--- ray/src/common/resolu.h 2003/02/25 02:47:22 2.4 +++ ray/src/common/resolu.h 2003/06/27 06:53:21 2.6 @@ -1,4 +1,4 @@ -/* RCSid $Id: resolu.h,v 2.4 2003/02/25 02:47:22 greg Exp $ */ +/* RCSid $Id: resolu.h,v 2.6 2003/06/27 06:53:21 greg Exp $ */ /* * Definitions for resolution line in image file. * @@ -13,13 +13,13 @@ * A typical line for a 1024x600 image might be "-Y 600 +X 1024\n", * indicating that the scanlines are in English text order (PIXSTANDARD). */ - -#include "copyright.h" - +#ifndef _RAD_RESOLU_H_ +#define _RAD_RESOLU_H_ #ifdef __cplusplus extern "C" { #endif +#include /* flags for scanline ordering */ #define XDECR 1 #define YDECR 2 @@ -52,30 +52,7 @@ extern char resolu_buf[RESOLU_BUFLEN]; #define fprtresolu(sl,ns,fp) fprintf(fp,PIXSTDFMT,ns,sl) #define fscnresolu(sl,ns,fp) (fscanf(fp,PIXSTDFMT,ns,sl)==2) -#ifdef NOPROTO /* defined in resolu.c */ -extern void fputresolu(); -extern int fgetresolu(); -extern char *resolu2str(); -extern int str2resolu(); - /* defined in header.c */ -extern void newheader(); -extern int isheadid(); -extern int headidval(); -extern int dateval(); -extern int isdate(); -extern void fputdate(); -extern void fputnow(); -extern void printargs(); -extern int isformat(); -extern int formatval(); -extern void fputformat(); -extern int getheader(); -extern int globmatch(); -extern int checkheader(); - -#else - /* defined in resolu.c */ extern void fputresolu(int ord, int sl, int ns, FILE *fp); extern int fgetresolu(int *sl, int *ns, FILE *fp); extern char * resolu2str(char *buf, RESOLU *rp); @@ -96,8 +73,8 @@ extern int getheader(FILE *fp, int (*f)(), char *p); extern int globmatch(char *pat, char *str); extern int checkheader(FILE *fin, char *fmt, FILE *fout); -#endif - #ifdef __cplusplus } #endif +#endif /* _RAD_RESOLU_H_ */ +
