--- ray/src/common/resolu.h 1991/11/12 16:56:16 2.1 +++ ray/src/common/resolu.h 2004/01/02 11:35:17 2.9 @@ -1,10 +1,9 @@ -/* Copyright (c) 1991 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: resolu.h,v 2.9 2004/01/02 11:35:17 schorsch Exp $ */ /* * Definitions for resolution line in image file. * + * Include after , , and + * * True image orientation is defined by an xy coordinate system * whose origin is at the lower left corner of the image, with * x increasing to the right and y increasing in the upward direction. @@ -14,7 +13,16 @@ * A typical line for a 1024x600 image might be "-Y 600 +X 1024\n", * indicating that the scanlines are in English text order (PIXSTANDARD). */ +#ifndef _RAD_RESOLU_H_ +#define _RAD_RESOLU_H_ +#include + + +#ifdef __cplusplus +extern "C" { +#endif + /* flags for scanline ordering */ #define XDECR 1 #define YDECR 2 @@ -26,13 +34,13 @@ /* structure for image dimensions */ typedef struct { - int or; /* orientation (from flags above) */ + int rt; /* orientation (from flags above) */ int xr, yr; /* x and y resolution */ } RESOLU; /* macros to get scanline length and number */ -#define scanlen(rs) ((rs)->or & YMAJOR ? (rs)->xr : (rs)->yr) -#define numscans(rs) ((rs)->or & YMAJOR ? (rs)->yr : (rs)->xr) +#define scanlen(rs) ((rs)->rt & YMAJOR ? (rs)->xr : (rs)->yr) +#define numscans(rs) ((rs)->rt & YMAJOR ? (rs)->yr : (rs)->xr) /* resolution string buffer and its size */ #define RESOLU_BUFLEN 32 @@ -47,4 +55,30 @@ extern char resolu_buf[RESOLU_BUFLEN]; #define fprtresolu(sl,ns,fp) fprintf(fp,PIXSTDFMT,ns,sl) #define fscnresolu(sl,ns,fp) (fscanf(fp,PIXSTDFMT,ns,sl)==2) -extern char *fgets(), *resolu2str(); + /* defined in resolu.c */ +extern void fputresolu(int ord, int sl, int ns, FILE *fp); +extern int fgetresolu(int *sl, int *ns, FILE *fp); +extern char * resolu2str(char *buf, RESOLU *rp); +extern int str2resolu(RESOLU *rp, char *buf); + /* defined in header.c */ +extern void newheader(char *t, FILE *fp); +extern int isheadid(char *s); +extern int headidval(char *r, char *s); +extern int dateval(time_t *t, char *s); +extern int isdate(char *s); +extern void fputdate(time_t t, FILE *fp); +extern void fputnow(FILE *fp); +extern void printargs(int ac, char **av, FILE *fp); +extern int isformat(char *s); +extern int formatval(char *r, char *s); +extern void fputformat(char *s, FILE *fp); +typedef int gethfunc(char *s, void *p); /* callback to process header lines */ +extern int getheader(FILE *fp, gethfunc *f, void *p); +extern int globmatch(char *pat, char *str); +extern int checkheader(FILE *fin, char *fmt, FILE *fout); + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_RESOLU_H_ */ +
