root/radiance/ray/src/common/resolu.h
Revision: 2.5
Committed: Fri Jun 6 16:38:47 2003 UTC (21 years ago) by schorsch
Changes since 2.4: +7 -28 lines
*** empty log message ***
1 /* RCSid $Id: resolu.h,v 2.4 2003/02/25 02:47:22 greg Exp $ */
2 /*
3 * Definitions for resolution line in image file.
4 *
5 * Include after <stdio.h>, <string.h>, and <time.h>
6 *
7 * True image orientation is defined by an xy coordinate system
8 * whose origin is at the lower left corner of the image, with
9 * x increasing to the right and y increasing in the upward direction.
10 * This true orientation is independent of how the pixels are actually
11 * ordered in the file, which is indicated by the resolution line.
12 * This line is of the form "{+-}{XY} xyres {+-}{YX} yxres\n".
13 * A typical line for a 1024x600 image might be "-Y 600 +X 1024\n",
14 * indicating that the scanlines are in English text order (PIXSTANDARD).
15 */
16 #ifndef _RAD_RESOLU_H_
17 #define _RAD_RESOLU_H_
18 #ifdef __cplusplus
19 extern "C" {
20 #endif
21
22 #include "copyright.h"
23
24 /* flags for scanline ordering */
25 #define XDECR 1
26 #define YDECR 2
27 #define YMAJOR 4
28
29 /* standard scanline ordering */
30 #define PIXSTANDARD (YMAJOR|YDECR)
31 #define PIXSTDFMT "-Y %d +X %d\n"
32
33 /* structure for image dimensions */
34 typedef struct {
35 int rt; /* orientation (from flags above) */
36 int xr, yr; /* x and y resolution */
37 } RESOLU;
38
39 /* macros to get scanline length and number */
40 #define scanlen(rs) ((rs)->rt & YMAJOR ? (rs)->xr : (rs)->yr)
41 #define numscans(rs) ((rs)->rt & YMAJOR ? (rs)->yr : (rs)->xr)
42
43 /* resolution string buffer and its size */
44 #define RESOLU_BUFLEN 32
45 extern char resolu_buf[RESOLU_BUFLEN];
46
47 /* macros for reading/writing resolution struct */
48 #define fputsresolu(rs,fp) fputs(resolu2str(resolu_buf,rs),fp)
49 #define fgetsresolu(rs,fp) str2resolu(rs, \
50 fgets(resolu_buf,RESOLU_BUFLEN,fp))
51
52 /* reading/writing of standard ordering */
53 #define fprtresolu(sl,ns,fp) fprintf(fp,PIXSTDFMT,ns,sl)
54 #define fscnresolu(sl,ns,fp) (fscanf(fp,PIXSTDFMT,ns,sl)==2)
55
56 /* defined in resolu.c */
57 extern void fputresolu(int ord, int sl, int ns, FILE *fp);
58 extern int fgetresolu(int *sl, int *ns, FILE *fp);
59 extern char * resolu2str(char *buf, RESOLU *rp);
60 extern int str2resolu(RESOLU *rp, char *buf);
61 /* defined in header.c */
62 extern void newheader(char *t, FILE *fp);
63 extern int isheadid(char *s);
64 extern int headidval(char *r, char *s);
65 extern int dateval(time_t *t, char *s);
66 extern int isdate(char *s);
67 extern void fputdate(time_t t, FILE *fp);
68 extern void fputnow(FILE *fp);
69 extern void printargs(int ac, char **av, FILE *fp);
70 extern int isformat(char *s);
71 extern int formatval(char *r, char *s);
72 extern void fputformat(char *s, FILE *fp);
73 extern int getheader(FILE *fp, int (*f)(), char *p);
74 extern int globmatch(char *pat, char *str);
75 extern int checkheader(FILE *fin, char *fmt, FILE *fout);
76
77
78 #ifdef __cplusplus
79 }
80 #endif
81 #endif /* _RAD_RESOLU_H_ */
82
