
97 extern int checkheader(FILE *fin, char *fmt, FILE *fout);
98
99 #endif
100
101 #ifdef __cplusplus
102 }
103 #endif
