| 1 |
/* RCSid $Id: resolu.h,v 2.12 2017/05/10 18:02:08 greg Exp $ */
| 2 |
| 3 |
* Definitions for resolution line in image file.
| 4 |
| 5 |
* Include after <stdio.h>
| 6 |
| 7 |
* True image orientation is defined by an xy coordinate system
| 8 |
* whose origin is at the lower left corner of the image, with
| 9 |
* x increasing to the right and y increasing in the upward direction.
| 10 |
* This true orientation is independent of how the pixels are actually
| 11 |
* ordered in the file, which is indicated by the resolution line.
| 12 |
* This line is of the form "{+-}{XY} xyres {+-}{YX} yxres\n".
| 13 |
* A typical line for a 1024x600 image might be "-Y 600 +X 1024\n",
| 14 |
* indicating that the scanlines are in English text order (PIXSTANDARD).
| 15 |
| 16 |
#ifndef _RAD_RESOLU_H_
| 17 |
#define _RAD_RESOLU_H_
| 18 |
| 19 |
#include <time.h>
| 20 |
| 21 |
| 22 |
#ifdef __cplusplus
| 23 |
extern "C" {
| 24 |
#endif
| 25 |
| 26 |
/* flags for scanline ordering */
| 27 |
#define XDECR 1
| 28 |
#define YDECR 2
| 29 |
#define YMAJOR 4
| 30 |
| 31 |
/* standard scanline ordering */
| 32 |
#define PIXSTANDARD (YMAJOR|YDECR)
| 33 |
#define PIXSTDFMT "-Y %d +X %d\n"
| 34 |
| 35 |
/* structure for image dimensions */
| 36 |
typedef struct {
| 37 |
int rt; /* orientation (from flags above) */
| 38 |
int xr, yr; /* x and y resolution */
| 39 |
} RESOLU;
| 40 |
| 41 |
/* macros to get scanline length and number */
| 42 |
#define scanlen(rs) ((rs)->rt & YMAJOR ? (rs)->xr : (rs)->yr)
| 43 |
#define numscans(rs) ((rs)->rt & YMAJOR ? (rs)->yr : (rs)->xr)
| 44 |
| 45 |
/* resolution string buffer and its size */
| 46 |
#define RESOLU_BUFLEN 32
| 47 |
extern char resolu_buf[RESOLU_BUFLEN];
| 48 |
| 49 |
/* macros for reading/writing resolution struct */
| 50 |
#define fputsresolu(rs,fp) fputs(resolu2str(resolu_buf,rs),fp)
| 51 |
#define fgetsresolu(rs,fp) str2resolu(rs, \
| 52 |
fgets(resolu_buf,RESOLU_BUFLEN,fp))
| 53 |
| 54 |
/* reading/writing of standard ordering */
| 55 |
#define fprtresolu(sl,ns,fp) fprintf(fp,PIXSTDFMT,ns,sl)
| 56 |
#define fscnresolu(sl,ns,fp) (fscanf(fp,PIXSTDFMT,ns,sl)==2)
| 57 |
| 58 |
/* identify header lines */
| 59 |
#define MAXFMTLEN 64
| 60 |
#define isheadid(s) headidval(NULL,s)
| 61 |
#define isformat(s) formatval(NULL,s)
| 62 |
#define isdate(s) dateval(NULL,s)
| 63 |
#define isgmt(s) gmtval(NULL,s)
| 64 |
| 65 |
#define LATLONSTR "LATLONG="
| 66 |
#define LLATLONSTR 8
| 67 |
#define islatlon(hl) (!strncmp(hl,LATLONSTR,LLATLONSTR))
| 68 |
#define latlonval(ll,hl) sscanf((hl)+LLATLONSTR, "%f %f", \
| 69 |
&(ll)[0],&(ll)[1])
| 70 |
#define fputlatlon(lat,lon,fp) fprintf(fp,"%s %.6f %.6f\n",LATLONSTR,lat,lon)
| 71 |
| 72 |
/* defined in resolu.c */
| 73 |
extern void fputresolu(int ord, int sl, int ns, FILE *fp);
| 74 |
extern int fgetresolu(int *sl, int *ns, FILE *fp);
| 75 |
extern char * resolu2str(char *buf, RESOLU *rp);
| 76 |
extern int str2resolu(RESOLU *rp, char *buf);
| 77 |
/* defined in header.c */
| 78 |
extern void newheader(const char *t, FILE *fp);
| 79 |
extern int headidval(char *r, const char *s);
| 80 |
extern int dateval(time_t *t, const char *s);
| 81 |
extern int gmtval(time_t *t, const char *s);
| 82 |
extern void fputdate(time_t t, FILE *fp);
| 83 |
extern void fputnow(FILE *fp);
| 84 |
extern void printargs(int ac, char **av, FILE *fp);
| 85 |
extern int formatval(char fmt[MAXFMTLEN], const char *s);
| 86 |
extern void fputformat(const char *s, FILE *fp);
| 87 |
typedef int gethfunc(char *s, void *p); /* callback to process header lines */
| 88 |
extern int getheader(FILE *fp, gethfunc *f, void *p);
| 89 |
extern int globmatch(const char *pat, const char *str);
| 90 |
extern int checkheader(FILE *fin, char fmt[MAXFMTLEN], FILE *fout);
| 91 |
| 92 |
#ifdef __cplusplus
| 93 |
| 94 |
#endif
| 95 |
#endif /* _RAD_RESOLU_H_ */
| 96 |
